SOURCE: I have a 2001 Yamaha 200 blaster 4 wheeler.
You have to adjust the jets on the carb, theres a high and low jet, Turn them both all the way in ( dont force them) just turn until they stop, now losen each one in 1/4 intervals and try running it,
SOURCE: Yamaha 2001 Raptor 660, need to clean my carb
Drain and replace the gas with fresh.
Remove the air cleaner and spray carb cleaner into the inlet. Work your throttle a little then put everything back together and try to start it.
SOURCE: Starting Problems Yamaha TTR 125
Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Be sure the bolts are tight. Let the float bowl fill then start the engine. Set the idle speed with the idle screw. This process should get you back on the road.
Please rate this solution. Thanks!
SOURCE: 2001 Yamaha Banshee that won't stay running
If your jetting is too rich it will be extremely hard to kick start it and will most likely flood it from kicking.First thing i would do is pull the top of the carbs off (cable,slides and needles) and see which clip they're set at. If they are set stock which would be middle clip then lower the needle one clip. This will lean the mix out and should start up easier with no problems,The idle issue is most likely just off.If your fiance still has the TORS on it then on top of the carbs he will see 2 dime size and screws and wires as soon as he takes his seat off.While running he can turn each dime size screw in or out to adjust the idle. If it has a TORS elimator kit on it then he won't have all the junk on top of the carbs and it will be just a cable and round cap screwed directly on top of the carbs and the idle screws will be on the side of each carb (brass color screws with nuts to tighten) same thing...in or out to adjust the idle where needed.Hope this helps.
-Steve
