Question about Acer PH110 Multimedia Projector
Acer Dlp projector PD311
Recently the projector has been shutting off after 15-20 min after turnig on.
It starts blinking red on temp ,lamp and the on button. The fan stays running and it does come back on but shut right off within minutes turn on.
Help me understand what causes problem. I change the bulb but that wasn't the issue. I have this same problem with my Acer PH530. It has been back to Acer for repairs four times already. They never seem to fix anything though. Every time I fire it up it works for 15-20 minutes then shuts itself off. The temp light blinks for a while. It isn't getting over-heated, there isn't a problem with any of the fans or the lamp... Someone please help me fix this.  I'm tired of talking with Acer customer service reps, sending it in to them – which takes a month or two each time – and then having it return with the same problem.
jcarlton214
  • 105 Answers
SOURCE: Acer pd120 projector
get a bottle of canned air. blow out unit. take bulb out and clean everywhere every time you change bulb. let it sit for a while so it warms back up prior to plugging back in.the air gets cold
Posted on Jun 07, 2009
SOURCE: My Acer PH530 overheats and shuts down after 15 minutes.
Same here.
But i found a solution. I mounted a 80mm 12V Fan on the Air-Intake Side of the Projector, connected 12V Power and viola - no overheating anymore.
It's very loud but i got my Projector in an extra Room in my Basement-Cinema. So noise is not an issue for me.
Posted on Jan 17, 2010
  • 2340 Answers
SOURCE: projector shuts down after a couple of minutes
This probably the fan is not cooling down the temperature of the high intensity bulb. Due to overheating the bulb will shutdown. Get a correct specification fan to replace the aging fan.
Posted on Jun 01, 2010
SOURCE: Acer PD 525 projector I have change the bulb and
Fan circuit is not comming on in time
Posted on Jul 14, 2010
  • 138 Answers
SOURCE: my acer lcd projector not showing display, its
I suggest call for assistance for that product or replace the bulb of your projector.
Posted on Sep 20, 2011
I have infocus t160 projector, it shuts off after 1 or 2 min and led of temp flashing red & lamp flashing green.
seems that the mother board is broken.
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 23, 2014 | InFocus X16 DLP Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
When I hit the start button on my NP 115 it begins to sound like the fan labors and pulses until it shuts down and the red light blinks in a series of 6 blinks. It also has a very hit frequency squeak that...
after 5 minute image go out n power indicator steady light orange n status indicator red light blikns in a series of 6 blinks. in the manual book said lamp error.. what mind "lamp error". please help me.
Jul 28, 2011 | NEC NP115 DLP Projector
My projector will not power on. I've replaced the cables, the power source, and the bulb but still nothing. The red standby led on the control unit turns blue when power button is pressed but goes right...
The ballast unit has most likely failed. Replace the ballast unit, unless the lamp exploded and in which case, there may be glass fragments stopping a fan from turning.
Feb 03, 2011 | Optoma HD81 DLP Projector
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
System locked
is there a lock swich and can you reset it srry i tried
May 10, 2009 | Acer PD311 DLP Projector
Projector shuts down after turned on and both red lights blink
this model is prone to over heat. look near the lamp for the temp sensor it is most likely bad
Nov 30, 2008 | BenQ PE7700 Multimedia Projector
Acer PH110 Multimedia Projector Logo
85 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
