Question about Acer Aspire 5600 Series 5630-6951 Laptop
How do i connect my acer 5315 laptop to my tv i have a 4 pin s vhs socket on my tv but a 7 pin on the laptop
  • Acer Master
  • 4,338 Answers
I had previously researched this and found that unless you have a custom cable made ,there isn't one available. The best way it to buy a PC to Video Component for $64.99 , item # G126-1020 from Global Computers @ www.globalcomputer.com. They also have other devices including wireless units.
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 03, 2008
Acer Aspire 5315 charging circut fuse
So you have removed the battery from this laptop for at least 30secs - 1minute? Not really sure about a laptop fuse? Test your DC jack for continuity - with a volt meter - outside prong and inside stem. Those will be the first few steps to finding your issue.
Troubleshooting Laptop Adapter and DC Jack
Jun 02, 2014 | Acer Aspire 5315 Notebook
How to connect acer aspire 5315 to LG led tv
Acer Aspire 5315 doesn't come with an HDMI port. So, you have the following options:
1. Use a VGA Cable to connect the PC to TV if the TV has PC-Input facility
2. Use an S-Video cable to the TV's S-Video-in port if the TV has it
3. Use and S-Video to HDMI converter if the TV has HDMI port
(http://www.amazon.com/Composite-S-video-Audio-HDMI-Converter/dp/B003NS0UUQ)
for audio, you can use 3.5mm to RCA (Red/White) connector to connect to TV's audio-in port.
Apr 15, 2013 | Acer Aspire 3680 Laptop
Hi Guy's I have an Acer Aspire 5315 laptop and a 32" Bush flatscreen TV. What cable do I need to connect the 2 to watch movies etc Cheers
Use a 15-pin, male-to-male VGA cable to connect your laptop to your TV. male-to-male means the pins are sticking out on both ends. Since both ends are male, you'll need to find the female VGA input on your laptop and on your TV. This is often called the PC input. Now, connect one end into the TV and one end into the PC. On a Mac, the VGA input is conveniently labeled with a "display" icon. It's recommended that you do this with everything powered off.
Sep 27, 2010 | Acer Aspire 5315 15.4-inch Notebook PC
Why would the plug melt on an Acer 5315?
Plugs melt when the connections 'short circuit'.
This means the positive and negative energy paths are touching.
Even the smallest AAA or 9V battery will get really warm if your connect the terminals together, and the power supply of a laptop computer pushes more more power (amps) than a little battery.
If it is indeed the power connection of your laptop has some melting damage, I must recommend you have your laptop and its power supply serviced or replaced, and to not plug it into the wall until you do. Fires have started by malfunctioning/damaged cameras and computers.
I hope that helps.
Aug 21, 2010 | Acer Aspire 5315 Notebook
No audio when connecting Aspire 5315-2326 to TV.
Use a cable out of the headphone jack with an adapter to the red and white (left and right) audio jacks of your TV.
May 16, 2010 | Acer Aspire 5315 15.4-inch Notebook PC
Trying to connect Acer One to TV
The 15 pin connector is for a computer type monitor and MOST TV's do not have that type input.
Some TV's have a "S" type input or some form of NTSC video (usually yellow jack) plus two jacks for stereo sound.
You would need a special convertor if you only have the 15 pin SVGA plug on the Acer.
Mar 31, 2010 | Acer Aspire One PC Notebook
I HAVE TRIED VARIOUS CABLE TO CONNECT MY ACER
Pls try a S-Video to S-Video cable. Power on TV, then PC.
pls send us your feedback if the above helps. Thanks!
Mar 05, 2010 | Acer Aspire 5520-5908 Notebook
My acer aspire 5315 doesnt charge properly.
I'm sorry to say that your initial fears are correct and the pin that the adapter connects to in the laptop is loose. This is a common problem with laptop's and can be easily dealt with.
Now I'm not going to tell you to open the laptop up and de-solder the adapter (unless you want me to).
Because this is a fiddly job and you have to order the correct adapter i recommend you take it to a reputable repair store and have them replace the adapter for you, don't let them tell you that you need a new motherboard as this is not the case at all, adapters can and do get regularly get fixed and is not that expensive.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
No S-VHS output signal?
once the cable is plugged in, press the fn (function) button and f5 I believe to switch display to the tv (it may be f6 or something else)
Apr 15, 2009 | Acer Extensa 5620 Notebook PC
Configuration to display video on TV using Acer Aspire 5052 laptop
just right click on an empty space on your desktop and you will get the options to clone or extend desktop.
Oct 09, 2007 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
