Question about HP OfficeJet V40 All-In-One InkJet Printer
Error message: Open door, clear carriage jam and then press enter
When I open the door, the carriage does not move to the left where I can see it or try to reinsert the ink cartridge. There is no paper jam. I tried unplugging it, opening the rear door, tried everything I know!
Please let me know how your tech support works.
Thank you,
Amy Hotard-Gadani
Cell (714) 791-7728
  • 1 more comment
  • Anonymous Feb 18, 2009
    my printer wont work
  • Anonymous May 01, 2009
    I can't get the carriage to move at all.
  • rrobins62 May 18, 2009
    my officejet v40 has the same problem. 'open door and clear carriage jam. nothing appear to be jam or stopping movement of the carriage. the ink cartrige appear to be lock down. i can move the carriage to the far right or left manually. if the carriage is to the far left and i push enter, it sounds like it trying to move but don't, if it is at the far right and i push the enter buttom, it moves 1/2" to the left with each enter command. the problem started right in the middle of a print job. any more suggestions.
    Thank You,
    Robert
    Guru:
  • 859 Answers
Our support works this way. You will receive an email notifying you that there has been a reply to your post, such as this. You read the post, enter your comments in the Comment Text Area Below and you'll get another email when there is another reply.
I will ask you to do one thing, await your response and then give you further instructions.
First of all, with the printer on, and leaving it on, open the cover to the print carriage area. Now, reach over to the right under the cover of the printer and pull the ink carriage to the center.
You will want to use a flashlight to examine the area around the carriage bar for an obstruction. Common items are pencils, pens, paper clips. Additionally, the ink cartridges themselves may not be firmly locked down in place. You may notice this when you reach under and over to grab a hold of them and drag them over to the center.
Should you be able to get this carriage over to the center, check that the cartridges are lock down and nothing is lying in their path on the far right hand side. A flashlight will help you.
Regards,
Worldvet
Posted on Nov 03, 2008
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Printer Problem
Unplug the printer.
Move the carriage back to the home position, all the way right.
Plug back in the printer.
Apr 21, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer Logo
1,245 people viewed this question
Ben Johnson
