Question about T-Mobile Wing™ Smartphone
GPSR edge keeps trying to connect by itself...
I don't mind that it trys to connect but how do I stop it? It keeps turning on out of sleep mode and running down my battery. How do I stop that?
    Scholar:
  • 62 Answers
It sounds like you have a program that wants to keep connecting to the web.
Make sure you are closing all of your programs with the task manager.
If you find the program that keeps trying to connect, try to see if you can tweak the settings so it doesn't auto-connect.
Posted on Nov 18, 2008
Can't get my iPad to turn on! Have tried pressing the button for a long time, still not turning. What else should I do to get started?
In order (stop if one works):
1. Recharge at least an hour from power adaptor rather than USB computer lead.
2. Reset by holding down Sleep/Wake button on top right of tablet while at the same time pressing down home button. Keep both depressed 15 seconds. If slider appears or screen dims, keep pressing till Apple appears.
3. Restart (display not working) by pressing and holding Sleep/Wake button till power off slider appears. Drag slider to right. Wait 2 minutes. Press and hold Sleep/wake button till Apple appears.
4. Recovery Mode. With device powered down, hold sleep/wake button down and drag slider to off position. Then plug USB into a computer (do not have usb cable connected to iPad yet) running latest version of iTunes. Hold down Home button while plugging USB cable into iPad. Keep Home button down until Connect to iTunes appears. If does not appear, start Recovery Mode procedure again. When Lightning cable, arrow, and iTunes appears, release Home. Click OK to restore to factory defaults (erases data). Restore data from earlier backup. (Summary of method from Phone Cruncher site.)
Aug 28, 2017 | Tablets & eReaders
Why does my Hisense F46K20E tv shut off by itself?
try to see if the sleep mode is activated (turn it off if it does), or there are overheating issue.
Aug 07, 2014 | Hisense Televison & Video
How to undisable i phone 3gs
You could put it in to recovery mode these are the steps
Turn off your device. If you can't turn it off, press and hold the Sleep/Wake and Home buttons at the same time and wait a few seconds for it to turn off.
Plug the device's USB cable into your computer only.
Hold down the device's Home button as you connect the USB cable to it.
When you see the Connect to iTunes screen, release the Home button. If you don't see this screen, try steps 1 through 3 one more time.
keep in mind this erases all you're data unless you have backed-up it upped. last step is to restore your iphone whit itunes.
And if you've changed you're mind about going into recovery just restart your iphone to cancel the process.
Hope This helped.
Apr 18, 2014 | Apple iPhone 3G Black Smartphone
My Micro Cruz keeps turning itself on. Won't stay off for longer than five minutes then the screen powers up and stays on. I have resorted to powering it off after use which sucks as it looses time, my...
So it's your screen that is coming back on after you press the power button to put it into sleep mode (not all the way off)? Flashing to the new firmware made this issue even worse. I would try a full reset. Back up apps and follow the procedure for resetting the device (press the hole at the top with a paper clip don't use a mechanical pencil...).
Other than this I would reflash or flash to a new rom it seems like you have a defect not a software issue. Flashing to the the updated rom should've fixed any problem that was software based not made it worse. It seems like there is a connection loose and it's triggering the device to wake up from sleep mode. If you feel like you have it in you, you can pull the device apart and try securing all connections but this is not recommended.
Oct 31, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Everytime I turn on moniter it goes into sleep mode and won't wake up!!
If there was something wrong with the monitor itself it wouldn't go to sleep it would just turn off. It sounds to be as if there is an issue with the signal going to the monitor itself, try restarting your PC and ensure that the connection on the back of the monitor and the connection on the back of your PC are secure.
Mar 07, 2011 | HP f2105 21" LCD Monitor
My iphone is not showing the chargfing icon yet it is charging, slowly
You may please keep in mind that iPhone battery may drain instead of charge if iPhone is connected to a computer that's turned off or is in sleep or standby mode. If you charge the battery while syncing or using iPhone, it may take longer to charge. About not showing the charging icon, please try resetting the phone by pressing the Sleep/Wake Button and the Home Button both simultaneously after which the phone restarts after some time with apple logo on the screen. -- MS Ramakrishna
Oct 13, 2010 | Apple iPhone Smartphone
How to stop sleep mode?
Sleep Mode
Setting the Sleep Mode reduces power consumption while the machine is idle.
You can choose how long the FAX/MFC is idle (from 00 to 99 minutes) before
it drops into sleep mode. The timer automatically resets itself after the machine
receives a fax or PC data or makes a copy. The default setting is 0 minutes.
1 Press Menu/Set, 1, 7.
2 Use the Dial pad to enter the length of
time the machine is idle before it drops into sleep mode (00 to 99 minutes),
and then press Menu/Set.
3 Press Stop/Exit.
Dec 01, 2009 | Brother IntelliFAX 2800 Laser Fax
Monitor Problem
That is because your computer is trying to display a picture at a higher resolution than the monitor can handle
EG. if your monitor was only capable of lets say 800 x 600 and you decided to try force it to display 1680 x 1260 your monitor would do one of three things
try but die doing so
switch itself to sleep or standby mode
scream at you that its "OUT OF RANGE"
The H & V numbers are horizontal and vertical frequencies sometimes it is possible to use the monitors own OSD to change these but please check in the monitor manual before you do so.
Your best bet is to start your computer in safe mode and re-set the resolution to something a little more in the range of the monitor and then try re-boot.
If this information was useful then please click below
Aug 17, 2009 | Princeton Digital VL1916 19" LCD Monitor
Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
May 24, 2009 | Dell Dimension 3000 PC Desktop
Computer not sleeping in sleep mode.
One possibility is if you have an optical/laser mouse that is on a relective surface and the mouse light is reflecting and triggering the computer to think that there is activity.
More than likely, your network card is keeping your computer from staying in sleep mode as any internet data activity is taking the computer out of sleep mode making the computer think there is activity.
There is an option in the Network Adapter properties that says to "Allow this device to wake up your computer"
Go to Control Panel and click Classic View on the left hand side
Double Click the Network and Sharing Centre Icon.
On the left hand side of the window that opens, click Manage Network Connections.
Right Click on the connected Network Connection. It is probably the Local Area Connection. Right click on it and choose Properties
A new box will open up. Click the Configure button under the Connect Using: box
Click the last tab at the top that says Power Management.
Under the Power Management tab click the square box that is beside: Allow this Device to Wake the Computer to take the checkmark out of the box. Then Click OK at the botton and close all the windows.
Let the computer go into Sleep mode and see if the computer still comes out of sleep mode on its own.
Let me know if this worked for you,
Ry
Apr 03, 2009 | HP Computers & Internet
T-Mobile Wing™ Smartphone Logo
47 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
