Question about Video Game Consoles & Games
Ps3 update 2.5
I downloaded ps3 update 2.5 and now the system will not read any discs.
    Problem Solver:
  • 15 Answers
This is a major problem caused by this update, some wont read discs, other wont load the menus. Consult the Sony website for updates or solutions but a popular solution is to enter recovery mode on the ps3, which restarts ps3 totally but formats the ps3, losing data. If you think this is viable, i have linked to the process but here it is:
Turn off Ps3
Hold the power button down; the system will turn on and turn off once again
Once the system has been shutdown, re-press your finger until you hear dual beeps
When you hear the 2 beeps remove finger power button
You will be asked to plug in your controller and press the ps button
This will enter recovery menu, which is:
Recovery menu
- restart system
- restore default settings
- restore file system
- rebuild database
- restore ps3
- system update
Each setting does a different function, consult the manual or PS3 site for consequences but be warned: YOU RISK LOSING ALL DATA IF YOU DO THIS. BACK IT UP. This is not a proven fix for this issue as it is the update which seems to have totalled many PS3's but has proven effective and worked when my discs stuck on title screens, i selected first restart system, then restore default settings the 2 times i have done it and it fixed the ps3 but i lost all of my data.
Posted on Nov 03, 2008
My ps3 will not go into recovery mode. is there anything i can do?
Posted on Nov 18, 2009
Ps3 freezing and disc wont read and skips
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
The most common reason for the PS3 not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PS3 including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PS3 going again!
Hope this will help...
Take care.
I wish you good luck
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
Cant update system so i can play blue rays
You can update your ps3 without going online on the ps3. Go to http://us.playstation.com/support/systemupdates/ps3/index.htm on your computer and download the newest update. Download it to a flash drive. Insert this into the USB port of your ps3. save it to your hard drive, and then update your system from the XBM. Also, newer games (little big planet 2) have the firmware on them so if you buy/rent them, you can install from the disc.
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
Do not read the disc
The problem is that the lens of your ps3 is either dirty or weak that it can no longer read any disc, i advice that you get a lens cleaner to clean the lens of your game, if after cleaning, problem persist, replace the lens on your ps3 so that your ps3 can continue to function as it use to function before.
Replace the lens on your ps3 and you will see that it will start reading discs.
You can also try the below procedure,
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 21, 2010 | Sony Playstation 3 (PS3) Console
PS3 - Game crash followed by disc read error
The update corrupted your hard drive that's why it's not loading any disc.Yes,Restoring the system will work but it will destroy all your saved game data.Updating the system will not remove the hard disk defect.There is only one solution,Reset it.
Jun 14, 2010 | Sony Playstation 3 (PS3) Console
Wont read disc
well as cookies.
May 09, 2010 | Microsoft Xbox 360 Console
Wont read the disc .my sony playstation 3 wont read any disc.
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
• Restart System: Restarts the PLAYSTATION 3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Apr 07, 2010 | Sony Playstation 3 (PS3) Console
It turns on but will no longer read discs.
You can also try the steps below. Its from PlayStation Forum:
well as cookies.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot read any disc.
I wish you good luck.
Mar 28, 2010 | Sony Playstation 3 (PS3) Console
My ps3 won't play blue ray movies!
Cause
PS3 has a AACS (Advanced Access Control System) is a copyright-protection technology that is used on Blu-ray Discs. The copyrighted content is protected by setting an encryption key on both the disc and the device used to play the disc.
An AACS encryption key expires in 12 to 18 months and must be renewed, so no matter if you have a new PS3 or using it already make sure you keep upgrading your PS3 firmware regularly.
Solution
There are two ways to update as listed below:
* Update via Internet
* Update via Storage Media
Download the update data directly to the system from the Internet. The latest update is automatically downloaded.
Select Settings -> System Update, Download the latest update data from the Internet. Follow the on-screen instructions to complete the operation.
You also perform this system update via a storage media, Use update data saved on a disc, Memory Stick™ or other media. Download the update data from a Web site using a PC
Hope this helps, Wishing you happy holidays and happy Gaming
Regards
KreativeGeek
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
Disk not reading
I had a similar problem. My PS3 was not starting the game discs when I inserted those to PS3. Also those game discs were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
Select option "Rebuild Database".
After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
PS3 80 GB - Error Code 8002991
Hi tomdonnatim,
If your PS3 is brand new, you most likely have to update the system's software to a more current version in order to properly play many Blu-Ray discs.
In order to update your PS3 system:
Go to the home menu, move to the "Settings" tab (the 2nd tab from the far left), scroll down to "System Update". It takes about 5 minutes to download and fully download the update, but it should solve the problem.
More information on the system update can be found below:
http://www.us.playstation.com/ps3/about/systemupdate
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
264 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
