Question about Pioneer ECS P4VMM2 V3.2A P4(478)/FSB 533/VIA/SDRM+DDR/A&V&L/MATX Motherboard (MBEP4VMM22)
Comp doesnt boot after installing USB 2 drivers
I recently reinstalled my computer and it worked perfectly well except that it took too long to copy thing to it extremely long file transfers from my external hard disk and removeable drives took hours where it took minutes so i got the usb 2 drivers of the ECS website and installed them the comp hung up during the install so i hard booted the computer and then it showed a black screen after that whenever i tried to boot
i took out my hard disk to see if there was some life in it and it showed the post bios screen and said that it did something sucessful and showed that there was no boot device phew some progress then i connected my hard disk back again and now it stuck on the pre bios screen it just hangs there even if i try to enter the bios quickly it hangs on the bios screen now i donno what to do? it is definetly due to the driver i installed how do i solve this
please help
    President:
  • 2,351 Answers
Hi rogueonline,
Disconnect the external drive from the PC. (It's possible windows registry is messed up).
It sound like your windows system is a bit confused as well. First try resetting the bios. See page 9 in your manual. (Don't forget to set it back to normal). This should allow you to get back into the bios. Go over each setting & adjust as needed.
Make sure your primary hard disk drive is listed in the boot order. Advanced Setup Page 30, in manual. If your windows operating system seem is a bit off (OS not installed correctly or driver software not installed correctly). The over-all function of the system can & will run slow. If your primary drive seem to also run slow, the FAT or MBR can be slightly corrupt which will also slow the drive down including file transfer & eventually the drive will cease to function. (The drive can be repaired by doing a full format through windows).
Do a fresh install of windows, including the full format, (Not a Quick format) on the primary drive. Even though ECS does include the USB 2.0 driver so does windows update service. If your windows was all ready updated & you re-installed ECS's (2003) USB driver, that may have been enough to screw up windows. If you have data on your current drive & need to get that data off & if you have access to another system you can pull your drive & slave it into another system & remove the data. There is no quick fix. Play it safe. Start from scratch. After windows has been installed & you install the ECS driver software, update windows until there are no updates left. I'm sure your system will regain its speed.
Link to ECS web site for P4VMM2 V3.2A .
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Driver&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
Good luck ogueonline!
Mike
Posted on Nov 03, 2008
I hav got a cyberview mp4 player from singapore.when i plug to my comp to copy songs from it , thrs a msg sayin tat us b device not recognized..i've tried restartin my comp nd even reinstalled my usb...
try connecting it to the other USB ports and install the driver. It can help sometimes. if it is not working even when you reinstall the driver the device might be dead.
Mar 05, 2011 | Audio Players & Recorders
Hi, my WNA3100 Wireless adapter does not work with windows 7, tried reinstalling the drivers and it still does not detect it, tried in my laptop wich has XP, works perfectly. How can I resolve this...
I did this and it worked for me.
*do not connect device to computer yet
**uninstall any previous versions of the software
1. run WNA 3100 v1.1.3.22 setup in normal mode, do not connect device when it asks you to
2. restart computer and boot up in safe mode (hold F8 after turning on comp before windows logo comes up)
3. once loaded in safe mode, connect wireless device, let windows install it
4. once done, start computer in normal mode
Jan 08, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
Hi, I got a free HP compaq desktop, the small ones, is 2.66hz it was working fine, but i don't have the password for the administrator in a xp pro, so I just reinstall a new copy of XP but now this...
please load xp again and press f 6 when you see it on the screen to load sata devices .
sata softwares and drivers are required in certain computers to load windows so while loading you will be asked to load those drivers through a floppydrive, so u must have
1)sata raid drivers (according to the hard ware installed in hp.)this piece of hard ware will not allow xp to boot if you dont give its drivers through a floppy drive(during installation and setup of windows.
so u must now have
1 floppy drive(usb)
2 a floppy disk with sata drivers
3)usb port to attach the usb floppy drive
after loading xp you will see xp running trouble free.
a easy solution is to load vists and the drivers are already there in vista cd.
Sep 19, 2009 | Computers & Internet
My Canon LiDE 50 worked perfectly on my copy of windows vista. I recently downgraded to xp (upgraded imho). Now the drivers wont install and windows still sees it as an unknown machine.
Are the drivers installed for windows xp, and what service pack do u have.First uninstall the drivers and reinstall them (make sure u select windows xp) and make sure it is xp compatable (vista drivers are not backwards compatable in most cases)
if this is a usb device (most likley usb 2.0) goto my computer right click select properties then select hardware then device magager check to make sure there are no yellow question marks, scroll down click on usb and make sure there are no problems here. then u can go to cannon's web site and download latest drivers and any fixes they may have
Sep 02, 2009 | Canon CanoScan® LiDE 50 Flatbed Scanner
Transfering files from comp to comp with usb...stuck...help
take the hard drive out of the old computer and put it in the working one as a slave. you will be able to drag and drop all the files you need.
Jun 18, 2009 | Gateway 310 Series (158920) PC Desktop
My comp. doesnt recognize my premier mp4
The computer recongize it as a removable disk.
plug in your mp4 player
click start
click computers
click removable disk
formate the disk
copy and paste you songs.
Dec 23, 2008 | Premier MP4 Digital Media Player
Usb ports doesnt work anymore
hi!good am...hope this wil help...
have you tried checking the driver for that device?go to to start>control panel>system>device>usb controllers.you will see if there's a problem regarding the connection of your usb...try reinstalling the cd driver that comes with the mobo...
Feb 09, 2008 | MSI PM8M-V Motherboard
Pioneer ECS P4VMM2 V3.2A P4(478)/FSB 533/VIA/SDRM+DDR/A&V&L/MATX Motherboard (MBEP4VMM22) Logo
216 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
