Question about JVC RX-6008V Receiver
JVC RX-6008v faceplate
I am trying to locate a new faceplate for my RX-6008v. The old face cracked while moving, and it causes receiver to not operate at all. The face will light up for one sec then dim out. I took it apart and it is the only thing found broken with thorough inspection. Please let me know if you have one. Thanks, Cameron
have a jvc home theater with this next problem, when I turn the display lights up then see the name overload and shuts down the display, and it does not connect the speakers
Posted on Aug 13, 2010
How can i Reset JVC KDR 335 ?
The reset for this unit should located right behind faceplate. Press bottom left button to release face and you should notice circular hole on the unit itself behind faceplate
Jul 30, 2014 | JVC Car Audio & Video
Connecting to samsung smart tv
For digital connections on your TV ( unknown model) read on page 7
[PDF] RX-6000VBK / RX-6008VBK INSTRUCTIONS AUDIO/VIDEO - JVC
Sep 30, 2012 | JVC RX-6008V Receiver
JVC KW-NX 7000, the spring loaded latch for the detachable face is broken so the face plate will not stay on therefore I cannot use my unit. Can I buy a new latch for this and if so where or do I have to...
If you still need help on the display faceplate, check this guy on ebay, he has all the jvc parts, I bought my faceplate touch screen from him, his user id is genecyrus on ebay NAU0005-001X
Oct 18, 2010 | JVC KW-NX7000 Car GPS Receiver
Have JVC 6008V A/V Receiver. No out-put from left-front speaker out terminals. Checked fuses, and all are good. R/F, and all other speaker out functions work fine.Switched speakers to make sure problem was...
make sure you're using the corresponding speaker inputs for speaker 1 (only) and turn off Speaker 2 on the bottom left corner near the headphone jack (it should be sticking out further then the speaker 1 button). hope this helps.
Aug 06, 2010 | JVC RX-6008V Receiver
Can i plug in my i-pod and listen to it?
All you need is either a dock, which will keep the I-Pod powered up, or a 3.5mm plug to two RCA phono leads, which will also be needed for the dock, this plugs into your headphone socket of your I-Pod and the two RCA's into an aux socket on the JVC. You can then listen to it in Dolby Pro-Logic. You won't be able to listen in Dolby Digital, unless the I-Pod has Dolby Digital output, which will require a different lead.
Of course the sound source (music) would have to be recorded with Dolby Surround, to get the full benefit, but many are, they just don't say in the imformation given.
Mar 09, 2010 | JVC RX-6008V Receiver
The screen says overload
disconnect all your speakers and if it still does it, the unit is bad. if not, then youve got a bad speaker. connect them 1 at a time til you find it. good luck
Feb 10, 2010 | JVC RX-6008V Receiver
Overload comes on after start up
disconnect all speakers to see if 'overload' goes away.if it goes away then you might have a bad speaker.If OVERLOAD is still there with no speakers connected .Then audio output circuit needs repair in unit..
Jul 30, 2009 | JVC RX-6008V Receiver
Reciever Problem
hi, its definetly an internal problem, commonly in the output section, usually its a capacitor or an transistor which is leaky or short. which causes the overload, so u will need a techinical hand to get it resolved.
Feb 12, 2008 | Audio Players & Recorders
JVC RX-6008V Receiver Logo
222 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
