Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Side by side (KSRB25FHSS05) loosing cool in freezer
My side by side (KSRB25FHSS05) started loosing the cool on the freezer side tonight. Unit seems to be running fine, fan running, compressor hot, no build up of lint on the coil, no build up of ice on the freezer back wall. Unit was built 02-2000.
Thanks for the advice!
  • 2 more comments
  • James Lane
    James Lane Nov 03, 2008
    Thanks Tech Master - No, I don't hear humming - no clicking either.
  • James Lane
    A little ice on the coil - that did it - tech coming to fix today - a Big Thanks for the help Guys !! :-)
  • bobbieanne Nov 07, 2008
    My kitchenaid superba side-by-side refrigerator is no longer staying cool in the freezer *or* the refrigerator side. It's humming quietly and clicking. Any quick fixes that will at least get my food through the night and then I can call a repair company in the morning... or go buy a new one?
  • griff06 Oct 03, 2009
    My Kitchenaid super BA ksrw25crss02 stopped cooling, it started first with jus the ice cream. so I cleaned it out and made sure nothing was covering air flow. unplugged it and plugged it back on and it got worst,the fridge then started not cooling. Only thin I notice was the digital controls could hardly work--got them working except for the on and off button--now it does not cool at all
  • 120 Answers
Your compresor is hot but is it running at all or is it just humming trying to start and the just clicks off if it is just your overload that is tripp you need to replaced it that the box connected to the compressor on the left side that is why not is cooling if is running then is cheaper to buy a new one since the 5 year warranty on the compressor has expired
Posted on Nov 03, 2008
Jame open the back cover of the evaporator are in the frezeer section you will a type of radioator thats is your evaporator now check for frost if just frosted is ok if all iced up and a lot of ice then yoy have a defrost problem if no frost and compressor is running and you are sure of that then check the name plate for the date the unit was manufacture is less tha 5 years call a tech ou to check for freon or restriction ;leaks if less than 5 years is free but you have to be sure is running becuase the seal system in the only one under warranty ok
Side by side kitchen aide 48"
What is the model number of the unit?
Nov 12, 2012 | Refrigerators
Kenmore model 105.53534300 side by side refridgerator not cooling
Relays are located on the left side of the compressor. How long ago did you smell the burning smell? Are you 100% sure the compressor is running? If it is, nothing is wrong with the relays. Although sometimes it is hard to tell if the compressor is running. By morning temps will be higher than tonight if compressor isnt running. If it isnt running, relays must be changed. I will post shortly on how to change the relays.
Dec 23, 2007 | Kenmore 53542 / 53544 Side by Side...
Have a kitchen aid side by side refrig that stopped working tonight. Model KSRB25FH with ice maker. Noticed ice was wet earlier today and tonight food has thawed in freezer section and refrig was not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Microwave Ovens
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
FREEZER SEEMS TO RAISE IN TEMP. AND ICE STARTS THAWING THEN STARTS FREEZING AGAIN. FRIDGE SIDE SEEMS NOT AS COLD ALSO.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 18, 2010 | Whirlpool ED2GHEXN Side by Side...
Kenmore side by side refrigerator 58642891
depends on the AGE of the one you have needing repairs . FIXYA can not determine what you need to do .
Nov 14, 2017 | Kenmore 56563 Side by Side Refrigerator
Refrigerator ok, but freezer not cooling - side-by-side Freezer cooling has been erratic lately, now does not seem to be cooling at all
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
ft789ui
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Kenmore cold spot not cooling properly
heatman101
jsrha
Apr 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
Jan 26, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator not cooling but freezer is
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Mar 17, 2008 | Maytag MZD2766GES Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
253 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
