Question about Fujitsu Siemens LifeBook N3010 Notebook
How to remove hard drive from Fujitsu Lifebook N3010 PC laptop
I've tried removing every screw I can find and cannot determine how to remove the hard drive from my Fujitsu Lifebook N3010 laptop. Help?
  • Anonymous Mar 24, 2014
    i am trying to reset my laptop, but can't find the reset button
  • Anonymous Mar 31, 2014
    hard drive remove
Remove the DVD drive, and then there are 4 outer screws holding the hard drive chassis in place. There are also 4 inner screws that hold the hard drive to the removable hard drive chassis, those do not have to be removed to remove the hard drive from the computer. Carefully remove the screws so they don't fall into the holes on the sides of the screws, and then slide the hard drive out of the pin slots.
Posted on Nov 15, 2008
Fujitsu N3010 lifebook internal mouse will quit working after a few minutes after boot up
Do a full anti-virus scan of your system, if okay! try a system restore bring computer back in time before this happened.
Apr 20, 2012 | Fujitsu Siemens LifeBook N3010 Notebook
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
Need to replace a keyboard on a Fujitsu Lifebook N3010. Dropped beer on it. Now some of the keys aren't working. Would like detailed inst's on how to crack this comp open.
I have stripped many laptops down and to remove keyboard is reasonably complex and replacements are also expensive. Dowload a manual off the net is the best and follow instructions to the letter. Ther isnt enough room here to describe the procedure.
Nov 20, 2009 | Fujitsu LifeBook N3010 Notebook
How I can down load audio driver for N3010?
Follow this link to the driver downloads page at Fujitsu. Choose Notebook PC > N series >N3010 and all of the drivers will be available to download.
http://support.fujitsupc.com/CS/Portal/support.do?srch=DOWNLOADS
Oct 18, 2009 | Fujitsu Siemens LifeBook N3010 Notebook
How I can down load audio driver for N3010 lifebook Fujitsu?
http://www.fujitsu-pc-asia.com/drivers/spring05/n3510/audio/winxp/n3510_audio.zip
Hi here is a link copy and paste into top of broswer i know its not the right 1 but ive been on there web site looking for your laptop and could not find it just try to install ok most likey they will be same audio chip find all info at fujitsu hope this helps please rate
Is the back light bulb replaceable in the Fujitsu Lifebook N3010
yes it is and a suitable place to find it is Ebay or search it by part number on google, as NEC will not have the display for it.
Jun 26, 2009 | Fujitsu Siemens LifeBook N3010 Notebook
Fujitsu Lifebook N3010 boot error
Do you have the original Driver and Application (DAR) CD? If so change your BIOS setting to boot from CD first and boot from the DAR. This will take you to the backup partition DICE (Disk Image Special Addition) on your hard drive. This will allow you to restore your system to the original drive image configuration. You will loose all your data!!!!!!!
Mar 10, 2009 | Fujitsu LifeBook N3010 Notebook
How do I remove a hard drive from a fujitsu lifebook T 4020 ?
underneath the laptop will be access panels, unscrew them and remove, the hard drive looks similar to this 95631bb.jpg
Nov 24, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
Removing bottom of laptop
It is a difficult task. After removing all the screws, look for the plastic locks on the sides of the top cover. On the one side you got the screws, and the other the plastic locks. Before removing the locks carefully detach the flat cables conecting the boards. Remember, do not break any connection and also make sure your laptop is off. The next thing you should do is to remove the battery. Now carefully slide the bottom cover off laptop.
Sep 30, 2007 | Fujitsu Siemens LifeBook T-3010 Notebook
Fujitsu Siemens LifeBook N3010 Notebook Logo
968 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
