Load Paper first showed paper jam drawer 2 took paper out checked for paper found no jam pushed check mark and it initalized then started showing "load paper" i have loaded and unloaded and changed paper still same
  • 4,338 Answers
Do this: Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-On
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 03, 2008
Canon ir3300 showing paper jam in 2nd tray but thre is no paper jam in it
i m using canon ir3300 , showing paper jam at left side , but i checked there is no any paper, although there is showing jam. what to do.
Jul 17, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Copier keeps telling us there is paper jam, we have looked where screen shows jam and find nothing. We have taken out the paper tray, still don't find even a tiny scrap of paper anywhere.
There are several possibilities. After you inspect for the Jam and close the drawer, does the copier come to ready? Have you checked the behind the doors on the right side. If the copier comes to ready and you press the start button does the copier jam right away. If so check the dial on the paper drawer and be sure its set to the right size paper. If its not the copier will jam, right away. It is important with a Canon to check all areas and open both the paper drawer and the right side doors when checking for jam, if the right sequence is not followed in checking for jams the jam may not clear. If still Jammed you might take some canned air open the right side door and blow out the paper feed area, a sensor may be blocked or dusty. If all else fails turn the machine off and un-plug it from the wall, let it set a few minutes and plug it in and try it again.
May 20, 2010 | Canon imageRUNNER 2000 Copier
We keep getting paper jam after paper jam (at least 7x's now) The jams seem to be toward the bottom where we take the paper drawer out. We do push the green release button and pull out the paper. We have...
hi did u have cheq all the paper path sensors may be any one of them stucked or may be if you have old machine may you have clean whole paper path sensors thanks
May 12, 2010 | Sharp FO-4400 Fax
False Jam at exit on a Toshiba DP3580 copier
make sure your drawer size shows 11x17 on display if not push user interface button then select the drawer and set it to 11x17
Jul 04, 2017 | Toshiba DP2570 Printer
Shows paper Jam on Canon 720 PC photo copier
Sounds funny but this model shows a jam when the exposure lite goes bad. Turn on the copier and watch the exposure lamp, should lite up and not flicker. Lamp is still available.
Nov 16, 2009 | Office Equipment & Supplies
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
SF2030...post transfer, flat jam ... symptom occurs between 1-15 copies ... not consistant ... in addition when theexit switch is activated during the copy cycle, a jam is not indicated #!@?
FYI... The copier will show a jam for 3 reasons. 1 Paper never got to the sensor, 2 Sensor sees paper there all the time or 3 Paper doesn't arrive at the right time. Alot of times paper feed rollers are dirty or worn, often ignored and overlooked, and these will give intermittant jams that show up anywhere in the paper path, often looking like a differant problem. Sometimes sensors are dirty with paper dust and will show a jam when there isn't one, in which case a can of compressed air is good to blow them out. Question, is this jamming out of all drawers and bypass or just one drawer. This would help in eliminating possibilities. Good luck, let me know if you have more questions. Please rate this. Thanks
Jul 01, 2009 | Sharp Office Equipment & Supplies
Paper
If the paper size tab inside the drawer is out of position, even by 1/8 inch, you will have this problem. Also, the drawer itself could have a flaky/broken paper indicator switch (shows how much paper is left). I have had both these issues. On the first, I just slid the adjuster back in to letter position. The second, however, took replacing the drawer.
Nov 18, 2008 | Brother HL 5140 Laser Printer
43 people viewed this question
jasbo
jasbo
