Question about ASUS P5NSLI (0610839134670) Motherboard
I update my bios with older version.
Aftyer i update my bios with older version, my computer did not boot it again.. how can i repair it?
4 Suggested Answers
aceltix
  • 119 Answers
SOURCE: BIOS
have you tried a bios reset instead?try a full reset by getting out the battery and by switching the jumper (all this disconected from the power)-do this with the ramm dims out of the slots also.sometimes this use.
try also to replace the battery and after that rewrite the bos by doing this from a bootable cd under dos mode.DO NOT use the aplication to flash or to update the bios under windows.
this might damage the bios.
check also the integrity of the bios hard component on your mainboard(look for scraches,signes of colizion)
check the bios data..you may have something wrong set
good luck
inform me of your doing..bye
Posted on Feb 07, 2008
colliewob
  • 778 Answers
SOURCE: T60 after Bios Update to Ver. 2.22 no Video
I do not know if this will work
1)open case
2) check motherboard for word which will say reset bios or words to that effect nearby will be a small 2 or 3 pin connector with the 2 pin remove the jumper from 1 pin and fit over both reboot and turn off straight away refit jumper back over 1 pin and reboot see what happen it may work
with 3 pin setup jumper will already be over 2 pin remove and fit over middle and the other pin remove reboot etc
Usually a failed bios update is more often than not fatal
hope this works for you if it does post favorable rating thanks
Posted on Jul 29, 2008
  • 16 Answers
SOURCE: my computer can not boot -BIOS ROM checksum error
to be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Posted on Jun 15, 2009
  • 119 Answers
SOURCE: BIOS update on MSI KT6 Delta (MS-6590 v2 5.0)
You should be able to get it from here.
http://www.motherboard.cz/driver/msi.htm
Posted on Apr 26, 2010
Windows 7 with Gigabyte motherboard says "ntldr is missing"
Check if UEFI is disabled after flash with newer BIOS version. If you flash BIOS the default settings gets loaded again. Check hard disk settings and boot settings.
Mar 03, 2013 | Gigabyte Computers & Internet
I have a Motherboard MSI 865PE Neo3 MS-6728 ver3.0. You can install Win XP normally but is will never boot any Windows 7 CD installer with boot error "CDBOOT: Cannot boot from CD - Code:5". I...
be sure if you computer and the installer is the same as 32 or 64 bit.. check your computer and your installer.... be sure you have updated version of your motherboard..
Jun 30, 2011 | MSI 865PE Neo3-FS Motherboard
Microsoft is unable to determine the exact cause of this error. However, this problem was most likely caused by an error in your computer?s random access memory (RAM). RAM is the main internal storage area...
What are you doing when this happens? It sounds like you will have to get a BIOS upgrade weather you like it or not. Visit the motherboard manufacturer's website and obtain the BIOS update from there.
Dec 29, 2009 | Microsoft Windows XP Professional for PC
My computer can not boot -BIOS ROM checksum error
Jun 15, 2009 | EliteGroup K7VTA3 V5.0 Motherboard
Problems after BIOS update
If the updated BIOS is the problem, reflashing the old version should remedy the situation. Many BIOS flash utilities save a copy of the old BIOS before they flash the new one, so you should check that before searching for an older version (which may still be available on the Intel site).
Before you try any of that though, you should go into Device Manager and uninstall the offending devices. Reboot the computer. Check Device Manager again to see that it re-added the devices. If it didn't right-click on the computer name in Device Manager and select Scan for hardware changes in the context menu to have Windows install the correct drivers for the devices. If the devices still don't work, then resorting to reflashing the BIOS is appropriate.
Jun 01, 2009 | Insignia D400a PC Desktop
Asus bios problem
Unless there is a compelling reason to update the bios it should be left alone. Apparently this is one reason for that sage advice.
Go back to asus, download an older version of the bios and install it. Fortunately you didn't end up unable to boot or you would be buying a new board.
Apr 29, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
I can't reset to default bios
hello, you will need to open your system unit, you will find a battery inside the motherboard remove the battery and refix it back. all the information on the bios will be cleared.
Apr 06, 2009 | Computers & Internet
Failed bios recovery on ASUS P5S800-VM using support cd
Hi there.
If you look on any support/bios update forum/website, you will find that flashing the bios is very risky. The reason it's risky is because of what you just described.
While flashing the bios, the bios chip memory is deleted and then the new bios is written. If you lose power, system crashes, or anything that interrupts the flashing process, the chip is rendered useless.
The computer turned off while flashing, and the reason there is no screen is because there is no bios to load. There is no way to reverse this or repair it.
If you are handy with a soldering iron and are confident with electronic components, you may be able to pick up another bios chip on the internet, but you will have to solder it to the board yourself.
Otherwise it's a new motherboard.
Sorry it wasn't good news
Mar 25, 2009 | ASUS P5S800-VM Motherboard
PowerEdge Server won't boot after memory upgrade
if you really need the BIOS update. you need a working PC to download the BIOS and unzip it to a CD. install it, since the PC do see the CD, you may have do some maneuver to ge the BIOS installed.
Oct 29, 2008 | Dell PowerEdge 1800 Server
Enter BIOS on boot
According to the intel manual the key is F2
"The BIOS Setup program can be used to view and change the BIOS settings for the computer. The
BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST)
memory test begins and before the operating system boot begins."
That is from the manual for the board, instead of reinstalling Windows you may as well just change the product key on one of the installations to your other copy.
Mar 07, 2008 | Intel D850MV Motherboard
ASUS P5NSLI (0610839134670) Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
