Question about Whirlpool Refrigerators
Roper referigerator model RT18akxkq00 stopped cooling but internal fan for frezzer is blowing
5 Suggested Answers
odiegh
  • 81 Answers
SOURCE: DRAIN PIPE
usually no you can look on the companies website for more detailed specs is there a specific reason for asking?
Posted on Dec 01, 2008
RepairClinic
  • 32 Answers
SOURCE: Whirlpool model#ed25texhw03 will not keep cool
This could be a problem with the compressor.
When a compressor won't start and “clicks,” this indicates it (the compressor) is locked up and cannot start so it clicks off on an overload thermal (temperature) protector. If the compressor only runs for a short time then clicks off it is likely drawing too much amperage, overheating and cutting off on the overload protector. Nothing other than replacement can be done with a compressor that is locked up or drawing too much amperage as it is a problem with the internal components of the compressor.
It is absolutely crucial that the condenser coils are clean and the condenser fan motor, if there is one, operates properly or the compressor will overheat and go off on the overload protector. This handy condenser brush makes cleaning your refrigerator condenser coils a snap.
The compressor can be replaced but this is very expensive ($400- $500 parts & labor) due to the fact that the refrigerant needs to be reclaimed from the system and the compressor refrigerant lines unsoldered, new lines soldered on and new refrigerant charged into the system. This is something only a trained and licensed repair person can do. Compressors are part of the "sealed refrigerant system", many manufacturers warranty the components of this system for an extended period of time, usually 5 years from the purchase date.
Go here for: Whirlpool-Refrigerator-Parts
RepairClinic.com
appliance parts, help & more
Posted on May 08, 2009
aasc
  • 1606 Answers
SOURCE: ge fridge makes a clicking noise fan in frezzer
Main control board bad . The board controls the fan opperation and the clicking , sounds like a relay on the board . Replacing the board should solve the problem(s) .
Posted on Aug 06, 2009
heatman101
  • 43501 Answers
SOURCE: Roper model # RT18DKXFW01 not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fgjfd
Posted on Sep 29, 2010
MY REFERIGERATOR TURNS ON BUT DOESN'T COOL
if it is a fros free check fan in the frezzer that is what cools the frige
Sep 12, 2012 | Danby DFF9102W Mid-Size Refrigerator White
Roper referigerator not cooling (ice bound) model RT14HDXDW03C
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 12, 2011 | Refrigerators
It was working but stopped blowing cold air.
There is a concealed fan that serves to distribute the cooled air between the two cabinets and 'stir' it to avoid cold spots and that fan isn't running currently.
Go to the link below and enter your full model number to see if Sears has an illustrated breakdown of your Roper. This will show you where the fan is located and you can then decide if you want to DIY or call a pro.
Sears parts dept.
Jun 16, 2011 | Roper RS25AEXLQ Side by Side Refrigerator
Not getting cold any where. Fan in frezzer runs, Fan blowing on comp. works, turned defrost time no help there. Had stater on comp. checked was told it was ok. What's next?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jun 08, 2011 | Roper RT14DKX Top Freezer Refrigerator
I have a Ropper Referigerator model # RT18bkxkoo. I am facing following issues: 1. The freezer section is working but I have noticed some ice developed at the back wall. 2. The referigerator section...
were
werw
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
dfg
Dec 27, 2010 | Roper Refrigerators
Freezer works fine,refrierator not cold.
Check to see if the fan is running in the frezzer side. This is called the evaperator fan and it blows the cold air from your evaperator to the ref side to cool it. If this is not running then your ref will not be cooling at all.
Jul 29, 2009 | Refrigerators
Fridge quit working but freezer works
check to see if the back wall of the fridge is full of ice
if so that is an automatic defrost problem or check to see if your frezzer fan is blowing
Apr 17, 2009 | Refrigerators
Kitchen Aid side by side referigerator KSSC42QMSO
the freezer does all the cooling for both sides a few shelves down in the fridge on the left hand side there is an air intake make sure nothing is blocking it also listen for the freezer fan to run if its not look at the coils in the bottom of the freezer to see if they are heavly frosted in the fridge side at the top left side should be some vents hold your hand there to see if air is blowing through if not reply to me well go from there
Nov 29, 2007 | KitchenAid KSRP22FNSS Side by Side...
New Sanyo Fridge not working
I have the sam eproblem but my freezer is very cool, but the fridge wont get cold, it is just chilled, my food still goes bad and the water and soda is room tem..this doesnt make sense!
Nov 25, 2007 | Sanyo SR-1030W Top Freezer Refrigerator
Refrigerators Logo
66 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
