Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
No wireless connection
My 2wire wireless adapter all of a suddent stopped working and now it the computer can not locat the network. tried restarting the pc, hittinghte repair button on the screen, removing the connection and reactivating it. Any ideas would be great
  • sansebastian Dec 15, 2008
    The 2 lights are always on. Lost the signal 100% erased the icon from my network place?
  • 113 Answers
Try 2 disconnect and reconnect the adapter, turn off the router and power it back again,set the wirless channel to 9 r 11 it will work
Posted on Nov 03, 2008
I use 2Wire router and usb adapter. I switched
you dont need to install the driver for the 2wire, you just need to configure the computer to look for the 2wire, if unable to locate the 2wire from your computer, there is a problem on your 2wire it self
Jun 13, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
Wants a network key # to activate
Sounds like windows has thrown a wobbly regarding your wireless network connection. Go into network connections and double click on wireless network adapter. Click on wireless network tab at top of box then highlight your wireless network and click on remove. Restart your computer then let windows find the network again. Click on connect then input your wireless key again. This should refresh the connection completely. If you need more help let me know
Jun 09, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Want guests to be able to use our AT&T U-Verse broadband network.
Try checking your wireless security settings to make sure you are using the correct wireless key (password).
Apr 13, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Keep getting disconnected
someone continue to stop my wireless connection from his own pc
Apr 06, 2009 | 2wire (1000-100016-002) Wireless Adapter
Can't access 2wire network using netgear adapter
I was also having trouble with my Netgear wireless n USB adapter connecting to my new at@t 2WIRE gateway. The problem was that the netgear software wouldn't allow my computer to stay connected to my 2WIRE gateway and the software wouldn't allow Windows when restarting my computer. I have Windows XP and after hours with at@t support there was no resolution and they gave me Netgear's suport number to call 1-888-638-4327. After 10 min. the problem was fixed. They had me click start icon at bottom left corner then all programs, then highlight "start up" and if you see anything like netgear adapter or netgear start up wizard right click on it and click delete. That was it! rebooted my computer and it connected automatically!!! I'm not very computer knowledgable but I hope this helped
Feb 02, 2009 | 2wire (1000-100016-002) Wireless Adapter
Linksys wireless adapter not being recognized by 2wire wireless
1. uninstall the WLAN monitor from add/remove programs.
2. restart computer. it should say "found new hardware" (for the WMP54GS)
3. insert the installation CD for the WMP54G, but make sure that you do not install the WLAN monitor. just install the drivers for the card.
Then let windows control the wireless.
Dec 13, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
2Wire 802.11g USB Wireless Adapter driver in qwest
try getting the drivers from
http://support.2wire.com/index.php?page=download
Dec 09, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Try using the Ethernet (network) cable instead of the USB connection.
Hope this helps!
Jan 29, 2008 | 2wire 802.11b+ Wireless Ethernet Client...
2Wire USB 802.11g adaptor on XP: drops wireless periodically
when you get your computer connected, set the wireless channel to 6 and disable wireless zero configuration that will stablize your connection
Dec 03, 2007 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
117 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
