Pc display Whenever I reboot my pc display come in small than monitor and i reset display setting to 32 colors and change to full screen again .But when I finish working and again start pc same small screen come 8 bit color and hardware found message come whenever I start my PC
  • 51 Answers
This maybe due to lack of Video Card/Monitor drivers or the resolution is set to a small size. You will have to find out which video card you have, and if you have an LCD sometimes they come with drivers (Samsung LCDs have drivers). To find out what video card you have, you can usually go off the model name and number of your computer and get the drivers from your manufacturer's website. If it is a home built computer, you will have to look at the card/motherboard model and serial numbers to figure out the video card they use. Normally XP has a default video driver and it should not do a miniature resolution, but it happens sometimes.
Posted on Nov 03, 2008
Whenever I go into full screen it just shows me a black screen and my mouse. I can hear the sound of the video. The setting that I am using is 800 x 600 pixels. 32 bit.
Your setting is too low to accomodate the colors of a video. You need to change your resolution to 1024 min. Right click on the desktop with your mouse away from the ICON's and choose properties. Change the display settings to a higher number and save your choice. Then try the video in full screen mode again and advise if this solves your problem?
Sep 27, 2010 | Dell UltraSharp 1908FP Monitor
1) I have a Toshiba Pro 600 model ps600c-01qw4. The problem of this laptop is that when i turn the computer on the screen is very small. So I went into the display setting and fix the problem. But when i...
Check the monitor in the device manager. NOT regular display properties. Make sure the monitor is the correct type. Try different settings in device manager for the monitor. Maybe try uninstalling the video card drivers, reboot and reinstall the drivers. Let me know if this does not work.
Joe
May 17, 2010 | Computers & Internet
My computer begins to load windows, then after the screen with the windows logo and bars goes away my screen goes black.
Nine times out of ten if that's when your display stops, it's simply because your display settings are set to something that your monitor can't handle. Depending on what it's not supporting, some monitors respond by going black ... others just go "crazy" displaying unintelligible gibberish.
If that's the problem, it's fairly easy to fix.
First things first ... let's get you a bootable system.
Boot in safe mode - press F8 when the Windows loader presents you with the 30 second list of choices, and then select "Safe Mode" as your boot option.
Right click on the desktop and click Properties, and then on the Settings tab.
Now click and drag the Screen Resolution slider to the far left ... you want the smallest settings that your screen will support. Typically that'll be 640x480, or 800x600.
Also change the Color Quality dropdown to 256 colors, or whatever is lowest. (You probably don't need to go as low as 16 colors, if that's presented as an option.)
Now, click on the Advanced button, and then the Monitor tab of the resulting dialog box. Change the Screen refresh rate to 60 Hertz.
OK your way back out, and reboot your machine. If these setting were the source of the problem, it should now be able to boot normally. You may not like the screen settings, but at least you now have a place to start.
"Start experimenting with the settings to see what does, and does not, work with your monitor."
If the display is still blank or gibberish, the my recommendation is to once again boot into Safe Mode, possibly Safe Mode with networking, and update your video display drivers. It's likely that they are incorrect or otherwise broken. Now start experimenting with the settings to see what does, and does not, work with your monitor.
I tend to start with the screen resolution. Once again right click on the desktop and click Properties, then Settings, and then drag the Screen Resolution slider a notch or two to the right to increase your display resolution. Now click Apply. It should change the resolution and display a small message box asking if you want to accept this setting. If you don't respond within some time, it assumes you can't see it, so it resets to the previous setting. If the screen goes blank or you can't read it, wait at least one minute before doing anything. The problem may resolve itself, and you'll be able to say "well, that resolution doesn't work", and move on to try another.
If, after a full minute or more the screen remains blank or unreadable, you'll have to reboot into safe mode, as we did originally, to restore your setting. (Why might this happen? Windows "remembers" and doesn't bother to ask you if you reset to something that you previously said worked. If you mistakenly said "this works" when it didn't ... perhaps by random keyboarding while the display was blank ... well, that could be how we got here in the first place.) You can repeat this process of trial and error for each of the screen resolution, the color depth and the screen refresh rate. (For CRT displays, you really do want the refresh rate to be as high as your monitor supports.)
Nov 28, 2009 | Dell Latitude D800 Notebook
Unable to change color depth...
Ok I think i found your problem. You don't need to install any drivers.
Switch your display to 256 colors To switch your display to 256 colors
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don't, follow the steps below if you want to switch the display temporarily while the game or program is running.
  1. On your desktop or on the Start menu, right-click the game or other program that you want to run in 256 colors, and then click Properties.
  2. Click the Compatibility tab.
  3. Select the Run in 256 colors check box.
  • The screen will revert to your default color quality when you close the program.
  • Try switching to 256 colors if your software program shows the wrong color or the graphics redraw slowly.
  • If your software program appears in a small window in the center of your screen, you can increase its size by changing your screen resolution temporarily. Follow the procedure above, but in step 3 select the Run in 640x480 screen resolution check box. Your screen resolution will revert to its previous resolution when you close the program.
  • The Compatibility tab is available only for programs or games located on your computer's hard disk. It is not available if the program is stored on a floppy disk, compact disk, or a network.
Please rate this if it fix your issue
May 30, 2009 | eMachines W3611 PC Desktop
Display problem in windows xp
Make sure the drivers for both monitors are installed. Update the driver for your graphics card. Hopefully this will fix your problem. Good luck.
Dec 22, 2008 | Microsoft Windows XP Home Edition
Window xp display
This should be your graphics card driver is not it. The original installation of hardware drivers may be better.
If that is not what system you set up the software in question. Can be re-systems.
http://www.notebooks-driver.com
Nov 03, 2008 | Computers & Internet
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Screen colors
possibly screen color depth is set to 16 colors. - open control panel display - settings tab, slide the color depth to 16 bit. - change resolution to 800 x 600 for now. reboot and see if that does the trick, then readjust settings to your tastes.
Aug 26, 2007 | Compaq CV 7500 17" CRT Monitor
Screen resolution resets to 800x600 after every reboot when d/port is connected.
You may have to set the monitors resolution to match the pc as they may be different.
Jan 13, 2007 | Dell Latitude D620 Notebook
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
