Question about PC Chips (M925G) Motherboard
My processor is 3.0ghz is not detected and i have also 2.6ghz processor is not detected, how can i overclock this.
    President:
  • 2,692 Answers
Download a manual to see how to overclock the BIOS software for your motherboard.  You will need to know you CPU socket number, then model number.
http://www.pcchips.com.tw/PCCWebSite/Support/Category_Support.aspx?MenuID=3&LanID=2
Posted on Jan 07, 2009
How to overclock a i5 Quad Core Processor i5-4670 (3.4GHz) 6MB Cache
The Intel i5-4670 is not designed to be overclocked. A different model - i5-4670k - is designed for overclocking.
You should find that the standard model chip works just fine for you at regular clocking - for music production.
Nov 24, 2013 | Computers & Internet
Is it possible to over clock amd phenom 8600b 2.30ghz triple core processor
Yes, every processor can be overclocked, but be very careful when overclocking processors. The increased heat can damage a processor and shorten it's life significantly. Ensure your processor does not get too hot during the oveclocking procedure. All overclocking should be done in small increments. The X3 8600 can be oveclocked to close to 2.7GHz safely with air cooling.
The best overclock is always through the motherboard. Depending on your BIOS you can raise the Front Side Bus (in small increments) in order to bump up the total frequency. If you have an unclocked processor, you can try to raise the multiplier. After every increase, you should stress test your computer using PRIME 95. If your computer locks up, drop down the clock speed and leave it there. Your computer should always be stable. You may have to raise the voltage of your processor to get to where you want. If you give the model of your motherboard, I can give you more detailed instructions.
Make sure you have CPU-Z (http://www.cpuid.com/softwares/cpu-z.html). - this will show you all the details of your processor. If you would like some more detail, check out this link:http://www.wikihow.com/Overclock-a-PC and feel free to message me. If you didn't understand some of the things in this post, I'd recommend not overclocking your PC - it can be dangerous and ruin your computer if you don't know what you are doing. Alex
Apr 09, 2011 | AMD HD860BWCJ3BGH Phenom X3 8600 OEM...
Overclocking with p5sd2-vm motherboard.
i have no install the sound driver please help to the install...............
Jul 27, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
How to overclock Intel Pentium Dual Core E2140 1.6 GHz processor
The following link will tell you the very simple way to overclock this processor. Half way down the page you will find the header "OVERCLOCKING"
http://www.value-reviews.com/index.php?page=pentium-dual-core-e2140
"Since the architecture was designed for the 1066 MHz FSB, overclocking is as trivial as setting the FSB to 1066 MHz (266 MHz quad pumped).
...you instantly get a 2132 MHz CPU with little increase in temperature."
Dec 06, 2009 | Intel Computers & Internet
I have a intel dg31pr motherboard with e7200 processor.i want to overclock it.plz help me............
Overclocking is something you should only do if you are fairly experienced with computers. Most motherboards that overclock are made for overclocking as are the processors used. Good overclocking requires a balance of increased FSB, multiplier, increased voltage to the ram and sometimes the processor as well, and excellent cooling. It is easy to burn out your system by overclocking. There are many things you should know first. For that reasion alone it is impossible for me to tell you how to overclock it.
But, go to www.extremeoverclocking.com. This is a site made for people who want to overclock. Read and browse through the forums. You will also find some excellent by the numbers guides there. Sigh up and jump in. When you perform your first overclock, come back and tell me. I've been overclocking since 2002.
Sirwriter
Nov 05, 2009 | Intel DG31PR Motherboard
Problem in overclocking my Processor.
1: You problem is your power supply, PSU. When you try to give more power to your CPU by overclocking it, it doesn't have enough wattage, or power, to get the CD drive, or your sound card to work. This is why the CD drive works again when the CPU isn't overclocked. So, in this case, to overclock your CPU, you would have to get more power to your system by getting a more powerful PSU, or one with more wattage. How much you can overclock your processor depends on a variety of different things. Your RAM, PSU, HDD, CD drive, etc. I would not go past about 3.4ghz with your processor, however, a "max overclock" is hard to determine.
2: The maximum temp for your processor is 70C, 158F. I would try to keep your temperatures under 60C to ensure your processor doesn't "die early" on you. The multiplier cannot be changed, only the FSB can be changed. You should be able to create a "profile" in bios and set it to your default so that it loads up automatically when you boot up. Make sure you find a stable configuration before you make a default profile.
Mar 30, 2009 | Intel Computers & Internet
What is the best?
Hi!
Thats not easy to tell....its all about money. But i will recomend you 3 verry good cpu:s that is not to expensive and worth the money.
1: Intel Core 2 Duo E6850 3,0GHz Box
2: Intel Core 2 Duo E8500 3,16GHz Box
3: Intel Core 2 Quad Q8300 2,5GHz Box
All of them are boxed, that means that you dont need to buy a separate fan
Nic
Mar 12, 2009 | Intel Core Duo T2600, 2.16 GHz Core Duo...
Need 2 install the fastest PIII processor possible on CpxJ650GT
you obviously seem to have the adequate knolledge so why dont you overclock it...
overclocking used to be a touchy subject but know its undrstood that that it creates no problems..the chips are designed to be overclocked,in fact overclocked should now not be the trerminology for it ...it was called overclocking cos then it wasnt natural and created unstable systems ..now it is merely enhancing .
Jan 24, 2009 | Computers & Internet
Overclocking
are you sure that your pc is built for overclocking? dont be risky it might get you trouble on your pc. i suggest that you shouldnt overclocking it and besides your processor is high ed.
CHARCOIS
Aug 24, 2008 | Intel (P42000400256SK478) Pentium 4, 2 GHz...
Compatible processor
Yes, if you overclock you computer, I believe if you enter your bios of the motherboard, asus already has a pre overclock options. That is if your using a p4 2.8 ghz processor. You can not put a 3ghz processor and overclock it to a higher fsb, your motherboard will literally smoke up but, most motherboards probably can easily detect a non compatible CPU.
Sep 16, 2007 | ASUS P4GE-MX Motherboard
PC Chips (M925G) Motherboard Logo
123 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
