Question about DHD NTX-2008 Car Audio Amplifier
DHD AMP how do i wire my 15" kicker to my DHD NTX-2008 4 channel amp?
  • magana6009 Nov 03, 2008
    every time my subwoofer hits my amp shuts off.
  • 631 Answers
How do you have it wired now?
Impedance of each voice coil?
Number of voice coils per speaker?
Posted on Nov 03, 2008
I have the xterminator 2000d amp and I am wanting to wire two 12s and one 15 to the one amp. Both Kicker speakers are 4 Ohm SVC. Am I able to do this safely?
Wire the two kickers in Parallel, this will half the resistance of 8 ohms to 4 ohms and match the 15" speaker on the other channel.
Jul 07, 2016 | DHD US Amps Xterminator XT-2000D
100 watt dhd amp wont turn on
If it's an aftermarket stereo, there's a small blue wire (accessory/antenna) that goes to the amp. So in essence, you have the large cable going to the battery that powers the amp. However, the small power wire going into the amp tells it when to turn on, by the stereo.
Mar 09, 2010 | DHD NTX-2004 Car Audio Amplifier
Amp light flicking off and on
that could be a few things i had that same problem check all ur wires make sure u have a good ground that was my problem
Jun 27, 2009 | DHD NTX-2008 Car Audio Amplifier
Ok . i have a pair of crossfire subwoofers, @
Your amplifier is 4 channel... and only 2 ohm stereo capable.
You will get the most power putting 1 subwoofer wired in parallel on each BRIDGED channel.
This will give you a 2 ohm stereo load.
Both + on 1 subwoofer to + terminal on amplifier bridged channel 1
Both - on 1 subwoofer to - terminal on amplifier bridged channel 1
Both + on 1 subwoofer to + terminal on amplifier bridged channel 2
Both - on 1 subwoofer to - terminal on amplifier bridged channel 2
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | DHD NTX-3102 Car Audio Amplifier
Help me with my system
More information is required to start solving your problem. (ie. your make and model of "1500W amp", the voicecoil configuration of the kicker and Audiobahn 15's, and why you want to encorprate 2 crossovers in your system)
Seems as If you have a system without a plan.
Head unit?
More info necessary to give you the best use of your components.
Jan 14, 2009 | KEF Audio PSW 2150 Speaker
2 DHD NTX-6812 car subwoofers
First you'll need to buy a good quality amp wiring kit. For the torture your battery receives, get a power cap. The higher the farad the better off. And as for sound quality use really good RCA's and speaker wire. Try to keep the amp as close to subs as possible, and speaker wire a the necessary length. Not to long. Be sure to have a good ground.
Dec 03, 2008 | DHD NTX-6812 Car Subwoofer
Dhd ntx 2009
With two 4 ohm svc subs and a 4ch amp the best way to hook it up is as you have described. There is no way of wiring it to get a lower ohm with your set up.
Aug 28, 2007 | DHD NTX-2009 Car Audio Amplifier
Amp has 3 modes on it ,as a switch,what is this,it has a 2,3,4 channel mode,i have the gold dhd 1000watt x4 channel
first thing 1000@4 means 250w per ch. which means150w usable power.the mode switch is only to reduce rca cables,use 2ch mode if only 1 pair rca available,60hz is a bit low for this amp,90 would work better.
Aug 21, 2007 | DHD NTX-2009 Car Audio Amplifier
DHD NTX-2008 Car Audio Amplifier Logo
300 people viewed this question
Top DHD Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Tygh Duval
Tygh Duval
Are you a DHD Car Audio and Video Expert? Answer questions, earn points and help others
