Question about HP Office Equipment & Supplies
After removing paper jam everything is Ok but does not print
    Problem Solver:
  • 15 Answers
Does it try to pull the paper into the printer?
Posted on Nov 03, 2008
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    I had a cannon LBP2900 printer. IT has a problem of paper jam. It prints very well in A5 paper but hen i try to print in A4 paper, the paper gets jam. It also makes some cracking sound and i found some...
    Without doing a complete disassemble, remove all covers, remove paper tray(s), remove ink cartridges (or laser cartridges...everything that is EASY to remove. Clean your rollers (may be gummed up a bit), remove all dust, dirt, grime, everything. My Canon printers are extremely sensitive to jams. As long as you keep it clean internally, you should have no problems. Take a look at this video about paper jams.
    Nov 30, 2017 | Canon LASER SHOT LBP-2900 Printer
    My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
    How to clear and avoid paper jams
    Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
    Paper jam in the printer
    Remove the paper manually
    1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
    2. Firmly grasp the paper, and gently pull it out.
    3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
    NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
    Paper jam in the paper support
    Paper or specialty media misfeeds
    These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
    Try one or more of the following:
    Check paper condition
    • Use only new, unwrinkled paper.
    Check paper loading
    • Load a smaller amount of paper into the printer.
    • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
    Remove each page as it is printed
    • Remove each page as it exits, and let it dry completely before stacking.
    Adjust the paper guides
    • When using media less than 8.5 inches wide
    • To rest against the edges of the paper or media, making sure it does not buckle
    Printer does not feed paper, envelopes, or specialty media
    These are possible solutions. Try one or more of the following:
    Check for paper jams
    • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
    Check media loading
    • Verify that the specialty media is loaded correctly.
    • Try loading one page, envelope, or sheet of specialty media at a time.
    Check printer default and pause settings
    1. Click:
      • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
      • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
      • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
      • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
    2. Double-click the print queue device.
    3. Click Printer.
      • Make sure no check mark appears next to Pause Printing.
      • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
    Banner paper jams
    There are many possible solutions. Try one or more of the following:
    Clear banner paper jams
    2. Remove the jammed banner paper from the printer.
    Review banner printing checklist
    • Use only the number of sheets needed for the banner.
    • Select the following settings to enable the printer to feed paper continuously without jamming:
      1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
      2. Click Properties, Preferences, Options, or Setup.
      3. Select the Paper Setup tab.
      4. From the Paper Size area, select Banner.
      5. Select Letter Banner or A4 Banner as the paper size.
      6. Select Portrait or Landscape.
      7. Click OK.
      8. Click OK or Print.
    Regards,
    Ron
    Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
    Had a paper jam. Paper was removed. It will not print. It keeps coming up with "unable to print 50" How do I get it to clear that off the screen?
    hey... most probably some the paper jam has caused some hardware disruption... u need to remove everything removable and again set it up...
    Apr 04, 2010 | Brother MultiFunction Center MFC-440CN...
    Paper jam but i removed all the paper
    Ohh, I had this same situation. What you have to do is disconnect everything. Ok, after that, connect the USB port on another port slot. Then connect the power cord. after that, your PC will say found new hardware, etc... Then go to Start, Control Panel, Add or Remove Programs all the way at the top. Then what you must do is uninstall every component of your printer. Then shut your computer down ( to allow it to process the info). Then install it again with the CD of installation. If you don't have the CD, google the name of your printer with the words installation. Then try printing another Document not the one you were trying to. After that cancel the printing. Finally, just print the document you want, and Viola!
    Aug 28, 2009 | HP DeskJet 5150 InkJet Printer
    Paper jam problem
    Remove the back cover and put an index card thru where the paper goes, that should push out any left over scraps.
    Jul 22, 2009 | Brother MFC 210C All-In-One InkJet Printer
    No paper pickup
    Hi damodarbk:
    it sounds like you need to replace the paper feed rollers.
    pdouglasss
    Jan 03, 2009 | HP LaserJet 3050 All-In-One Printer
    Paper jam cleared from back, but printer thinks it is still there
    HI
    please change the usb cable.. it will work.. and restalled that software cd also..
    do it.........
    Nov 18, 2008 | HP Photosmart 3310 Printer
    Carriage jam error
    Here is the document that i want you to follow exactly in order to resolve your issue.
    CLICK HERE TO VIEW THE DOCUMENT.==>> DOCUMENT
    Please let me know the result after following the document.
    Thank you so much. I remain.
    adonscott
    Jul 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
    Phaser 7700GX Color Printer prints wrinkled pages!
    when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
    In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
    Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
    42 people viewed this question
    Ben Johnson
