Question about Parsons QuickVerse 7 Essentials (fe11044) for PC
Loading problem Everything seems to load properly from the cd-rom, except there is nothing in the text screen. Just blank. I turned off the Anti-virus and Firewall before installing as suggested by quickverse. I have uninstalled and reinstalled with the same result. I contacted quickverse tech support and was told they were aware of some people having this problem but had no solution since they had been unable to recreate the problem there. Help me if you can. Thanks,
Having problems installing QuickVerse 2006 MacAuthur Commentary Library, Vol.1 & R. C. Sproul Library, Vol. 1?
CD will go through the inital setup, and once it starts its installation process, it stops installing at 5%. Is there a solution in correcting this problem?
Posted on Feb 27, 2009
HP pavilion ze4600 XP operating system safe mode etc. will not load CD restore does not work either? help
Firstly hdd's shouldn't click. Purchase a new hdd set your BIOS to boot from CD drive, install XP from your disc.
Dec 05, 2014 | HP Computers & Internet
Tip
Upgrade CD/DVD ROM to CD-RW/DVD ROM
I just replaced my original CD/DVD ROM with a Toshiba SD-R2512 CD-RW/DVD ROM in my 1805-S253 running Windows ME. I used "Roxio Easy CD Creator" for writing to CD's. Everything was "plug'n'play" except the bezel that came with the new drive had to be swapped out. Windows ME recognized the new drive immediately and I didn't have to load any new drivers. This upgrade will probably work on other 1800 or 1805 Satellite series machines.
on Apr 13, 2008 | Toshiba Satellite 1805-S253 Notebook
Cd drive wont recognize blank cd's and i brought brand new ones and it still dosen't reconize them
Make sure you've loaded blank CD on CD RW device. CD ROM drive has nothing to read on blank CD. Regards
Dec 19, 2010 | Dell Computers & Internet
When I turn my Toshiba A45-S151 laptop on, I first get the screen that shows the Toshiba logo and has the four icons under the logo. Usually the next screen is black, has a cursor in the top left corner,...
That blinking cursor is the way in which the BIOS is telling you that Windows is not loading because its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Oct 18, 2010 | Toshiba Satellite A45-S151 Notebook
Status:Oxc000000f,can this problem be sorted out without recovery discs or windows installation disc?
First download the recovery cd from here.
Second Burn it to CD
Then turn off your computer,then after that, turn on again your computer and while the screen is blank, just keep tapping F8 key until you will see the advanced boot options,select your CD ROM.After that, click repair computer, after you click that windows will load you will then choose the US as keyboard layout just follow the on-screen instruction,if you will see like "choose an recovery option", just choose start-up repair and then your computer will begin the start-up repair
Hope will work, but if nothing happens you need to reinstall the Operating System of your computer.
Feb 04, 2010 | Computers & Internet
Problem loading windows
it seems your window corrupt....just try to repiar it using win xp cd
or can go with blind try....
go to bios and set priority boot from hard drive rather then cd
Mar 31, 2009 | Computers & Internet
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Computer turns on, wont load windows, then goes to a blank screen
When a PC boots first it checks all of the hardware to ensure all is working properly. The stage two of that is turning it over to the operating system. When it is turned over to the operating system the first thing it looks for is the Master Boot Record which is a small program on your hard drive that starts your operating system. If it cannot find the Master Boot Record or if the boot record is corrupt then the operating system will not load. In order to fix put the WIndows operating system disk into your CD ROM and let it boot to the CD ROM. Allow it to load for a few minutes and it will eventually ask you if you want to proceed with the installation or "repair". Choose repair. This is one option to fix your boot record.
Second option is to use Recovery Console. Put the Windows CD in the CD ROM. Click on Start and then Run. In the run box type D:\i386\winnt32.exe /cmdcons (where D is your CD ROM drive). Follow the instructions on the screen. You will be at the command line, type in FIXBOOT. This will also fix your master boot record. Follow these procedures anytime you have an operating system load error use the Recovery CD as your last resort. Hope this helps.
Dec 24, 2008 | Acer Aspire 5315 Notebook
My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Nov 05, 2008 | HP Pavilion dv4000 Notebook
LOADING DISC
except XP os disk is not oping automatic so please after insert the disk go to my computer and doble clik the f drive it will open still its not open cd is correpted
Jul 03, 2008 | Zenith Data Systems Zenith (OP-260-74501)...
Parsons QuickVerse 7 Essentials (fe11044) for PC Logo
132 people viewed this question
Top Parsons Computers & Internet Experts
Marvin
Marvin
Norman Al-Anbar
Are you a Parsons Computer and Internet Expert? Answer questions, earn points and help others
