I contacted customer support MOTEVO MOBILE and they emailed me the document. Thank youI contacted customer support MOTEVO MOBILE and they emailed me the document. Thank you
You can't post conmments that contain an email address.
What do you mean by "Not working"? If you cannot get to the settings screen on the Motevo you will not be able to update it. Updates are often done by using a USB memory stick or a Micro SD card. You use a computer or a laptop to download the updates from the Motevo website onto the memory stick/SD card then plug that into the Motevo unit in the car. You then go to the settings and select the update option.
https://www.sony.com > support > kf-50we620 > faqs
LCD Projection TV HD-Monitor Grand WEGA® / Included components may vary by country or region of purchase: RM-Y913 · Questions & Answers · Is this page helpful?
I just bought a used honda city that has this Motevo GTV-x3+ installed. I was successful in storing the channel using the remote. After I go into the radio section, I touch the "Scan" button on screen and once it pauses on a channel I like, I touch the "Scan" button again. This stops the tuner from moving on to the next channel. Next, using the remote I long press a number for example 1 and the channel is stored in the list on position 1.
This is symptom of weak lamp in TV, please replace lamp in TV and I would suggest to buy Sony original lamp for TV safety. Lamp replacement procedure is written in user manual in details, click Sony Support if you want to download user manual copy. Thanks.
Installation is Quick and Easy:
In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
Unplug your Projector from your power outlet
Allow the lamp to cool for at least one (1) hour before replacing it
Remove the Lamp unit cover
Unscrew the lamp housing unit
Remove the old lamp housing unit and discard
Screw in the new lamp housing unit
Place the cover back onto your unit
Caution: Do NOT touch the bulb directly with your fingers.
Thank you I found it
