Question about Haier BC112G Wine Cooler
Short maybe? My wine cooler seems to be continuously turning on and off. You can hear the fan running but the led lights blink constantly and it will not stay chilled, any suggestions?
  • ff_sharp Nov 03, 2008
    Thanks, I will check the ground. I have tried other outlets and it continues to do the same thing.
  • 120 Answers
Check voltage on outlet is grounded properly try another outlet
Posted on Nov 03, 2008
Whirlpool 22" wine refrigerator wwc287bls. Makes a high pitched sound pretty much constantly (compressor seems to run constantly too)
Howard, We're sorry to hear about your Wine Cooler making a high pitched noise. Our Wine Coolers are handled by a different department. Please call 800-263-2629 for assistance.
Jun 13, 2017 | Whirlpool Refrigerators
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
I have an oster wine cooler model #owo912H6H that was not cooling i took the back off and have a blinking red and green light and a fan that would **** and run a few turns and stop i cleaned the fan and it...
It seems this is either due to faulty fan or fan motor. This could be a reason that the wine cooler is not cooling at optimum rate. As i cannot see the cooler, this is what i could judge from the information you gave to me.
I would still say, it would be worth repair, if this is due to faulty fan or motor ( motor seems to be the main cause ).
The main tough thing would be to get fan motor. You could try to get a replacement motor or a compatible one from the parts store near your home and give a shot. More likely, you would be successful, if the fault is related to motor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 25, 2010 | Refrigerators
FR23SL Uses Peltier Cooling - No compressor nor freon....
Luzer - Thanks for the very helpful solution. My cooler has the problem described. When I take off the back and plug it back in, all three fans run, but the unit does not get cold. Is it possible that it needs new fans anyway (like maybe they are going but not moving enough air to generate the effect)? Or woudl it be something else?
Thanks!
Mar 25, 2010 | Emerson (025806803716) Wine Cooler
Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Jan 28, 2010 | Marvel 61WC Wine Cooler
Wine cooler does not get cool - fans do not run the light and temperature display do work
if you hear the compressor tun on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
Nov 12, 2009 | Oster 12-Bottle Wine Cellar - Black
I just bought a wine cooler not sure where to start to fix it. Fans will not turn on
Hi there.........i take it this is a used / second hand wine cooler......if so you've probably discovered why its been discarded........problem could b due to a faulty compressor unit....the fans are usually wired through the compressor...and run in conjunction with it........if the compressor isnt running then the fans are out .........if the comressor is running then check that there is nothing impeeding the fans rotation.....check for broken or damaged wiring.....check for tampering by someone else....check continuity of wiring through fan coils.........check for faulty starter unit on compressor
regarddss ir Galahad
Aug 12, 2009 | Haier BC112G Wine Cooler
My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Nov 15, 2008 | Haier HVT12ABS Compact Wine Cooler
Magic Chef wine cooler clicking
If I was abetting man - I would suspect that the fan is polarised, and has been wired incorrectly..
Check that there is nothing obvious in the way of the fan blades..
Aug 15, 2008 | Refrigerators
Haier BC112G Wine Cooler Logo
146 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
