Question about Plextor PX-716A (PX716ASW) DVD±RW Dual Layer Burner
Plextor PX 716A & PX 755SA Neither will read !
I recently started having problems with my Optical drives after switching my motherboards. I switched to an MSI P35 Neo2 Intel based board after my other one went down the drain.
Ever since I switched out mainboards I have a hard time getting any form of DVD or CD to play on either of my Plextor drives. I have certain DVDs that I cannot watch, and only certain DVD Games will play as well. I have never had a problem playing CD formated games or discs to play. Any thoughts?
james klgr
  • 362 Answers
SOURCE: Plextor PX-716A will not read discs
the problem could be in he media player settings, check them and change as required. its pretty self explainatory.
Posted on Dec 09, 2007
  • 236 Answers
SOURCE: DVD drive
yoru writter is fine, it only detects what type of disk you are attempting to write to. please double check the disk you inserted, has to be new and not used. the only reason you will get this kind of message is when you inserted a finally burned disk, that is not set for multisession. this has nothing to do with your hard drive also.
Posted on Apr 10, 2008
roy_gv
  • 107 Answers
SOURCE: After a re-installation of WinXP, my px-716a will
hello, the dirver is not the issue, its the hardware itself. try to do this; control panel-administrativetool-imapi cd burning rom, and choose disable,.. Why? maybe the lens has not enough power...
Posted on Mar 09, 2010
pappapumpdaf
  • 635 Answers
SOURCE: I would like to make this a slave so that my 500
It would be a better idea to set your plextor on another pata/ide cable as master since many plextor drives are known to conflict with certain hard drive models reducing their speed or corrupting the hard drive cache. I can't confirm this problem with your drive, but I usually set any plextor on a separate cable. That having been said however, you can easily set both drives as master and slave with the jumpers located on both drives. Your hard drive will show your jumper settings on the top of the drive, and your plextor DVD will be stamped on the rear near the 40 to 80 wire data cable with these letters cs, sl, or ma. Some will have the full name stamped (Cable Select, Slave, Master). Set your plextor jumper to Sl or slave mode. If you have a Western Digital there is an option to set it to master/single. Do not use this setting since with a slave drive it is no longer a single drive. Simply choose master or master with slave.
Posted on Mar 13, 2010
Testimonial: "Thank you for the help, I've tried this and it almost was working but for some reason my system I'm getting NTLDR is Missing"
dasphyzie
  • 148 Answers
SOURCE: i can't read or write with my PLEXTOR DVDR
try a cd if it dosent work try a dvd if it dosent work there's no two way you need to change the lens
Posted on May 27, 2010
I can't read or write with my PLEXTOR DVDR PX-716A (DVD+R9) why ?
drivers, bad dvd, or the dvd player is bad, and possibly the usb to your computer 1.0, 2.0, 3.0
May 27, 2010 | Plextor (PX-716A-BPS) DVD RW Dual Layer...
I would like to make this a slave so that my 500 GB PATA HardDrive will be the master as that has my operating system and the Plextor PX-716A drive will be the slave?
You need to configure the jumper at the back of the drive as shown in the following picture
Configure the CD/DVD drive as slave, configure the hard drive as Master.
Mar 13, 2010 | Plextor PX-716A (PX716ASW) DVD±RW...
After a re-installation of WinXP, my px-716a will no longer burn. Checking the drivers, I see they are all Microsoft drivers so I downloaded the latest Plextor drivers (v1.11) and supposedly updated them -...
Mar 09, 2010 | Plextor (PX-716A-BPS) DVD RW Dual Layer...
Plextor px-708a will not recognize disks. Just removed a second DVD drive from the system and jumpered px-708a as MASTER. The system recognizes the drive; it just will not read.
as you've changed the configuration of the drive from slave to master you need to go into the bois and change the settings for the drive so that it reads the px as master cd drive
Feb 25, 2010 | Plextor PX-708A DVD±RW Burner
My HP computer does not recognize the Plextor PX-880U DVD Drive
Try getting new firmware from Plextor and see if that doesn't help the problem.
Feb 06, 2010 | Plextor (PXW5224TAT3BP10PK)...
716a light blinks amber and doesnt see disks inserted
The drive is in need of service and needs to be sent to Plextor for a replacement.
Jan 30, 2010 | Plextor PX-716A (PX716ASW) DVD±RW...
Need to put px 716a burner into new computer. 37 pin to sata
Hello
Thank you for using FixYa for your problem
Sorry they do not do a IDE to sata adapter, the Motherboard need the sata port, or take back and get the IDE version
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Plextor (PX-716A-BPS) DVD RW Dual Layer...
When I turn my computer on the tray keeps opening and closing.
open the computer casing disconnect the power and ribbon cables from the drive and the motherboard wait about 30 seconds replug everything and power up and reboot
Jun 11, 2009 | Plextor PX-716A (PX716ASW) DVD±RW...
Dec 09, 2007 | Plextor (PX-716A-BPS) DVD RW Dual Layer...
Plextor PX-716A (PX716ASW) DVD±RW Dual Layer Burner Logo
139 people viewed this question
Top Plextor Computers & Internet Experts
Ben Armstrong
DROPNDEAL
DROPNDEAL
Are you a Plextor Computer and Internet Expert? Answer questions, earn points and help others
