Question about Tyan Tiger 230 S2507D Motherboard
I have the same Tyan Tiger 230 (s2507) motherboard
I got it from a friend and decided it would be a good basic unit to put together to play games such as W.O.W etc.... I cant find anyone that have the drivers for this motherboard. Everything runs good I just cant it all to run good together. Meaning it wont display anything on the screen. Im assuming its because it lacks the motherboard drivers? It maybe basic to you guys but im not quite sure what to do next.. any help would be greatly appreciated.
thanks,
cole
(I did write alot about your problem but im not sure if it sent so i will sum it up)i have the same motherboard only time i get that error is with a video card greater then 512mb, clockspeed of over 400, also could be the drivers for ur video card as well as the motherboard. (i dont no much about computers so thats the best i can give you, sorry) Hope that helps and good luck. i also run wow on this motherboard and i could play it at about 50fps at max graphics so it works pretty good for a cheepy
Posted on Mar 04, 2009
I get one long beep followed by 2 short beeps.
Depending on what bios you have the problem is either your video card or the ram. On most bios's the is a video issue but on the odd one it is a dma access error ie memory.
You need to check your video card. If you have a spare one or can borrow one then swap it and see if it boots. It could be a few things but basically either a faulty video card or slot.
DMA access could mean the mother board has a problem or the video card or even ram.
This isn't a very common error but is usually the video card.
Oct 02, 2011 | Tyan Tiger MPX S2466 Motherboard
I need a manual for a tyan tiger i7501b s2729g2 motherboard.
(http://www.tyan.com/manuals/m_s2723_102.pdf)
This is the manual for Tiger i7501 (S2723), since your motherboard is from the same family, their manuals are common. Hope this helps.
Apr 17, 2009 | Computers & Internet
Need a schematic for this motherboard tyan tiger 133 (1834)
I found the information that you are looking for and you will find it here: http://www.tyan.com/archive/products/html/tiger133.html. This page on Tyan's Web site will provide you with a color image of the mother board (with slots labeled) along with the specs for the board. I hope this is exactly what you need.
Thanks for using Fixya and please rate my solution.
IT_GURL :)
Mar 27, 2009 | Tyan Tiger 133 S1834 Motherboard
Os istallation problem
Hi Prashant
This will apply is you are using a SATA drive and are attempting to install Windows XP:
In the box your motherboard came in, there should be a 1.44Mb floppy disk (Also called a stiffy). This will have the driver for XP to be able to read your SATA controller. If you do not have this "stiffy", either contact the hardware manufacturer or check their website for a download.
When Windows XP setup starts, and you are greeted with the blue screen, press the "F6" button when prompted to do so - to make XP setup allow you to install a 3rd party driver SCSI or RAID controlled. This you have to do within a few seconds of setup starting, so make sure to look carefully. The message will appear in the bottom of the screen.
This applies for IDE / ATA HDD:
Ensure that the HDD is being properly picked up by the BIOS. If not, ensure that all connections are good. If they are, test with another, known good, HDD to check whether your HDD is not maybe at fault.
Jan 07, 2009 | Tyan Tiger K8WE (S2877ANRF) Dual Opteron/...
Tyan tiger mpx (S2466N-4M) weird boot problem
probably the board is bad or the board is grounded out on the chassis edge somewhere or possibly the mounting screws...
recommendation.. pull the system out of the chassis
test the power and board on a sheet of cardboard...
also try one stick of memory only and set the options for full ecc scrubbing on to test the memory correctly
Aug 26, 2008 | Tyan Tiger MPX S2466N-4M Motherboard
I want to get a layout diagram of the tyan s2507 motherboard
The manual for that motherboard is located here -
ftp://ftp.tyan.com/manuals/m_s2507S_100.pdf
You will need Reader installed in order to open the PDF document. If you don't have Reader, get it free from http://www.adobe.com
Oct 29, 2007 | Tyan Trinity 450 (S2507S) Motherboard
Tyan Tiger 230 S2507D Motherboard Logo
325 people viewed this question
Top Tyan Computers & Internet Experts
Jerry Umali
Larry Chandler
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
