Contributor
- Posted on Dec 03, 2008
Re: I just bought the magellan maestro, and I can't get...
The GPS unit comes with an adhesive disk that must be installed on the surface where you want to place the GPS unit. The suction cup will only work with this adhesive disk. Once the adhesive disk is installed, the suction cup will hold. Here's the instructions magellan web site...
- Clean and dry the dashboard where the adhesive disk is going to be installed using enclosed alcohol pad.
- Remove the protective paper cover from the bottom of the adhesive
disk; place the bottom of the adhesive disk firmly on the dashboard.
- Apply even pressure on the top of the adhesive disk for a secure fit (Allow 24 hours to cure).
- Place suction cup mount on top of adhesive disk.
- Firmly press suction cup mount down flat against the adhesive disk,
press the suction cup lever down to secure the suction cup to the
adhesive disk.
even with clean disk the suction cup won't work for me
even with the disk it still doesnt suction!
I did exactly as you and the guide mentions. But the surface is bumpy like a golf ball and so did not adhere properly. Any ideas?
