Question about Yahoo YHT-630 System
There was a problem signing into yahoo messenger please try again a little bit later
This is the messege when i signin in to yahoo messenger "There was a problem signing into yahoo messenger please try again a little bit later" I am using the yahoo messenger 8 version. from last 2 days i am facing this problem but i am able to signin in to yahoo mail and also yahoo web messenger. And previousy i used to use messenger 9 version but there are few bugs in 9 so uninstalled 9 and installed  8 version after installing 8 i am able to login but last few days i am not able to login into 8 verion messenger..... Please help me out from this...... Thankyou
Cheers sandy
  • 4 more comments
  • Toni_Page200 Nov 08, 2008
    When I try to log in, I get the following message:
    HTTP/1.1 417 Expectation Failed
  • Anonymous Nov 27, 2008
    i am signing to yahoo but
  • lucian_k2000 Dec 08, 2008
    there was a problem signing into yahoo messenger!!
    please try again a littlebit later
  • herrtag Feb 06, 2009
    This is the messege when i signin in to yahoo messenger "There was a problem signing into yahoo messenger please try again a little bit later"I am using the yahoo messenger 8 version. from last 2 days i am facing this problem but i am able to signin in to yahoo mail and also yahoo web messenger. And previousyi used to use messenger 9 version but there are few bugs in 9 so uninstalled 9 and installed 8 version after installing 8 i am able to login but last few days i am not able to login into8 verion messenger..... Please help me out from this...... Thankyou herrtag@yahoo.com
  • Anonymous Mar 18, 2009
    same problem as posted please help
  • aannddrreeii May 21, 2009
    There was a problem signing into yahoo messenger. wtf ?
Throw your laptop to the bathtub with water and let it dry for 5 minutes and make sure that you plug it right away then turn it on.
Posted on May 10, 2009
Dear all ,,,,, i faced this problem from quite a while and i finally got a solution to this... actually nobody has an idea that why does this happen.
this is due to proxy settings of either of the 1
a) ur browser
b) ur messenger
c) ur connection
in my case it was with the connection
for changing the settings of internet explorer(because yahoo treats it as the default to pick up settings) go to internet options>connections>lan>automatically detect settings and uncheck all other boxes
for changing the settings of yahoo messenger click connection preferences and check no proxies
and the most important is the dial up connection proxy
when you go to internet options under the connections tab there are dial up networks shown and there are three tabs alongside these are 1)add 2)remove 3)settings ,,,click settings and under proxy server uncheck all and your problem will be solved
Do report your replies
Opinder Singh
Posted on Aug 11, 2010
    Sergeant:
    Champion:
  • 298 Answers
I would try uninstall messenger 8 and then reinstall it. This happens all the time. Give that a shot and then let me know how it turns out. I have had to do this too a couple times after i had messenger 9.
Posted on Nov 08, 2008
4 Suggested Answers
SOURCE: Problem in Signing
i cant connect to yahoo messenger, when i put username & password it tells me that i have to change proxy settings. when i go to connection i can see that it has internet connection by dial up , as i have dsl, but it dont let me change it, it is gray where do i have to change this setting.
Posted on Jan 22, 2008
early1234
  • 871 Answers
SOURCE: PROBLEM SIGNING IN YAHOO MESSENGER
uninstall yahoo messenger from your computer
restart computer.
defrag drive,
delete temp files in temp folder:
start>run>%temp%...delete
start>run>temp...delete
start>run>prefetch...dlete
now try reinstalling YM. download the installer from majorgeeks.com
dont do the online install. this will work now
Posted on Mar 25, 2008
rockfixya
  • 679 Answers
SOURCE: please try again a little bit later (81003005)
hi,try the solution posted on this site:
http://stephenhaim.com/resources/yahoo-messenger-81003005-error
please give me a good rating if solution works for u.
Thanks for using FixYa.
Posted on Jan 05, 2009
There was a problem signing into yahoo messenger please try again a little bit later (81003005)
Make sure you spelled your password correctly. Make sure the caps is on of off depending on your password. Try closing out yahoo messenger and restarting the application. If that does not work reboot your machine. If that does not work uninstall your messenger then reinstall it. If that does not work contact yahoo for further assistance.
Feb 15, 2010 | Acer Computers & Internet
Hi i m having problem with my messenger. whenever i try to sign in it says " there was a problem signing into yahoo messenger please try again a little bit later". how can i fix this problem?
hi! please consider to reload YM software with respect to registry key clean concept (or) check with your id(s)/password correctness along with net speed
Jan 04, 2010 | Yahoo Messenger
There was a problem signing into yahoo...please try again later..it keeps saying this.what can i do please
Check your Internet connection properly that it's working...if internet connection is not getting any data from yahoo then this type of messege pop ups....or if you are banned from yahoo server it will say same....Good Luck
Oct 27, 2009 | Yahoo Messenger
There was a problem signing into Yahoo! Messenger. please try again a little bit later
just try reloading the yahoo messenger on the computer . try an older version first .
Oct 19, 2009 | Yahoo Messenger
Here at the time of signing in/ it is showing some error
are you able to login to your yahoo mail, check your id and password. If persists, contact yahoo technical support.
http://help.yahoo.com/l/us/yahoo/messenger/contactus/contactus-01.html
Feb 20, 2009 | Yahoo Messenger
Cannot sign in to my yahoo messenger ...
stop using it ,.. that program is horrible!
use live messenger or anything else.
Jan 15, 2009 | Yahoo Messenger
Please try again a little bit later (81003005)
Nov 22, 2008 | Yahoo YHT-630 System
There are a couple of options why this isn't working... 1) The messenger system may be down and you may have to try later 2) your network settings may have changed.
It sounds like #1.
Oct 08, 2008 | Computers & Internet
I cant signin in my yahoo messenger
I CANNOT CONTINUE ON USING YAHOO MESSENGER, ONCE I WAS LOGGED IN, ITS SAYS THAT ERROR CODE 81003005... HELP ME PLEASE....
Jun 20, 2008 | Yahoo YHT-630 System
Yahoo YHT-630 System Logo
3,843 people viewed this question
Top Yahoo Audio Players & Recorders Experts
Greg Ulan
micky dee
Kolbrun...
Are you a Yahoo Audio Player and Recorder Expert? Answer questions, earn points and help others
