Question about Frigidaire CWS3600AS Top Load Washer
Wont drain Washer works until the drain cycle comes on, it just wont drain ...we replaced the punp but that was not the problem, any other suggestions
  • james dziemianzuk
    james dziemianzuk Jan 20, 2009
    Mine does the same but I have not replaced the pump. I would like to get more info before I put any parts in it. The timer stops when it gets to rinse. How many volts should be at the drain pump .
    Brigadier General:
  • 6,966 Answers
A couple of areas to additionally check:
  • drain valve/filter. some versions have this additional part. this would be between the tub and the pump;
  • drain hose. check for kinks, blockage, layout;
  • controller board relay for drain valve/pump. They often get burned or cold solder;
  • controller board itself.
The diagrams here might be of help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 03, 2008
LG Washer not completing spin cycle and says LE
It is either:
1. Thermistor error. $6 part. Easy repair
2. Motor position sensor issue. $18 part. Easy repair
check out repairclinic.com or appliancepartspros.com for repair videos. Thermistor can be replaced from bottom of washer . Videos show you where it is.
Mar 06, 2017 | LG WM-1832C Front Load Washer
Bought in 2006 and quit working all together in 2007 then pulled it out today and the thing started working until the end of the wash cycle and wont come on at all again... it drained well but at the
Hello Kimberley,
It appears that a part of your question is cut off so i may be off base here but what i am reading is that your washer will go through the wash cycle and drain the wash water then just quit?? is that what is happeningIf yes that is whats going on i think what is happening is that after the wash cycle it fills with only COLD WATER for the rinse cycle and its not filling with the rinse water and just sits their until the rinse cycle water is filled and if its not getting cold water into the washer its not going to do anything If it is filling with cold water my apologies my bad for misinterpreting what the question reads and i ask ya to re-ask it.
GENE
Nov 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have an toploader smart drive (about 12 years old now). I added some clothes to the machine last minute throught the cycle and now its just stopped. Dashboard lights come on but it wont drain or...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 21, 2011 | Fisher and Paykel WA37T26G Top Load Washer
Washer stops in middle of cycle. Comes up with code d5. My wife pushed something on and off 3 times and came up with a code of f71
some machines come with a reset program but not all. Suggest you pull the plug out and wait 20 min untill washer has totally discharged. In the mean time, try and drain the water from the tub. Take note if the drain pump motor is working as well. Retry a wash program..
Sep 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
The drum wont hold water. it goes right out the draim
The drain needs to be above the actual water level or it will run out, the pvc should be above this point in order for the hose to get air and not act like trap and run out all that comes in,< woud suggest going to hardware store and getting piece to add on to 4 inch section with a coupler and washer drain cap>. they will cut to length, < take measurement of pipe size and length needed to get just bellow height of washer top, pvc goes together by cleaning and glueing, if the 4 inch piece has angle cut then it will have to be cut to strait line for good seal.
Apr 22, 2009 | Amana NAV3330E Top Load Washer
Fisher paykel ecosmart washer wont go drain or go to rinse cycle
this is joyce
take hose and siphion the water out of the unit.run into pan on floor or outside if you have long enough hose. it will come out just get started by putting one end in water in tub and the other end outside or in tub or whatever and start suction on hose untill water comes out and let run untill all water is out of tub.
thanks,
joyce
Feb 07, 2009 | Fisher Paykel EcoSmart GWL15
Washer won't drain and clothes stay soaked
Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Neptune washer won't drain
pump ,could be blocked or could have failed.i have same model and have had to replace it.to be sure get volt meter stick meter probes into pump wires turn washer to pump out[around spin area]if voltage but no drain yes need punp or clean out.u can get to it from the back.God bless,tom
Dec 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
My washer will not drain or spin the water out
sounds like pump problems the washer wont go into spin cycle until pump drains water so until pump gets replaced the way to get water out is a bucket sorry wish could help more
Aug 23, 2008 | Washing Machines
Frigidaire CWS3600AS Top Load Washer Logo
103 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
