Question about Epson Stylus C60 InkJet Printer
Printer I have a new ink. it needs to be reset
  • Epson Master
  • 4,338 Answers
Download and follow the instructions on this SCC Epson Service Utility link:
http://inkjetprinterhelp.us/epsonSSC.html
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 03, 2008
Wat tank full mp 520
Hi Guy,
I believe that what you mean is 'Waste Ink Tank Is Full' error on Canon MP520.
To fix this problem, first you need to reset waste ink counter of the printer then you should replace the ink absorber with new one.
In order to reset waster ink counter properly, you can read complete procedure how to reset waste ink counter of the printer below:
How To Reset Waste Ink Counter Canon MP520 Multi Function Printer
May 07, 2014 | Canon MP520 All-In-One InkJet Photo...
What do I need to do when I install new ink cartridges to get the printer to stop showing that the ink is low or out ?
You will need to reset the software in most cases as the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Jul 21, 2011 | Canon PIXMA MP470 All-in-One Printer
Ive refilled ink cartridge and put it back in printer but the printer is still indicating empty cartridge and wont print. How do I reset the firmware on printer so it accepts cartridge as new?
Often times it is the chip in the cartidge that needs resetting - depending on the brand, there are various tools needed to reset - sometimes needing a new chip. Printer manufactures have gotten stingy with ink and want people to buy genuine new cartidges. The best advice I can give you is try to get to an ink refill shop and see if they can reset the chip in the cartridge.
Mar 15, 2011 | Office Equipment & Supplies
New ink cartage says needs replacing eimartin46@att.net
1. Remove the ink cartridge from the printer and reset the ink count. 2. Insert it again. 3. If it does not work, do a full reset of the printer. If it still does not work, there may be a problem with the electronics in the printer and may need to be replaced.
Feb 28, 2011 | Office Equipment & Supplies
My printer is running through ink really fast with not a lot of use 3 cartridges in one month. Each time I replace it with a new one it still reads low on ink. Any ideas what might be wrong?
This printer does not actually read the ink levels. It reads the documents getting sent to the printer and estimates the amount of ink used. You can buy a little scanner that resets the code on your cartridge to read as if it is brand new. This will allow you to use ALL of the ink in the cartridge before having to go buy more. This is a ploy to buy more ridiculously expensive ink than you actually need. Keep resetting it until your prints come out missing ink. Then you know you actually need a new ink cartridge. You can get this scanner on eBay or at your local electronics store.
Nov 23, 2009 | Canon PIXMA MX310 All-In-One Printer
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
New black cartridge installed. Won't print. HELP please.
Try
Important
Note
New cartridges won't install.
unplug your printer. then remove the cartridges and reinstall them being sure to seat each one firmly into it's socket. finally plug the printer back in.
Aug 17, 2009 | Epson Stylus NX400 InkJet Printer
Ink shows empty when toner is not even close to empty
there is one thing that if you refill the cartriage and then use again then still ink indicator shows low ink as its' ckt is designed so.
there is no problem you can print easily.
your printer will show correct ink level when you put in new cartriage.
but remember one thing that if your printer stops printing and shows message on computer that no ink in cartriage ,, then you need to reset printer counter, (this resetting process is present in your printer manual)
so no problem in printing, it shows low ink because the circuit inside it is designed soo.
so that you purchase new cartriage.
(remember : you need to reset the counter , refer to manual)
Jul 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
Epson Stylus C60 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
