Question about Pioneer DJm500 Professional DJ Mixer W/Effects System
Static out of 1 MASTER OUT & channel selector for effects is not working properly
When i switch effects to channel 3 sometimes it will do both channels. Also the Master out R channel will produce unbearable static at times. now more than not. amnyone know what i need to replace?>?? or how to fix it?
  • Colin Moses Apr 15, 2009
    like electrical cleaner or silicone type electronic spray?
  • 68 Answers
Umplug your system from the main electricity outlet and spray the knobs with connection spray. it think it is just just in there. good luck
Posted on Apr 08, 2007
SOURCE:
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Nov 10, 2016 | Nady Systems Music
Could you use the Bose 901 series VI for a pa system?
Actually that's where the bose 800 systems came from.
Old school jazz guys were using their 900 series turned backwards as a pa
Mar 31, 2017 | Music
Shooting in black and white --i don't know what is the problem --need help
1. Set the Power switch to CAMERA.
2. Set the Mode switch to TAPE. (VP-D353(i)/D354(i)/D355(i) only)
3. Press the MENU button.
4. Move the Menu selector to the left or right to select Camera, then press the Menu selector.
5. Move the Menu selector to the left or right to select Digital Effect, then press the Menu selector.
6. Move the Menu selector to the left or right to select the desired Digital Effect mode, then press the Menu selector.
7. To exit, press the MENU button.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 18, 2011 | Samsung SC-D353 Mini DV Digital Camcorder
Hi. my YAMAHA DSP-A1000, works well only the input selector does not to select. its all static noise and does not seem to lock onto an mode. i have to use the tape 2 monitor to hear music.
The INPUT SELECTOR is defective. Order part number VT148000; it costs $51.04. As of 14 Jan 2011, the part is on backorder until the later part of Feb 2011.
Register online to order the part yourself, or you can place your order by phone at the Yamaha Parts Department at (714) 522-9011 or (888) 892-6242, Monday - Friday, 7:30 am - 5:00 pm PDT.
https://www.yamaha24x7.com/yamahaoms/QuickOrder.aspx
I hope this post also clarifies the problem from the posts above.
IMPORTANT: After installing the new Input Selector switch, place the knob at 1230 position (between LD and DAT/Tape 1) BEFORE turning the unit ON. The Yamaha Tech said this procedure ensures the input source is properly programmed and aligned.
Lakay
Dec 12, 2010 | Yamaha DSP-A1000 5-Channel Amplifier
How to get the effects to work on the mixer
This is in general for Behringer mixers since you did NOT tell us a model number...
To use the effects you adjust the FX knob for EACH channel for the amount of the mic or input you want to send to effects from that channel. This is the "send" mix.
You dial in one of the effects based on the list near the effects selection window with the selector knob and the number will change and start flashing. You press down on the selection knob which will enter the new effects number and the number will be solid and not flashing.
Then there is a knob to select how much of the OUTPUT of the effects you want to go to the main and sometimes one for the amount to the monitors.
That is all there is to it. The effects can be gated by a foot switch input if you desire.
It is a good idea to include a model number as your thing is posted as if it is a PMP3000 mixer.
May 11, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Terrible static on left side of all channels
Hi...
Unplug all the inputs to the amp.
Does the problem go away?
If its only the left sometimes, it sounds like the speaker selector switch or source selector switch needs a good cleaning with some de-oxit and a small brush
Apr 27, 2009 | Audio Players & Recorders
I have a Yamaha Natural Sound Stereo Receiver RX-750 (purchased maybe around 1992-1993?). The input selector switch doesn't seem to be working properly. No matter which input I select, the sound is fuzzy...
Hi cfipp
You could fix this problem with a quick squirt of CRC 2-26 into the function selector switch connected to the knob you are wriggling. This will sort out the problem. If you need further advice, feel free to ask me. I will help you.
regards robotek
Mar 07, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Please explain the working of this code
It's a Java http server (webserver) that serves random "prices" if they match a search string.
Well here is an explaination:
private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};
These are search strings
private static Random rnd = new Random();
This generates a random number
private static Charset cs = Charset.forName("UTF-8");
This is the charset that the http server uses
ServerSocketChannel server = ServerSocketChannel.open();
Create a new server
server.socket().bind(new InetSocketAddress(8055));
Bind the http server to port 8055
The rest is handling the request and processing it
But here:
if(Arrays.binarySearch(symbols, symbol) >= 0)
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;
else
response = "Price not available";
channel.write(cs.encode("HTTP/1.0 200 OK "));
channel.write(cs.encode("Content-type: text/plain "));
channel.write(cs.encode(response));
channel.close();
It sees if the string input matchs: DELL INTC MSFT ORCL SUNW.
(private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};)
If so, it gives a price based on a random number.
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;)
Or else
It says "price not available"
then it gives a html header to end the error message.
Hope I helped you :)
Gook luck
Nov 26, 2008 | Computers & Internet
Yamaha DSP A-1000 input selector switch not working properly
i did not post that....and why would fixya be asking the poster of a problem for a solution?????
Bug? Pls delete these posts moderator.
ty
Mar 09, 2008 | Audio Players & Recorders
Connecting n64 using attenna cable
should be channel 3 or 4 and does it has a RF selector switch?
Aug 17, 2007 | Nintendo 64 Console
Pioneer DJm500 Professional DJ Mixer W/Effects System Logo
173 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
