Question about HP OfficeJet 6110 All-In-One InkJet Printer
6110xi paper jam, or something worse?
I've flipped it open, removed back access panel, and cannot find anything like a paper jam. Also, I looked for some type of mechanical sensor that lets the printer know there is paper loaded, and I don't see anything.
Where is the paper jam sensor located? Maybe it needs to be cleaned.
I hope I can fix this. I'd hate to send another printer to the landfill.
  • rtso1 Nov 04, 2008
    Tripwire45 - I tried everything in the link. Nothing worked. Maybe this printer is worn out, and the Paper Jam error is is indicating such.
  • kjro Nov 17, 2008
    If your's prints one page, then stops and shows the error message, then you can press enter for another page to print, try this fix. Read all the way to the bottom. (Unplug power from printer, hold down # and 3, plug back in, hold till reset.) Worked for me two times now. http://h10025.www1.hp.com/ewfrf/wc/docum...
    Novelist:
    Scholar:
  • 111 Answers
Actually, the "paper jam" message can be displayed due to a variety of jam locations and other causes. Starting by looking in the back of the printer is a good first step, but you can have a jam in the front or even in the automatic document feeder (although that one should be apparent because it's sticking out the front end.
HP.com has a web page that goes into a lot of detail about where to look for a paper jam and what other conditions in your product might cause such a message to occur. The solutions are available as well. Take a look here:
Paper Jam error
Try those solutions and post back your results. Good luck.
Posted on Nov 03, 2008
Paper jam
Hi......................
How to Clear a Paper Jam on an HP Inkjet Printer?????
Paper jams are among the most common problem with HP inkjet printers. Follow these instructions to learn how to clear a paper jam so you can get back to work.
Instructions Things You'll Need
  • HP inkjet printer
    • 1 Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
    • 2 Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
    • 3 Look for paper through the opened back panel. Remove any paper you find jammed.
    • 4 Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
    • 5 Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
    • 6 Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
    • 7 Close the front access panel. Make sure that it latches back into place.
    • 8 Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this will helpful to you...................
Good Luck.............
Sep 24, 2011 | HP DeskJet D1460 InkJet Printer
Paper jammed
    This is how to clear paper jammed in canon inkjet printer.
    1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
    2. Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
    3. Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
    4. Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
    5. Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
    6. Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
    7. Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
    8. Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam
Dec 19, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Keeps having paper jams need help
Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device. Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
Look through the opened back panel and look for paper. Remove any and all paper you find jammed there. Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
Following the steps above you can clear the paper jam issue on your canon inkjet printer installed on your Windows based PC.
Hope that helps.
Thanks for using fixya..
Nov 17, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Have a paper jam I can't get to .
1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
2. Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
3. Look for paper through the opened back panel. Remove any paper you find jammed.
4. Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
5. Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
6. Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
7. Close the front access panel. Make sure that it latches back into place.
8. Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Oct 02, 2010 | HP Officejet 6310 All-In-One InkJet...
Paper stuck
  • 1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
  • 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
  • 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
  • 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
  • 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
  • 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
  • 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
  • 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
  • Sep 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    MY HP PRINTER SAYS I HAVE A PAPER JAM BUT I CANT FIND ANY PAPER JAMMED. WHEN I TRY TO PRINT ITMAKES A NOISE LIKE WOODPECKER PECKING ON A TREE. HOW CAN I GET IT TO WORK AGAIN
    Take care.
    Jun 07, 2010 | HP Photosmart C6180 All-In-One InkJet...
    Keeps saying there is a jam in the paper feed, when you open the front door there is no jam, reclose it and it will print
    1. Step 1
    2. Step 2
    3. Step 3
    4. Step 4
    5. Step 5
    6. Step 6
    7. Step 7
    8. Step 8
    Hope this helps. Please rate my response.
    Thanks.
    Have a good day.
    Mar 17, 2010 | HP LaserJet 2420 Printer
    I had a major paper jam at my printer (Canon, Super G3, imageClass MF 4150). I removed all the paper which was not easy. The printer is not working and switches to following messages: Paper Jam, Lift panel...
    2. Step 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
    3. Step 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
    4. Step 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
    5. Step 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
    6. Step 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
    7. Step 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
    8. Step 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
    Jan 26, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
    Paper jam - can't clear error message
    Hello Nj,
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Paper jams are was very common on HP printer model.
    Here are few instructions on how to clear the paper jam on your printer.
    How to Clear a Paper Jam on an HP Inkjet Printer 1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
    Hope this helps.
    Aug 08, 2009 | HP Office Equipment & Supplies
    Error Paper output slot the paper is jammed.
    8. Plug the printer’s power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
    Nov 23, 2008 | Canon Office Equipment & Supplies
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    71 people viewed this question
    Seeker5211
    Seeker5211
