Question about Philips 55PP9352 55" Projection Television
Pincussion/Geometry/Convergance Problem Today I tried to take advantage of utilizing my hdtv using my new xbox 360. Everything went fine, My son and I played it for about an hour and then turned it off. About an hour later my nephew came over to check it out but when I turned the TV on the convergance was all screwed up. The center seems fine but then bows out where the sides are really bad. I tried to adjust the convergance through the remote but it will only move horitontally and vertically. It seems to have a bowed effect which the remote is unable to fix. How could this all of a sudden happen? I read that maybe there are service codes you can push ont he remote to adjust for settings. If I purcahse a service manual would that solve this problem?
  • James Davy Sep 27, 2006
    Wow, that was a fast response. Thank you for that. Well after the Tv was off after a while, I turned it on to adjust what i could so my wife and I could watch some television. And the bow was gone, though the convergence needed to be adjusted big time. When I was finished correcting the convergence everything looked great. Do you think that a component inside the Tv is going to go out soon? What could cause this?
    Sergeant:
  • 337 Answers
If you can not correct the convergence with custumer settings is because something went wrong inside the tv and it has to be diagnosed and corrected by a service technician,you are correct there are setting you can access with the remote but are usually adjusted after you have replace a major component.I would suggest you call for service,I do not believe is a problem you created or you could have prevented.
Posted on Sep 27, 2006
My Xbox 360 is fuzzy and has green dots all over the screen
I doubt it's the 360 since everything else is working just fine. The menu works fine, the game works fine. However if you downloaded one of these maps from the marketplace it may be corrupt, and you will have to delete and re-download the map pack.
May 15, 2010 | Microsoft Xbox 360 Console
New HDTV.. xbox 360 has no audio but has video
alright. make sure that your red, green and blue are all plugged in properly and that your audio plugs are also in there correct plugs. i think audio is red and yellow. correct me if im mistaken
Jun 10, 2009 | Microsoft Xbox 360 Console
Xbox wont show on screen
Check the little switch on the av cord at the end where it goes into the xbox. If your using component most likely it needs to set to HDTV. If your using the yellow, red, and white cables then set it to TV. My tv will go all black if mine is set to HDTV when I'm using the yellow, white and red ends. I hope this helps.
Jun 09, 2009 | Microsoft Xbox 360 Console
New interface on 360
There could be a number of reasons your interface is failing. Have you tried to restart the device? Unplug everything, let it sit for a few moments and then start it all up again. That should do the trick.
Jan 11, 2009 | Microsoft Xbox 360 Console
Saved games on xbox 360 hard drive
its not the account just the hard drive. make a new xbox live account.
Jan 02, 2009 | Microsoft Xbox 360 Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Hi when I turn my xbox 360 on the power button just flashed red.
Need more info on what happens. On my sons we would turn it on and the light let but that was it. We found out that the power supply that came with it went out. Try a new power cord from the plug on wall to the game system.
Dec 15, 2008 | Microsoft Xbox 360 Console
Hello my name is steve
Maybe Your A/V cord went bad maybe you should try buying a new one
Dec 13, 2008 | Microsoft Xbox 360 Console
How to hook up a XBOX 360 to an HDTV
You can go to Wal-Mart or any major electronics store and buy a splitter/selecter for your different devices.
Basically, the unit will allow you to connect a few input devices (xbox, ps3, whatever) into one HD connection on an HDTV. You will be able to select which device uses the HD connection to the tv through a switch.
I hope you find the item :-) A Competent electronics salesman should be able to help you out just fine!
Jun 29, 2008 | Microsoft Xbox 360 Console
Hannspree 37" with Xbox 360 HD
Try to use a HDMI cable, your component cables may not be usable with your TV.
Apr 20, 2008 | Hannspree (K206-10U1-005) Television
Philips 55PP9352 55" Projection Television Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
