Question about Motorola Mobility RAZR V3
Phone freezes at random times, pull battery to restart
V3 will freeze at random intervals ranging from a few seconds to several hours. I have to pull the battery & reseat it to get the phone back on. Checked battery contacts and swapped batteries; neither helped. I can turn it on and set it down and it will freeze or it will stay on while I carry it around. Leaving it open or closed makes no difference. Any options other than replacing it?
  • Larry Fosdick Oct 01, 2006
    Bought a new V3 at a Cingular store. Old phone stayed on overnight, though without the SIM card, it could not call. I took the SIM card out of the new phone and put it back in the old phone, and it has worked normally for >24 hours. The only change was that the SIM card was removed and replaced a day later. Could a piece of dust or something gotten in and made for intermittent contacts in the SIM, causing the freeze problem?
  • 62 Answers
Your old phone may have just needed a new sim card, as for if your new is not working use the warranty and send it back and replace it.
Posted on Apr 25, 2008
Zte warp freezes and shuts off when on the phone and in sleep mode
1.Power off the phone.
2.Press and hold Vol+ key and Power key simultaneously for about 10 seconds until the some option appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.
3.Use Vol+ key and Vol- key to move the cursor to "wipe cache partition" and press camera key to confirm it.
4.After 5 seconds, the cursor will be on "reboot system now" again and press camera key to confirm it. The phone will reboot automatically.
All your personal informations will be deleted
Jan 14, 2013 | ZTE Warp
Why does my Dell Inspiron 530 freezes up after being on for a few hours?
Check your battery status. It is possibly overheating whitin time and causing malfunction.
Oct 25, 2012 | Dell Inspiron 530 Desktop Computer
Freezes almost everyday .wont even turn off.always have to let battery run out then restart next day
When the computer freezes, you can remove the battery physically instead of having to wait the few hours for it to run down. Underneath the laptop are two tabs holding the battery in, just release them and pull it out.
Are you using the machine on a soft surface (bed, couch?) that would allow it to overheat and malfunction when it freezes? Are you overloading the CPU with too many overbearing programs? Perhaps you've got a virus?
You'll need to be more specific about what you are doing when the freezing occurs. This could be anything ranging from software to hardware faults.
May 11, 2011 | Acer Aspire One PC Notebook
Refrigerator freezer problem. Kenmore Elite bottom freezer refrigerator, model # 795.75546401, manufactured 9/2004 (LG is actual manufacturer). The Express Freeze LED turns on and 2 "beep"...
Press and hold FRZ TEMP button and REF TEMP button at the same time for 3 seconds.And see if that makes any difference in the problem. ---------- If the problem is same then try the manual reset procedure.In manual reset the unit has to be unplugged from power outlet for 24 hours.Then empty both the fridge and freezer section completely.Then after 24 hours.Clean the melted ice water from the inner parts.Then reconnect the power cord of the unit to power outlet.Set the temperature to normal settings.It will take near to 4 hours for your unit to run its regular cooling cycle.Once this is done then check,if the same problem is seen.-----------This will help.Thanks.Helpmech.
Dec 20, 2010 | Kitchen Ranges
Touche screen is freezed, I restarted it , remove the battery ...but no results , ...i updated the software using nokia software updater (just today)...it worked but later on after few hours , it freezed...
Hi, when a phone screen randomly freezes, it means that the phones memory is faulty or when an application you downloaded has virus.
What to do is this,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Sep 03, 2010 | Nokia N97 Cell Phone
Xbox 360 Freezing during netflix and dvd playback
If you are using a HDMI connection, often the connection will be lost between your xbox and your tv. In my case I simply change to another channel or the other HDMI channel and then back and the secure HDMI connection will be restored.
Aug 05, 2009 | Microsoft Xbox 360 Console
Samsung blackjack on at&t set-up It keeps freezing on the at&t screen. I have pulled the battery and restarted still does not work any thoughts
My BJII does this from time to time. Sometimes I've had to pull the battery and restart several times, but eventually it will boot up. Some people suggest pulling the battery and leaving it out for 45 minutes so the phone will reset. I just do it for a minute or two. If you've tried multiple battery pulls and left the battery out for a long time and it still freezes, you'll probably need to do a hard reset--press the "up" (top) part of the D pad and power on. Note that you'll totally reset your phone like this, so all your customizations will be gone, but at least the phone should work.
Jun 21, 2009 | Samsung Blackjack SGH-I607 Smartphone
Phone freezes up, restarts randomly, and is very slow.
Hello sg2134,
I too use the Sony Ericson Z750a. If the phone freezes up or it does not respond to the button presses, then switch off the mobile and switch it on again. If the problem persists, you can remove the battery and and the sim and put it back again. Then you will find the mobile to be normal again.
Nov 01, 2008 | Sony Ericsson Z750a Cellular Phone
Motorola Mobility RAZR V3 Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
