I cannot get my hp psc 2110 all in one to print anything! I have tried everything in troubleshooter and still cannot print.
  • 3 more comments
  • mommyluvs6 Nov 03, 2008
    Ok, so I did as you suggested, and it took all this time, (this computer is so slow since we installed the internet in mid Sep). However, I got an error message near the end of the installation process, after I plugged the device back in as directed, it was installing and then I got a message something like: Could not install hardware, printer driver is unknown, and then Device Setup was unsuccessful, may not run properly. ?????
    Hello, Hello, is anyone home? I'm still trying to solve my printer problem, but no-one seems to be answering my questions.
    Ok, so I unplugged the psc 2110 from computer (usb port) uninstalled printer software, then reinstalled printer software and when prompted to plug the printer back in, I did so. But after a little while this error message came up. "Cannot install this hardware. There was a problem installing this hardware. hp psc 2110 series. An error occurred during the installation of the device. Printer driver is unknown. Now what??????
    What is SP2 or SP3?
    Every time I click on the download button to download this driver, it just sits on my computer screen and looks like nothing is happening.
    Genius:
  • 2,035 Answers
Please try the following steps given in this link:
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=uk&dlc=en&docname=c00853577
Good luck...
Posted on Nov 03, 2008
  • 3,037 Answers
Resolution for “Cannot Install this hardware, Printer Driver Unknown”
Install the S/W first – Do Not Plug the USB cable
After completing the S/W installation, Click Start -> Run -> type MSCONFIG
Click on the Services Tab
Put a check mark on “Hide All Microsoft Services”
Then Click on “Disable All” on the same screen
Click Apply, Ok, Restart
Restart the computer
Now connect the USB cable, should install fine from there
Go back to MSCONFIG and on the general tab select “Normal Start Up”
Restart the computer, try to print. . .
Rationale : This problem could be because of a Non Microsoft service influencing the Plug and play service, thus having some negative impact on it.
Ultimately this results improper USB enumeration and unsuccessful driver installation.
If this doesn't work, then try disabling your security systems and let me know what happens and we can work from there
  • 6,487 Answers
If you haven't tried yet to install using the software from HP web site , I will advice you to download the latest software for this printer and install this one instead of using the setup CD of the printer, go to this link for the latest software http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=79495&lang=en&cc=us&prodTypeId=18972&prodSeriesId=295848&taskId=135
    Scholar:
  • 59 Answers
You have not mentioned the OS you are using. May be the drivers provided by the manufacturer are not supported by the Operating system you are using..... Ok, anway assuming you are using XP proffesional, Just uninstall the software using the control panel and then restart the system.Just check the Device manager and uninstall any loaded drivers for the printer.Then rebbot and reinstall the software again. If this doesnt work, enter the website www.driverguide.com  or  www.officialdrivers.com where your system will be scanned for appropriate drivers and then will be automatically installed for free. Definetly this is a driver problem. Let me know if this helps.
    Master:
  • 505 Answers
1. Go to cpntrol panel-Add remove program and uninstalled all the printer software from there
2. Go to registry editor ad make sure there is no entry for the HP printer
3. Unplug the printer from the computer
4. Install SP2 or SP3 if not installed
5. Go to www.hp.com and click on software and driver downloads and download the software for the ho printer.
6. Restart the computer once before installing.
7. Start installing and follow the direction
8. If it still dont get installed you may have to run repair installation of the Operating System
Thanks
  • Indrajit Roy
    Indrajit Roy Nov 03, 2008
    SP1 and SP2 stands for Service Pack 1 and Service Pack2. Click start-right click on My computer and go to properties. You will get to know from there.
    You can download from www.microsoft.com
    Thanks
    President:
  • 624 Answers
Remove the software, then unplug the printer from the computer, then reboot the computer, then reload the software drivers, then plug the printer cable back in when prompted to, then you should be able to print.
  • 2 more comments
  • Dave DeGain
    Dave DeGain Nov 03, 2008
    When you remove the software, use the "add/remove programs" in the control panel.
  • Dave DeGain
    Try checking on the HP website for an updated driver for your operating system. Here is a link to it.
    http://h10025.www1.hp.com/ewfrf/wc/softw...
    You can copy and paste it into your address bar of the internet browser if it is not a clickable link.
    Hilite the entire link and then right click and then choose copy. Then just open a new tab in your browser and click on the address bar at the top and right click and choose paste. Then hit enter or the arrow to the right of the browser. You will come to a page with a choice of operating systems, just click on yours.
    Then you will need to do it all over again from scratch. I am sorry about that, but there is no other way, you must remove the old software first before installing the new. You may just have the wrong software for your operating system.
    Sorry it took so long to get back to you, but I am busy today and can not just sit at my computer and wait for an email, I hope you can understand. I am not ignoring you.
  • Dave DeGain
    You have never told anyboby what operating system you have. "SP2" is "Service pack 2" and "SP3" is "Service pack 3" for Windows XP operating system. All of the experts here are just assuming that you are using Windows XP because you have not told anybody otherwise and it is the most used operating system. You ocan get the updates you need from www.microsoft.com and it is a good idea to keep your computer up to date.
    Try clicking this link for an updated driver, just select your operating system from the list to get it.
    http://h10025.www1.hp.com/ewfrf/wc/softw...&
  • Dave DeGain
    Once you select your operating system, you will get a page that has all the software downloads for your product, including the driver, patches, utilities, and firmware upgrade for it as well. Just follow the instructions given to do all of these properly.
Hp psc 2110 printer will print but will not scan. It displays that I need to install software that it does not have that option. I don't have the cd.
my psc will not scan now. It says it is not connected to the computer, but a month ago it did scan. I use Vista windows and was able to scan either with Paint or Photo Gallery
Mar 31, 2010 | HP PSC 2110 Color Printer
The printer will not power up. Everything is
If no power, try to check the plug fuse first.
Sep 09, 2009 | HP PSC 2110 Color Printer
Right when i turn it on it makes noise hp psc 2110
Dose it work?
My hp 750 dose this and even talks when not working.
You can get HP Print Diagnostic Utility software which will fix most hp printers issues.
www.hpsupport.com
R Miss Brooks
Sep 02, 2009 | HP PSC 2110 Color Printer
Hp psc 2110 won't work in vista
Vista has the drivers for the HP psc 2110 embedded in the OS.
So, you should be able to print, with the default drivers. But, you will not be able to scan as of right now, unless someone releases an update for the HP PSC scanning software. I doubt that will happen, as these all in one's are so old.
Such a good little printer/ scanner/ copier too.. kind of sad to think its that obsolete that its not compatible for scanning.
Jan 19, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 2110 all in one
Try to clear out all old print jobs and then go to your printer,
Right click on printer Icon and check to make sure it is set as Default.
Nov 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer trouble.
hmmm..ok
remove the old software.
go to www.hp.com and get new drivers
re install them
try it again
May 10, 2008 | HP PSC 2110 All-In-One InkJet Printer
HP psc 2110 all-in-one wont print from internet
I'm assuming you went to the HP site and downloaded the Vista drivers??? Other than that try this:
  1. From Control Panel > printers... uninstall all printers.
  2. Unplug USB cable to printer and re-boot.
  3. Install Software.
  4. Plug USB cable back in.
Hope that fixes Ya...
Geno
Mar 26, 2008 | HP PSC 2110 Color Printer
Printer problems
Cycle printer power (off for about half hour).
If still nogo rry uninstalling the S/W then re-installing S/W from CD ROM.
Search HP website for Driver upgrade.
Feb 23, 2008 | HP PSC 2110 Color Printer
19 people viewed this question
k24674
