Question about RCA P52929 52" Rear Projection Television
RCA P52929 I was just wondering if anyone out there can tell me how to get into the screen adjustment, you know all the small groups of squares. Had the green gun replaced, the repair guy adjusted it but I have moved it since and now every thing is out of whack again. Already tried with the remote and of course the service guys won't show you these little tricks. thanks Flattop
  • Bryan Marche May 08, 2008
    I already know how to do that adjustment I was looking for the screen that is all squares, you can adjust 9 squares at a time in any position on the screen not just the center. but thanks for the input
Go to the menu select the screen option 3 and then select option 6 . adjust projection tv. green is for green use it first then adjust the red and blue until the patterns on the tv screeen appear white.
Posted on May 06, 2008
My screen is bowed in picture. How do i adjust this on the projectors or is that the problem?
jbaker46360,
You have a convergence problem. See my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics for the explanation, how to fix it and where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Feb 18, 2011 | RCA P52929 52" Rear Projection Television
Hi I have an RCA TV Model# P52929 that is not turning on for me at all what so ever.
FBT flyback Transfomer 239111 Ck your hori output Transistor also. Call Mats Electronics for Parts 1-800-628-1118
Dec 21, 2009 | RCA P52929 52" Rear Projection Television
Remote Sensor
its s usually to the right or left of all the buttons (channel, volume, menu, etc) it might have a tinted plastic small square covering it, i take it your trying to program a universal remote
Mar 08, 2009 | RCA P52929 52" Rear Projection Television
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
Picture is warped. rca 52 inch model p52929
This is hte beginning of a convergence problem. If you can solder, try resoldering the pins on the convergence ICs. These are large black ICs attached to a heat sink and will be marked STKxxx. If that fails to resolve the problem, replace the ICs.
Keep us posted.
Dan
Aug 25, 2008 | RCA P52929 52" Rear Projection Television
Rca projection tv
MCM electronics 800-543-4330 $197.77 p/n 240793
Jan 25, 2008 | RCA P52937 52" Rear Projection Television
Blue ghosting
This could be a convergance problem, if there is such an adjustment described in the manual and it doesn't work, make sure the optics are clean.
Oct 06, 2007 | RCA P52929 52" Rear Projection Television
Alighning tv
i have an alinemenet problem with my rca tv P52929 i went to the book and it said to go to the menu and select 3 which is the screen menu then select option 6 which is the adjust projection tv. this is suppose to allow you to adjust the the tv's three colors. it says to select the green centering to adjust the green tube. blue for the blue and red for the red. it says to center the green first then adjust the red and blue tubes until the test pattern on the tv screen appears white. i hope this helps you. my problem is that the program is not in my tv. it has everything else but not the option 6 to adjust the tv. this may be your problem to. good luck.
Apr 15, 2007 | RCA P52929 52" Rear Projection Television
Convergence setup menu gone
No rest on this model other than unplugging to let it return to factory default. If your a tech .. Check R19722 and R19703 for open. Both 750 K. these open make the convergence menu to be gone.
Jul 13, 2006 | RCA P52929 52" Rear Projection Television
RCA P52929 52" Rear Projection Television Logo
85 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
