Question about Polaroid PDV-0700 Portable DVD Player
Definite ribbon problem!!! Need help.
After a little breakdown of the unit, I determined my black screen is due to a ribbon issue. The ribbon which runs from the main body, though the right hinge to the screen is damage. When poked at it shows a picture briefly. Is there any way to fix this or find a new one? I know Polaroid is absolutely useless in regards to help with this specific dvd player. Thanks C
  • 50 Answers
Hi It's sad when a simple problem, causes a piece of equipment to be thrown away, while all the expensive parts are still ok. If you are mechanical, and can carefully take the unit apart,(make sure it is unplugged), the ribbon cable may be a plug-in type, and you can remove it from it's connector on the monitor end, and in the main unit, and if you bring it to your local electronics repair shop, they may give you one if they have one the same size (same # of conductors), or sell you one for a few dollars. Otherwise, if you have a fine tipped soldering iron, and experience soldering, you can bypass some or all of the damaged connectors in the ribbon cable with small wires. Cut them to length, and solder them to the respective pins on the ribbon cable connectors. Hopefully, you can see which lines on the ribbon cable have been damaged, and will only have to hard-wire bypass a couple. Otherwise, it would be more economical to replace it. Hope this helps! Good Luck!
Posted on Nov 30, 2006
My Hp notebook screen is black,sometimes it fades in and out black to grey then to black.how can i fix it
Connect your laptop to an external monitor and switch to monitor. If the external monitor shows the desktop, then the complaint is in the lcd/led display unit means the screen. Replace the screen. If the external monitor also shows the complaint, then it is normally due the mch(media controller hub) . It comes as separate card unit in some models and onboard for some other models.Only an experienced technician can solve that issue. In some rare cases it is due to a corrupted BIOS. Reply if this helped you.
Sep 15, 2014 | HP G70-467cl Notebook Pc Lcd Back Cover -...
How to remove ribbon cable from Garmin Nuvi 1490
Try this link for a pictured breakdown of Kindle Fire HD.
https://www.ifixit.com/Teardown/Kindle+Fire+HD+Teardown/10457
There's also directfix.com which has some help.
May 07, 2014 | Garmin nuvi 1490T GPS Receiver
Vertical black stripe on screen
Hi my name is Roety,
I can help you with your issue ,
The black strip is either a bad panel or part of the lower buffer board is bad. There are ribbon cables that run from the panel to the buffer it may just be a loose ribbon connector
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 29, 2009 | Gateway GTW-P42M303 42 in. Plasma...
My Zenith P42W46X 42 inch tv got two black lines vertical lines on the screen the were coming and going away before but they are more stable now.i opened it up and wiggled all the connections arround the...
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable near the black lines. Unplug the ribbon cable and look for black chips on the underside of it, I think they say 100 on them, you need to resolder both ends on each chip. Should fix the black line issue.
Oct 08, 2009 | Zenith P42W46X 42 in. Plasma EDTV
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
1" black vertical line in center of screen. Sony Plasma.
NOT DEFECTIVE!!!
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Aug 19, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black screen on camcorder
I think you have two different issues here. The black screen may be due to a CCD failure. Canon has a worldwide service notice regarding this issue, and will repair your unit at no cost if they determine this is the problem (it sounds like it is).
The little red symbol indicates your backup battery (or date/time battery) CR1616 needs to be replaced. It is located behind a small square panel which you can see to the left of the menu buttons when you open the LCD panel.
Dec 08, 2008 | Canon ZR70MC Mini DV Digital Camcorder
LCD Screen
Replace the Ribbon Wire between the Mini DV unit and the lcd screen. Samsung wanted $136 to repair same issue for me. Screen started with colored lines eventually going to white lines and finally screen went completely black and stayed black. I replaced the Ribbon Wire after purchasing a copy of the systems schematics and repair manuel online. With total cost of everything i bought to make this repair I saved a little over $115 from what Samsung wanted for the same repair.
Jul 21, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Avic x1r fault
It's the flexible PCB ribbon that goes to the screen. According to Pioneer, they no longer offer replacement pieces.
Dec 05, 2007 | Pioneer AVIC-N2 Car DVD Player
Nintendo DS Lite
Well something more appropriate i guess would be my ongoing issue with DS's that have had screens replaced.
if you could describe something for me
as the unit will not power ,,, plug in the charger, if it is as i suspect you will get an orange light illuminate for 1 second, after it goes off the unit is unresponsive until you unplug and replug the charger.
if this describes your problem i would be most interested to hear weather you used the ORIGINAL screen or if it is a replacement screen
thanx
Nov 14, 2007 | Nintendo DS Lite Console
Polaroid PDV-0700 Portable DVD Player Logo
138 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
