Question about Protron PLTV3250 32 in. LCD Television
POWER PROBLEMS I AM NOT GETTING NO POWER TO MY T.V. NO LITES ,NO NOISE, NOTHING? Ok...Im watching TV and the TV suddenly goes off. No lights, sound, black screen....dish box and vcr still working. I unplug everything, test to see if the outlet is bad but vcr/dish box works in the outlet. No matter what I plug the TV into, it doesnt work now. I just got done paying for this thing. Dont have a good feeling about this. Can anyone help?
  • 1 more comment
  • ugadawgzac Nov 09, 2008
    What a coincidence!!! My TV just went down as well. I'm going to try opening up the area around the power supply to check the fuse and see if any of the capacitors are distended. I'll be back to let you know what I find.
  • merentes Nov 22, 2008
    I have the same problem! It gets off suddenly
  • Anonymous Dec 30, 2008
    no power to tv ,dvd player and dish box works on this plug.
    protron 32lcd
I have a 32 lcd tv and it did the same. Their is a part in the power board that is overheating and makes the power board blow fuses. were pretty sure this will fix alot of whats wrong with these. the part needs to upgrded to a bigger part so it does not over heat as easy. I have orderd new part and hope that it will be up by 11/29/08 from what i can tell the cost of part is about 1.49 so tell your freinds don't discard so fast. Please contact me at jmiller@dspn.com if i can help.
Posted on Nov 25, 2008
T.V. DOSEN'T WORK AT NO MATTER WHERE I PLUG IN THE HOUSE.
Posted on Nov 20, 2008
How to fix my lcd tv and magic remote?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 29, 2015 | LG 47LW6500 47 3D LCD TV
My hannspree tv screen goes black blank
If the picture shows a picture briefly upon power up then goes off after a few seconds, you have a back light fault. It could have a problem in the 24vdc circuit, failing back light inverter board, or a blown CCFL lamp.
Dec 05, 2012 | Televison & Video
Lost sound on tv suddenly
Just check whether the mute button on remote is jammed. Then if that is ok, check whether you can listen to the sound on a Head Phone connected to the TV. Even if it works, the TV needs attention by a qualified service technician.
Jul 14, 2012 | Samsung PN50A550 50 in. Plasma TV
Why does my vizio lcd 47 in tv just suddenly turn off. I will be watching tv and suddenly it just goes off. The vizio power light then blinks steady for about 1 min and then the tv starts up again, as if...
Good day!
Please follow this procedure to fix your problem:
  1. Open the cover of your TV.Remove all screws at the back.
  2. Next,power ON the TV and check the output voltage of power supply using voltmeter.
  3. It should have not less than 5vdc for system board,12vdc for sounds and 24vdc for inverter board.If the 3 supplies are got a voltage drop your power supply had problem.For example if you check the 5vdc then the reading is 4.50vdc only.
  4. If you have voltage drop,check some leak/bulge on top capacitor on power supply.replace it by using soldering iron and soldering pump.
  5. When the power supply looks like OK,no voltage drop and no leak/bulge on top capacitor.The problem is your system board or main board.There's no easy remedy for that.You have to replace the whole system board.
I hope this solution helps you to fix your problem.Thank you and good luck.
Jun 13, 2011 | Vizio VO47L 47 in. LCD TV
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Black screen
Sound like you have problem in two major.
1. Check the if there any short component in the primary and secondery side of the power supply.
2. If the component are ok in the power supply.Check in the deflection area.
Good luck.
Dec 06, 2007 | JVC AV-48WP30 48" Rear Projection...
TV shutdowned while watching and it wont power up again..
just replace your Lamp. Thats it
best regards
Circuitcity
Aug 25, 2007 | Sony KDF-E55A20 55 in. LCD Television
Samsung TXM3296HF problem - tv won't turn on
your flyback transformer could be your problem or in the video circuit.have a tech look at your tv for possible repairs.good luck.
Apr 01, 2007 | Samsung TXM3296HF 32" TV
Protron PLTV3250 32 in. LCD Television Logo
71 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
