Question about Maytag Atlantis MAV6451 Top Load Washer
Fuses keep blowing out
The fuse on my washer control keeps blowing out? The fuse was blowing out twice a year. Now the fuse is blowing every 2-3 loads. No water goes in the drum - washer just stops.
Why is this?
    Problem Solver:
  • 4 Answers
IF water is not going in the drum It sounds like the water valve coil has finally failled , It has been blowing fuses ,because the ccoil on the water valve was getting weak . change this water valve and you sohould be ok , but before doing so chaeck to see if you have the proper voltage going to this valve when It is calling to open ,if the power is there and the water is turned on the valve should be letting water in the machine . you can also take a ohm meater and check the valve for proper resistance . . If the machine is up in years I would change this valve . from the chack I mentioned earlier . hope this helps you
Posted on Nov 27, 2008
Fisher and paykel keeps blowing fuses, code 37, I have replaced the pump already
Yes the original bad pump has damaged the drain pump circuit on the control board.
Dec 20, 2016 | Fisher and Paykel Washing Machines
My whitewater pin keeps on blowing fuse F114. display read check fuses F114/F115. Changed 114 but keeps on blowing.
Pinball problems are commonly discussed on pinball forums. For your case go to http://pinballbash.com/forum/index.php?topic=2526.msg23570#msg23570 and look for a very long append from VisitorQ. He gives a nice detailed description of the possible causes.
Aug 22, 2016 | Game Room Guys Flipper Opto Board Williams...
Keeps blowing fuses
Try using higher Amps fuse.
Oct 13, 2014 | Washing Machines
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Fuse keeps blowing, tech replaced a 'faulty' battery but it continued. Tech then fixed a 'short in th wiring and still the fuse keeps blowing. Not sure if this is a glitch or an actual problem with just my...
What fuse keeps blowing (drive or hyd HEAVY FUSES or light fuses probs for invertor controller LIGHT FUSES), low batteries or running on discharged batteries for a period of time can blow the fuses. Have the motors been tested? Is the drive an AC and hyd a DC?
Sep 20, 2013 | Crown Walkie Pallet Truck Electric 6000 lb
Keep blowing fuse
Year make and model, and which circuit does the fuse protect ?
May 16, 2013 | Cars & Trucks
Rheem water heater rtg95dvn keeps blowing 3 amp fuses
Not for sure what your root cause was and I know it's a little late but I just suffered this same exact scenario on the same water heater. Storms came through, power went out, power came back on and the water heater keeps blowing the 3 amp fuses now. I removed all the cables and plugged them back in one at a time. When I plugged in the Fan Motor connector the fuses blew. Installed new fuses with the connector out, the Fan Motor was putting out 150 VDC through the connector port (on main control). I pulled the control from the unit and Q1 is visible blown and disintegrated on the control board. Obvious control design issue. I've ordered a new control and will put a surge protector on the heater now when the new control comes in. Very disappointed that this was not caught in controls testing within the manufacturers facility. New control is not very cheap. Half the cost of a new Heater. Hopefully the Fan Motor survived the high voltage with the fuses blowing. I'm putting this here for anyone else that suffers the same issue on this water heater or the Richmond equivalents as they use the same control.
Jul 31, 2012 | Rheem Tankless Hot Water Heater...
Radio, ignition coil, antitheft and climate control fuses keep blowing
try looking for a short in the wiring harness and do they run to the same fuse
Feb 16, 2012 | 2000 Ford Expedition
CB keeps blowing fuses
There are a few common reasons the fuse keeps blowing:
1. The transmitter final transistor is bad, it usually is directly connected to the 12v source and not switched by the power switch.
2. The power wires were accidentally reversed I.E. positive to ground, neg to 12v. There is a protection diode on the circuit board that did its job and is now shorted. it will keep blowing fuses until its replaced.
Dec 30, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Maytag Atlantis MAV6451 Top Load Washer Logo
249 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
