Question about Frigidaire Dryers
Frigidare gas dryer model crgf342as
Dryer runs but won't heat up.unpluged burner and re pluged it and it worked for a few minutes than stopped again. what could cause it? the pamplet said there are two fuses that could cause it but could'nt find them .do you know where they are located?
  • bigbobhughes Nov 06, 2008
    ordered the new coils. hope it works. Thanks
    President:
  • Frigidaire Master
  • 2,651 Answers
Fuses(thermostats) will totally stop the glow bar from energizing, if your glow bar glows i would look in a good gas supply and second the coiols located atop of the regulator assy themselves ight be bad, part number 279834. $20 bucks for the coils worth a try.
Posted on Nov 03, 2008
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
Jul 08, 2012 | Dryers
When I turn on the dryer, it takes a few minutes before the burner ignites, and will only heat for about 5 minutes then the burner shuts down.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 02, 2010 | Whirlpool Dryers
THE BURNER COMES ON AND THEN THE BURNER SHUTS DOWN AFTER A FEW MINUTES. TIMER WORKS FINE, SPINS WITH NO PROBLEM AND HAS BEEN COMPLETELY CLEANED OF LINT.
heatman101
Jul 02, 2010 | Whirlpool LGR8648PG Gas Dryer
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes...
Gas Dryer not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
heatman101
May 06, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Feb 04, 2010 | Dryers
When I start my dryer, I have heat at first, but it shuts off after a short time for the rest if the cycle.
It sounds like you have a gas dryer . The coils on the burner valve need to be replaced . They get hot from the electricity going thru them , and one opens (shorts ) until the dryer cools down . It should then heat again for a few minuted , then stop heating but still run . Your timer will not advance either , if set on auto , unless dryer heats . Without the model number , cannot give you the part number , so take it with you to get the part . It comes with both coils in a pkg .
Oct 11, 2009 | Whirlpool Dryers
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
LG Gas dryer will not keep heating
sounds like the heat sensor on side of heater pan is bad and needs to be replaced ,,, its mounted on side of pan the flame blows into and has 2 wires plugged onto it / larry
Dec 12, 2008 | LG DLG5932W Gas Dryer
Gas dryer tumbles but no heat
Depending on the model, you may have a gas vale problem. The ignitor is working but gas is not being allowed to flow to the burner. It could also be one of the temp sensors or the control board for the system. Try unplugging the dryer and then replugging it back in after a few minutes.. If that fails to work after that.. provide brand and model so we can provide more detailed assistance...
Regards
Oct 11, 2008 | Dryers
Dryers Logo
111 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
