Question about Yamaha (AX497) 2-Channel Amplifier
Hook-Up Does anyone know how to hook up a Yamaha 2 channel amplifier Model # CA 400?
    Genius:
  • 1,175 Answers
Http://www.hifiengine.com/manuals/yamaha/ca-610.shtml
Free registration
CA600 is close enough for what you need
Posted on Jan 18, 2009
    Brigadier General:
  • 6,966 Answers
It all depends what other devices are to be installed to the Yamaha Ca-400. Perhaps your best bet would be to consult the owner's manual. For the owners manual of a Yamaha CA400, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 03, 2008
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
Can i wire one speaker to the other speaker inside the box so that i only have one positive and one negative cable wire coming out out of the box and to the amp
Hello... I can help you with this question. Yes it is possible to do this, but you will have to use a 2 ohm stable mono block amplifier in order to do this. By connecting both positives together and both negatives together, you will be running a 2 ohm load. So if your amp is a monoblock amp, connections will be simple as tieing all the positives together and the negatives together and just hook to the amp. If you are using a 2 channel amplifier that is bridgeable, then you will need to series the subwoofers to an 8 ohm load and then bridge the amplifier to 1 channel. The way you series the subwoofers is take the positive wire in the box and hook to the positive on subwoofer #1. Take the negative wire in the box and hook to the negative on subwoofer #2. Then take a piece of wire and hook the negative from subwoofer #1 to the positive connector on subwoofer #2. Then hook the wires to the amplifier. To bridge the amplifier (if it is a 2 channel bridgeable) would be to use the left positive and the right negative, but check the amplifier for markings to confirm this. If you have any other questions, feel free to let me know and I will help you out! Hope this helps!!
20 year car audio/video installer
Bay manager
Mar 22, 2011 | Kicker 05C104 Car Subwoofer
Hello i was wanting to know if i could hook up my AX-596 amplifier to my Yamaha HTR-5860 reciver
I assume you want to slave it to the receiver and drive some more speakers with it.
Connect some RCA cables from whichever channel pre-outs you want on the HTR-5860 to any input on the AX-596.
Set the AX volume to something sufficiently high, run through the HTR's speaker level setup and match the AX volume to match the channels on the receiver. Then leave the AX's volume alone.
If you just want the AX to have access to program sources of the HTR, run the RCA cables to it from one of the VCR1 or 2 Out (but DO NOT select whichever one you use via the front panel). These are not affected by the HTR's volume controls.
May 07, 2010 | Yamaha AX-596 Amplifier
Sony X-Plode amplifier. NOT working
It is possible if the model amp you have is bridgable to 1 channel. Usually when you bridge an amp you will need to hook one wire to the positive side of one channel and the negative side to the other. You will need to consult you user manual for the amp or get the manual from the sony website for instructions on how to bridge the amp or if the amp is even bridgable.
Oct 11, 2009 | Car Audio & Video
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
How the best way is to hook up 2 400 wat amp's to 3 subs
four chl run inside spk
440wat run bass
cap look at manufactory recommendation for cap and make connection to amp'''''''oh make to ground amp seperate from cap
Apr 04, 2009 | Car Audio & Video
Amp wont come on
you might have blown a mosfet transistor or resistor inside the amp
Jan 19, 2009 | AudioBahn A4004T Car Audio Amplifier
Jensen LXA400 Fuse Size and RCA hook up for 2 channel mode?
take it to a stereo shop. there are variables you may not be aware of when hooking up speakers to an amplifier like ohms, very important!
Dec 08, 2008 | Jensen LXA400 Car Audio Amplifier
Yamaha (AX497) 2-Channel Amplifier Logo
217 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
