Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Motor locked up
Underneath all of the strainers and a small white plastic cover in the middle of the dishwaher is a blue impeller. It doesn't turn . I can get it to turn if I move it in or out or turn it, but it only works for a few revolutions. Is it something I can repair?
  • zebra6559 Nov 03, 2008
    Thanks for the help, I'll let you know how hard it was!
  • 42 Answers
Remove the front toe kick (two torx screws) on the left side is a plastic circulation water line it just pulls out for easy removal. remove you water valve by taking out the 2 torx screws. this just loosens it up so you can maneuver it around to take out drain pump . once you have done this you will see a locking tab on the pump ,pull it slightly and rotate the pump clockwise to remove it. do everything in reverse to replace with new .
Posted on Dec 21, 2008
    Sergeant:
    Champion:
  • 324 Answers
That is the drain pump.should be replaced as a assembly. tough job if you have never done one. The easiest way i seem to do that is with the dishwasher out from undernieth the counter.
Posted on Nov 03, 2008
  • ok let me know. if you have any other questions.
Replacing impeller
Remove the back cover of the motor to expose the plastic fan. Find the c clip that holds it on the motor shaft. Remove the nut that is on the front side of the impeller. I used a vise grips to hold the shaft from spinning on the side where the fan was. A small 2 or 3 arm puller hooked under the front shoulder of the impeller and that is all you need to do.
Feb 26, 2013 | Hobart AM14-253 Free-standing Dishwasher
Remove motar from whisper flo pump
Replacing your pool pump motor
Gather the following items.
Phillips and flat head screwdrivers
Circuit tester
Dry towel
Step One
First, make sure that the power to the pump is turned OFF. This means turning off the breaker at the panel box and not just the switch at the pump.
Step Two - Removing the motor assembly
Remove the four hex head bolts which hold the motor assembly to the pump/strainer housing (These bolts may not be visible).
Slide the motor assembly out of the pump/strainer housing, exposing the diffuser. Pull the diffuser of of the seal plate, exposing the impeller. (The diffuser may remain in the pump/strainer housing. To remove, pull it straight out of the strainer housing.)
There will be a gasket or O-ring sealing between the motor mounting bracket and the strainer housing. Inspect this thoroughly and replace if necessary. An economical option would be to purchase a Go-Kit which includes the pump shaft seal and all necessary o-rings, gaskets and lubricant for your pump.
Step Three
Now, you can lift up the motor with bracket attached to get to the wiring more easily. There may be a bare copper ground wire attached to the outside of the motor that you will need to disconnect. Remove the cover plate on the back of the motor to get access to the wiring. You should have one green wire that is the ground wire and two other wires that are your leads. The lead wires should be black and white but could be any other color except green. Disconnect these wires (they may be attached to a screw, held down by a nut, or clipped on with a terminal clip).
Step Four
Next, you will need to disconnect the conduit (sleeve covering wires between motor and switch or junction box). This usually means unscrewing the compression nut that is screwed on the adaptor which is screwed to the motor. After unscrewing the conduit compression nut, you can pull out the wires from the motor. If you wish to reuse the adaptor, unscrew it from the motor.
Step Five
Now you must remove the impeller from the motor. Remove the volute covering the impeller if it is there. (Some are screwed on). You will need to go to the opposite end of the motor and pop off the plate covering the shaft. The shaft will either have a slot in it for a screw driver or is flattened to allow you to put an open end box wrench on it. This will allow you to unscrew the impeller. You will unscrew in the direction that is opposite to the direction that the veins point at the outside of the impeller. This is the same direction that the motor will rotate the impeller. This may look backwards but the water comes into the center of the impeller and rolls off the veins away from the impeller by centrifugal force. As you take the impeller off, be sure to note how the pump seal is positioned. We highly recommend replacing the pump seal with the purchase of a Go-Kit when replacing the motor.
Step Six
Now you can see the bolts that hold the motor mounting bracket to the motor. Unbolt these, separating the motor mounting bracket from the motor. You are ready to reverse the process to install the new motor.
Step Seven
Important Notes on Reassembly: DO NOT touch the ceramic faces of the seal; This may cause the seal to burn up and leak. Be sure to tighten the impeller completely. Be sure to wire the new motor for 110V or 220V depending on what you have. This may be a simple switch in the motor or you may need to use the wiring diagram on the motor to set for the proper voltage. (Black tracer means the white wire with a black line corkscrewing around it.) Be sure to put the volute back on, aligning properly. Be sure to reconnect the bare copper ground wire to the ground lug on the new motor. When tightening bolts, alternate tightening a few turns at a time to seat evenly or the pump may leak. Fill the strainer housing with water before starting the motor to prime system and prevent damage to seal and impeller.
More Helpful information on how to replace a pool motor
Shaft Seal installation
Clean and lubricate the impeller hub shaft and pump housing seal recess with a dilute solution of non-granulated liquid-type soap
Gently wipe the black, polished surface of the spring seal assembly with a clean, soft cotton cloth. Press the spring seal assembly onto the impeller hub with black polished surface facing away from impeller.
Gently wipe the polished face of the ceramic seat with a soft cotton cloth. Lubricate the O-ring on the ceramic seat and press it firmly and evenly into the recess of the seal plate with polished side facing out.
Place the seal plate onto the motor mounting bracket aligning the positioning lug and guide.
Replacing the impeller and diffuser
Slide the motor assembly, with the diffuser in place, into pump/strainer housing, being careful not to dislodge the diffuser.
Fasten assembly to housing using the four bolts. (Be sure housing gasket is in place.) Tighten alternately and evenly
Oct 03, 2010 | Garden
I have dry hardened dough stuck in the motor area, i need to open it up and remove the flour which is ratteling
hi. 1. remove the screw near the cable. 2. use something sharp, small and robust to lever out the white screw cover which is underneath and in the middle. it looks like plastic moulding. 3. the screw head has a raised middle in the flat head groove. I put a medium flat head screwdriver in a vice and used a hack saw to remove some metal in the middle. it only took 15 minutes so don't be put off. unscrew. 4. lift off the cover. 5.use a toothbrush and the something pokey to clean.
Feb 04, 2013 | Breville SHM2 Twin Hand and Stand Mixer
ZODIAC INGROUND POOL PUMP MAKES A NOISE BUT DOES NOT PUMP WATER. WAS WORKING AN YESTERDAY. HAVE CLEANED FILTER, AND MANUALLY TURNED FAN AT THE BACK. STILL NOT WORKING??
If your pool pump is acting sluggish it may simply be a build up of debris inside the impeller. Cleaning it is simple if you know how.
Step 1 - Check the Impeller
You can check the impeller for clogs by opening the clear cover that is on the strainer basket. Then place your garden hose into the basket and turn it on high. The water should disappear immediately. If it does not, you may have a clog.
Step 2 - Turn off the Power to the Pump
Before actually removing the clog from your pool pump impeller you will need to turn off the power to it. Remove the basket and use a finger to reach into the hole behind the basket to feel for any debris. If it is clogged, go to step 3.
Step 3 - Disconnect the Pump and Motor
Disconnect the pump and motor from the plumbing. Depending upon the make and model of your pool pump you may be able to skip this step. The motor usually just slides away from the pump.
Step 4 - Remove the Plastic Cover
Take the pump apart by removing the plastic cover over the motor. This cover generally has several small screws holding it on.
Step 5 - Remove and Clean the Impeller
Once the cover is removed you will easily be able to see the clog in the pool pump impeller. Just use your fingers or a coat hanger to clean it out.
Step 6 - Clean
Put everything back together. Once you have it cleaned out you can put the cover back on and put it all back together. Problem solved.
Dec 10, 2010 | Plumbing
Pump seal is leaking water. I removed the screws holding the pump together. How do I remove the impellor to get at the seal?
This is from one of my previous posts, may be some extra steps, but should cover what you need... Turn off the electric first. Now split the pump in two by removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing). Once you remove the clamp or bolts, the motor with seal plate, diffuser, and Impeller can all be pulled back away from the pump. Then disconnect the electrical from the motor and you can pull the motor with the seal plate, and impeller all the way out and work on it. To get to the impeller, you need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tail piece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under the thermal overload switch, or removing the capacitor for even easier access. Once you've locked the shaft, you can just unscrew impeller. If the impeller has a bolt or screw in the middle remove that first. this screw will be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure to replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white ceramic, and black graphite surfaces 100% free of any dirt, grease, etc while working with them. Installation is pretty much just the reverse. Install half the seal into the seal plate. Install the seal plate onto motor and bolt into place. Install other half of seal onto shaft. Screw impeller onto shaft and install screw (if one was there to start with) in center of impeller (reverse thread). install diffuser over impeller make sure it is centered and doesn't rub the impeller hub. Install new diffuser and valute o-rings. Hookup wiring before re-attaching to rest of pump. Clamp or bolt back together. Pour plenty of water into pot to prime and flip the motor on for a sec or two. Pour some more water. Install pot lid. You should be good to go. Keep in mind there are many different pumps and some variations to the above instructions, but the above should cover most situations. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 03, 2010 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
How do I remove existing motor and replace it with a new one ? Hayward 2.0 hp # SP2615X20 Thank you
Oct 02, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Looking to replace my elec. motor on my hayward pump # sp3605x7. ser# 640c30. not sure how you..remove the motor from the pump.did not see a set screw? thank you steve 978-606-9706.
Turn off the electric first. Then just remove the 4-6 bolts and separate the back half from the front. The motor with seal plate, impeller, and diffuser can all be pulled back away from the rest of the pump. Now disconnect the electrical from the motor and your can pull the motor with the seal plate, diffuser, and impeller all the way out and work on it. You need to remove the diffuser (plastic housing that goes around the impeller) sometimes this is held by a series of 3 to 6 small screws, other times it just slips over the impeller. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tail piece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white and black ceramic surfaces 100% free of any dirt, grease, etc while working with them. The instructions above a based on a very similar model and may vary slightly, let me know if something doesn't look/sound right and I'll clarify. Good Luck
Sep 24, 2010 | Hayward Single Speed 34 Hp Swimming Pool...
How to install the motot?
Turn off the electric first. Now split the pump in two by removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing). Once you remove the clamp or bolts, the motor with seal plate and impeller and diffuser can all be pulled back away from the pump. You need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. Then disconnect the electrical from the motor and your can pull the motor with the seal plate, and impeller all the way out and work on it. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tailpiece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure to replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white and black ceramic surfaces 100% free of any dirt, grease, etc while working with them. Installation is pretty much just the reverse. Install half the seal into the seal plate. Install the seal plate onto motor and bolt into place. Install other half of seal onto shaft. Screw impeller onto shaft and install screw (if one was there to start with) in center of impeller (reverse thread). install diffuser over impeller make sure it is centered and doesn't rub the impeller hub. Install new diffuser and valute o-rings. Hookup wiring before re-attaching to rest of pump. Clamp or bolt back together. Pour plenty of water into pot to prime and flip the motor on for a sec or two. Pour some more water. Install pot lid. You should be good to go. Keep in mind there are many different pumps and some variations to the above instructions, but the above should cover most situations. if something doesn't sound right let me know by commenting on this post, or sending email and I'd be glad to clarify. Good Luck!
Aug 03, 2010 | AO Smith Pool Pump Motor 1HP Square Flange...
Bosch dishwasher wont drain. At end of cycle is full of cloudy water.
It is possible if you have broken a glass recently that the piece of glass has made its way to the drain pump impeller. You need to remove bottom basket. Remove the filter strainer clamp by rotating CCW. There may be another round filter under the strainer (depending on model). Then with a torque screwdriver remove one screw which holds the plastic pump cover on. Remove the pump cover and pay close attention to the pump impeller. Does it rotate by finger movement? If not it could be jamed with a piece of broken glass. You must remove any obstruction to allow the impeller to turn. I usually force a paper towel piece (half piece while rotating the impeller by finger to allow the paper towel to bring up any obstruction below the impeller) Reassemble the cover and filters carefully and make sure the final strainer clamp aligns correctly with its marks. This insures nothing will make its way to the impeller in future.
Regards Sam
Jun 15, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
104 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
