Question about Mitsubishi WS-55857 55" Rear Projection Television
Power but no picture or sound
Have had this tv for about 6 years now with no problems. Had work done on my house and didn't have tv on for about 6 months. Lots of dust from contractor so I covered tv with plastic to prevent dust getting in. Once turned tv back on, worked fine for about 2 wks. Then, all of a sudden, it turned on and immediately turned off. Was advised by a service tech to unplug it off for about 24 hours and then try it again. After 24 hrs, it turned back on (and it will turn off), but no picture or sound. I assume there are some capacitor or other issues and that I will need to have it serviced. My questions are: 1) what is are the likely parts that will need to be replaced and 2)could dust could have initiated this problem? Any suggestions would be appreciated.
    Problem Solver:
  • 9 Answers
The problem is the circut board that leads into the tv from the power cord i had problem with that ,had tech come out and replaced the circut board the cost $350 , $200 for the labor i payed $54 for that tv and it was a steal cuz it was under the warranty
Posted on Mar 26, 2008
I recently just experianced the exact same thing. I had a service tech come out and he told me that one of the tubes leaked. It destroyed one of the boards and he said that you can not get the tubes anymore. So I guess I just throw this awesome tv away.
Posted on Oct 13, 2006
    Sergeant:
  • 337 Answers
Is hard to tell if the set is going to need parts or not,maybe not,since you protected the set from dust is not likely the cause of the problem,after a while the units develop loose conections because of the heat dissipation some components have and the solder conections become loose.Be safe and seek assistance if you are not too familiar with tv service.
Posted on Sep 27, 2006
SOURCE:
Power on, no picture, no sound
more than likely you have a faulty main board, common problem with Vizio's. There is a slight possibility the power supply is at fault. I would recommend you get a diagnosis to be sure.
Apr 07, 2013 | Vizio VP422 42 in. Plasma TV
No picture, no sound, but TV will power up
Average life on all brands and models is 3 to 5 years. Average repair on this size and type of set varies but is usually from 150 to 250 parts and labor. I see very few sets of this type (any brand) that are more than 6 years old.
The bulk of sets in our shop (over a hundred sets on average) that have failed are under 2 years of age.
Dec 20, 2012 | Toshiba Regza 42RV535U 42 in. LCD HDTV
Luxor tv no picture or sound
Connect the TV to another power outlet that you are sure, works. Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
Kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Mar 31, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KV40XBR800
YOU MAY HAVE A BAD IC 2504 OR M BOARD EST $250.00-450.00
Sep 05, 2008 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Philips HDTV does not turn on
I would check the line coil and horizontal and low voltage regulator transistors.
Jan 21, 2008 | Philips 60PP9202 60" Rear Projection...
look for imperfect contacts on the inside main board.
Jan 21, 2008 | JVC AV-27230 27" TV
Sound and picture distorted only on lower channels
Bad tuner.......they are electronically divided in sections called
bandwidths, i.e. 2-6 , 7-13 so-on.........T.
Give accurate model # / service # for RCA part #............
Nov 06, 2007 | RCA F32450 32" TV
Shrunken picture
HI!
can you take a picture to your tv to see exactly what happen to your vertical problem!? then you can post here thanks!
Nov 02, 2007 | Proscan PS56670 56" Rear Projection...
Open Questions:
Mitsubishi WS-55857 55" Rear Projection Television Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
