Question about HTC S620 Smartphone
Dropped in water and won't start????
My friend dropped his S620 in the sink and he gave it to me to try and help hi get it fixed but i can't even get it to turn on, i've been reading about a reset button that i could try but i cant find it, can anyone help??
  • 113 Answers
in this case don ever try to turn on the phone in this case and the circut will  get jammed. dismandle for the water to get dry. this solution might sound funny but  it will work, bury in the phone in the rice ,as it has nature absorb water , may be bury it atleast an hours time.try with hair dryer to dry the water content and while blowing air keep in distance and try as the hot air will jam the circuit again
Posted on Nov 03, 2008
Zip brush won't spin and I can't figure out how to fix
did you check to make sure theres no clog in the hose since its powered by air?
Aug 09, 2011 | Kirby G4 Bagged Upright Vacuum
My asus k40in laptop cpu fan turns on only when it wants to. it doesnt help much in controlling the temperature. how can i turn it on continuosly like other laptops do.
hi my name is rui it does happen a lot i suggest that you buy a external cooling system for your loptop try it. well i got a friend thats pc is on 24hrs w/a cooling system helps alot even if the internal fan is not working.,
Jul 21, 2011 | ASUS K40IN Notebook
The water is not draining from machine, although the pump is obviously trying. It doesn't sound quite right. Kind of a growling noise. It can pump water into tubs when experimenting with ideas, but can't...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 13, 2010 | Bosch 24 in. SMU40 Built-in Dishwasher
Our R-04 under sink water holding tank, for our culligan water filtration system got drained, and the pressure is now gone and it won't fill up on it's own. We had a leak, fixed it, but now need help...
The RO tank will still fill up even without any pressure it just won't push any water out. If the RO tank lost pressure and it is a sealed tank, it should be replaced. The bladder is bad.
A 3 gallon tank should have 7psi pre-charge pressure, 10 gallon 10psi. There must not be any water in tank to set the pre-charge pressure.
If the RO tank is not filling up then there is another problem.
RJ
Jan 26, 2010 | Culligan Under Sink Water Filter
I dropped my ipod touch in the sink and it now it doesn't work
to fix this, you're going to need your ipod, a plastic zip-lock bag, and uncooked rice. first, open the bag and fill it halfway with uncooked rice. then put your ipod in the middle of it all. then zip the bag and let it sit for about a day. the rice should have absorbed all the water by then. most of the times, this will work. but sometimes, the ipod is damaged beyond repair by the water. good luck
hope this helps ;-)
Apr 04, 2009 | Apple iPod touch
I need internet and mms settings for htc s620
Hi...
Why don't you call or sms the customer-service of your provider?
they will send you an sms with the settings for the phone.
friendly greetings, Gilbert.
Mar 10, 2009 | HTC S620 Smartphone
Dropped camcorder in sink full of water
http://www.fixya.com/support/r3771170-phone_water_damage
Nov 20, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Kenmore ultra wash
This could be due to lime deposits from your water or very hard water. If you fill a glass from the sink is it real cloudy? Also it could be due to low pressure from being clogged or if you have galvanized pipes they may be clogging up and causing low water pressure which is not rinsing off the dishes with enough water. To test the water pressure in your house turn one sink on and then turn the other one on. If there is a large drop in pressure this means your pipes may be starting to clog up. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 24, 2008 | Dishwashers
SCRATCHED STAINLESS STEEL SINK
Have you tried a really fine steel wool? I don't know if this would work. I have stainless steel farmhouse sink, front exposed all stainless steel. My contractor scratched it up horribly when he was putting it into the kichen. he fixed it amazingly with a fine steel wool pad. I don't know if your scratch is too deep for that but it couldn't hurt. The scratches on our sink were surface but very noticeable. Hope this helps.
Feb 08, 2008 | Kitchen Ranges
S620 Software Problem
You might need to flash the ROM and start over again..
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/i_BuN68vclM&hl=en\"></param><param name=\"wmode\" value=\"transparent\"></param><embed src=\"http://www.youtube.com/v/i_BuN68vclM&hl=en\" type=\"application/x-shockwave-flash\" wmode=\"transparent\" width=\"425\" height=\"355\"></embed></object>
there is a guide how to flash from tmobile to s620 on there you will see links to and how to do this.. you don" t have tmobile dash version but the s620 version.. this will give you a step by step guide on doing this regardless if you have the tmobile dash version.. just follow the promps..
Dec 17, 2007 | HTC S620 Smartphone
HTC S620 Smartphone Logo
124 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
