Question about Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier
Ionic breeze quadra
Wire broke and it doesn't work
  • TuffKitten Apr 22, 2009
    OH JOY! I just KNEW the answer to this issue would be along those lines. I wonder where I could take it to have it fixed. It's still under "warranty" which does me a fat lot of NO GOOD now that SI is BK. The place that is handling SI's warranties won't honor original manufacturer's warranty... only if you purchased extended and WHO DOES THAT????!!!!
If you are talking about the 2 thin wires inside the unit, it can be fixed if you are good with taking things apart. You have to do an almost complete tear-down of all the internal components (many hidden screws). You can replace the broken wire with a .009 or .008 gauge E string for an electric guitar. This can be found at a local musical instrument store. The string must be cut to almost the exact length. The wire has a spring tension mount on a small circuit board. If the replacement wire is too long, there will be too much slack, too short and you will not be able to put it back together. I did this and it took me hours. I removed about 80 screws to disassemble it.
Posted on Dec 16, 2008
I have the same problem as Theloneroofe as desribed on Dec 2 2009. One of the wires on my ionic breeze quadra broke. It is one of the wires that have the glass beads on them that you clean by turning the...
These are special tungsten wire that have special ends on them to hold in place. I have some of that wire, but do not know how the ends are made to make replacements.
I doubt that you can find parts for these units.
Dec 18, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
One of the wires on my ionic breeze quadra broke. It is one of the wires that have the glass beads on them that you clean by turning the quadra up and down. Can it be replaced and how? Thanks.
You're probably screwed...
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to pick up spare parts if you scour eBay long enough.
Dec 02, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
How do you reset a Quadra ,Ionic Breeze
Hi.
This appliance simply resets by disconnecting the power cord for five minutes. The control board does not include battery.
If the model was manufactured before 2007, pleas read below.
Ionic Breeze Concerns
Regards.
Ginko.
Nov 14, 2009 | Sharper Image Professional Plus Ionic...
I have an Ionic Breese Quarda that just stopped working all of a sudden. Is there someone who can walk me through some basic fixes? Company out of business I'm told.
The high-voltage grid wire(s) most likely broke -- unfortunately, there is no good remedy for this -- I have repaired a half dozen of these units by replacing the grid wires with titanium wire. This is a very time-consuming, complicated, nerve-wracking repair -- not recommended. Even if the reapair is done, the unit will likely fail again, soon.
When my reapired units failed, I got units off E-Bay -- they didn't last very long either.
I'm now in the market for a more rugged ozone-generating air purifier.
Charlie
Sep 21, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Broken "wire/filament' in ionic breeze quadra
This does NOT work. The electric guitar wires burn out in 1-2 months.
Jul 13, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
How to get replacement parts for Sharper Image ionizer?
one of the electrodes broke off the botto of one of my towers.
Dec 26, 2008 | Sharper Image Professional Plus Ionic...
Ionice breeze quadra Model # S1637
had the same problem with ionic pro ca500. i took the unit apart and found a fuse that was blown and it works now. sorry but i don't know if there is any repair shops.
Aug 02, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Where can I have a Ionic Breeze Quadra Model S1637 repaired?
Try this link, pair for $10- http://breezerepair.com/parts.html
Jul 16, 2008 | Sharper Image Ionic Breeze® Quadra® 4.0...
Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier Logo
666 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
