Question about Dell Inspiron 6000 Notebook
Labtop not charging
I have this dell inspiron 6000 that the battery won't charge or turn the pc on to use but the light is lit on the charger plx help
Dell inspiron won`t charge the battery.New dell battery,new 19.5
volt adapter
Posted on Dec 08, 2009
  • Dell Master
  • 998 Answers
Try removing the battery and see if the laptop powers on. If it still doesn’t power on then either the motherboard is defective or the AC adaptor may have a broken wire in the cable.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 04, 2008
.dell inspiron shuts off before boot. when charger is connected it periodically flashes once on charging light. battery is good and is charged
Hello, The hard drive operating software or the hard drive is bad. You will have to try using the recovery cd to reload the software.
May 15, 2014 | Dell Inspiron 6000 Notebook
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
My Inspiron 6000 won't charge the battery.
According to your problem, this may occurs for either the battery of your laptop or the charger is faulty. First check electric outlet where you have plugged your laptop charger is OK. Then check the power cord. If everything OK then you have to change the battery.
Jun 10, 2011 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 won't charge
Since you have already replaced the battery and the laptop works with the AC charger, then probably the charge circuit in the system board (mother board) is bad. I have rarely seen an AC charger that will power the laptop but not charge the battery. 99% of the time, if it is not the battery, it is the system board.
May 05, 2010 | Dell Inspiron 6000 Notebook
MY DELL INSPIRON 6000 DOES NOT SEEMS TO WORK WITH OUT THE BATTERY CHARGER PLUG IN AT ALL TIMES, MEANING IF YOU TAKE THE BATTERY CHARGER OUT THE COMPUTER DIES.
Either battery is not taking charge or battery charger is not charging the battery. You can take to a local PC repair center and have the battery tested. If it is battery, you can find OEM replacements online from companies that do nothing but batteries and typically beat manufacturer part prices.
Oct 19, 2009 | Dell Inspiron 6000 Notebook
I have a Dell inspiron 6000 battery problem
try to remove the battery out from ur laptop then clean its terminals from any corrosion (By scratching it using a screw or something like that) then after 5 min. try to install it back again then connect the laptop to the charger hope it works
Jul 22, 2009 | Dell Inspiron 6000 Notebook
Battery alarm flashing orange on dell dell inspiron 6000
flashing because it is very low.
If you charge-it and still flashing it seems to have o problem with battery, charger or even the laptop. Try to test the charger and laptop with another battery and see where is the problem.
Jul 18, 2009 | Dell Inspiron 6000 Notebook
6000 crashing
sounds like your motherboard fried
Sep 06, 2008 | Dell Inspiron 6000 Notebook
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
Dell Inspiron 6000 Notebook Logo
252 people viewed this question
Alun Cox
