Question about Panasonic DMR-ES10 DVD Recorder
DMR-ES15 Stops after 45 Min.
We have new Panasonic Recorder DMR-ES15. While we try to record keeping the setting LP, 2 Hrs or LP 4 Hrs and using the media DVD-R
the recorder stops after about 45 min. and show U88 error and gets restarted.
This is not every time. but more often than the good case.
Solution/help is appreciated.
  • pitcom Nov 06, 2008
    Thanks for the reply.. We are not getting convinced with any such assertion, as recording stops exactly in around 45 minutes. Can it be because of buffering problem or such...? is there any body who are facing the similar problem, and can suggest solution they fund.
    Regards
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
U88 means the unit has detected an error while recording or playing and has entered its recovery process to restore the unit to normal operation. You could try using a DVD-RAM disk or a different make of DVD-R but, as you say the unit is new, you should probably return it to the retailer for exchamge, repair or refund according to unit age and retailer's return policy.
Posted on Nov 06, 2008
  • Mike C
    Mike C Nov 06, 2008
    If the problem continues to occur regardless of type of media used, then the unit should be returned to the retailer - as stated above.
Hello! I have a problem with a Panasonic DMR-ES15 DVD recorder. I have an error code E61. I tried all the solutions manual but did not work. I can not use it either as player or as a recorder. reset have a...
Hello.
I had a similar problem with my DMR-ES15 a little over 2 years ago, and, I too, could not find a solution. I resorted to sending it off to Panasonic for their 'out of warrantee' repair, for a hefty price. (I could have bought new, but really liked the features of the ES15.) Panasonic repaired it, and it worked well for another 2 years. Just recently, 3 weeks ago, it died it's second death, with the same issue. I wish I had a solution for both of us, but it seems it is a failure which cannot be repaired by the consumer. I had seen a previous post, which has a suggestion of looking for '2 failed capacitors', but no other information, not even where these capacitors are located in the machine. I enterd a post myself, but have received so solutions/suggestions, and I don't even see my post on this site anymore. I'm a little disappointed with 'Fixya'...
If I find any new information, I'll be sure to post it.
Feb 03, 2011 | Panasonic DMRES15 DVD Recorder
My dmr-eh55s will no longer transfer from the hard drive to the DVD in the high speed mode. It will in low speed mode (real time).
It sounds like the DVD-RAM drive is about dead. Panasonic did not make them to be very durable.
Panasonic sells replacements at a high cost.
Replacement drives may work from used models including:
DMR-ES15
DMR-ES25
DMR-ES45
DMR-ES46
Jun 17, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
Sep 30, 2009 | Panasonic DMRES15 DVD Recorder
Panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
Jun 05, 2009 | Panasonic DMR-ES10 DVD Recorder
Problem with Panasonic DVD Recorder DMR-ES15 We have a Panasonic DVD Recorder DMR-ES15 that we have used successfully for quite a while now that has ALL OF A SUDDEN quit recognizing ANY disc. We are in the...
With a soft cloth, clean the 'hole' area of a DVD that you know worked in the past. Sometimes oils from our fingers get on the disc and then the disk can't spin properly. If the problem persists, open the case and look for two failed capacitors. (See similar solutions on this website.)
Apr 01, 2009 | Panasonic DMRES15 DVD Recorder
Dmr-es15
My DMR-ES15, dvd recorder is showing a U-61 code, I'd done all the instructions on my user manual. I think the problem is lost of memory. How can I get it back working. If I have to change chip of memory what is the part No., and how much will cost me in US dollars. Thanking you in advance.
Sep 06, 2008 | Panasonic DMR-E80H DVD Recorder
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
Tuning tv stations for panasonic dvd recorder DMR ES15
Set your TV to channel 3 or 4. Then press TV/VCR which is above the button on the bottom right of the remote. Then you can tune in TV stations from the unit.
Aug 20, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10 DVD Recorder Logo
317 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
