Question about HP Photosmart C7280 Laser Printer
Shutting down is running across my screen
Was copying when I realized I forgot the othe 1/2 sheet to be copied, so I quickly opened the lid and put it. It stopped everything and when I pressed copy & pressed the black button to start, it didn't do anything, pressed cancel nothing. So, I thought I would shut the printer down and would cancel every thing and I could start over. That didn't work, now this has been running across my screen for several days. What do I do to get running again?
  • fmossing Nov 03, 2008
    It worked, I'm not sure the way it should have, but I'm up and running.
    The lights didn't shut off when I pressed the Off button, so I just continuesd with the remaining steps and it worked. After, a screen read that I should not unpug the all-in-One until I shut if off, but it wouldn't shut off.
    Also, the power cord I unplugged from the All-in-one was actually the Power Adapter cord, it was one and same cord, should it have been?
    Thanks!
  • HP Master
  • 4,338 Answers
Do This: Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 03, 2008
  • JDTec
    JDTec Nov 03, 2008
    Great!!!!
How do you copy and paste one excel spreadsheet to another making sure the headers are lined up correctly.
right-click the sheet you want to copy, select "copy to", then either select the position within the current document, select annother document (needs to be open in the same excel instance) or select "new document". check the box "copy" to copy, leave unchecked to move.
Jan 01, 2016 | Microsoft Excel Computers & Internet
Copying or scanning from books
Check in you scanner settings there should be the single sheet feeding setting check that is not selected
Jul 24, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
When making copies, only a part of the document prints; the rest is solid black.
Solid black in a copy typically means that the scanner is partially blocked. Open the top, where you'd place a sheet to be copied, and examine the small strip that runs down the side (left, most likely). See if it's clear, or if something is covering part of it.
Most copiers don't use the full size scanning plate for copies, but use a strip that scans the paper as it moves across it. If something blocks part of it, you get the black area.
Apr 12, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
My AR-163 copier is bringing out half copy, it will copy and leave the down part uncoppied, how do i solve that problem
Half copy is never an issue with the toner. If you leave the lid open and make a skyshot copy what does it look like, is the copy all black with a thin white border around it, and do you see the scanner light comming on all the way across? You will want to make sure that your developer is evenly distributed across the magnetic roller. Also try looking into the score tron and check the drum cleaning blade and drum.
Oct 11, 2014 | Sharp AR-163 All-In-One Laser Printer
I have a lexmark 2600 all in one machine. How do I scan more than 1 page at a time?
This photocopier can only copy 1 page at a time. This is due to only being able to place one sheet on the viewing surface per scan.
To make a scan follow these instructions:
  1. Open lid and put the document or photo face down
  2. Close the lid to press the document flat and avoid dark edges
  3. Have the printer connected to the computer and both turned on
  4. Press the scan icon on the printer
  5. Follow onscreen instructions
  6. Repeat for each document needing to be scanned
Sep 14, 2011 | Lexmark X7350 All-In-One Printer
Hi, I have an HP4250, it is printing a faint part down one side of the page. I have changed the toner and fuser and it still does it, can anyone help.
Since you have changed the toner then the most likely cause is dirty laser optics. To properly clean the optics, quite a bit of disassembly is required. You may want to ask a local repair company for an estimate to clean the optics. Should be around $75
Good Luck and Thank You using Fixya.
May 21, 2010 | HP LaserJet 4250dtn Printer
When we send fax or copy it comes out black , can recieve faxes and print off fine .? hplaser jet 3050
Scanner's lamp damage
Try to open the lid on where we copy sheets of this paper hold down the sensor and press the copy button, see if the scanner lamp light, lamp power can be interrupted
Oct 27, 2009 | HP LaserJet 3050 All-In-One Printer
Dell 1600n Will only print with sheet feeder open
Rollers may be worn out and not properly grabbing paper or a gear may be broken. You should be able to inspect by lifting cover to feeder and watching as paper is pulled through.
Dec 04, 2007 | Dell 1600n All-In-One Laser Printer
Excel Sort Across Sheets
Hi Raymond, I have a solution for you. Asuming your 'main' sheet is Sheet1. On Sheet2, in the same line as your data on sheet1 (i.e. A5 on sheet1 is JIM), then on A5 on sheet2, enter a link ( the = ) and enter. copy this formula down. Do the same with Sheet3 linking to Sheet1. When you sort Sheet1, Sheet 2 and 3 will follow. Hope this helps. Regards DeltaC
Sep 11, 2007 | Microsoft Office Standard for PC
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
HP Photosmart C7280 Laser Printer Logo
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
