Question about Toshiba 50H82 50" Rear Projection Television
Video problem picture has a pronounced serrated edge and flashes a double image constantly,i call it a wiggley picture.the on screen display is absolutely perfect with no wiggle,menu is perfect also,tried both tuners and a video signal all the same
  • Steven Millar Sep 27, 2006
    Thanks for your help,I was not sure which module to go to
    Problem Solver:
  • 16 Answers
Soundslike you have a bad Video Module in the set,I beleave it is a MVPU14 module right in back of the video input jack panal,it's a metal can module,Ive repaired this module by haveing the Surface mounted filter's replaced,Only 1 problem you will need a Knolageable Teck W/the skill to find and replace the bad filters causeing your problem,(The Edges of thje picture seem to be tearing )Right? Im sure thats your problem, Goog Luck Walter Grzybowski
Posted on Sep 27, 2006
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
Double images on screen
IT SOUNDS LIKE A PINCUSHION PROBLEM. IN MOST CASES IT IS DUE TO CAPACITORS GOING BAD ON THE BOARD. OTHER TIMES SOME TV'S HAVE LARGE MICROCHIPS THAT RUN THE PINCUSHION AND COLOR SYNC. HOPE THAT HELPS.
Feb 20, 2010 | RCA HD52W56 52" Rear Projection HDTV
Picture has double images around the edges of the viewing area.
Firstly check for correct colour registration at centre of screen. Look for coloured halo around white edges in centre area of picture. Use static convergence adjustment if necessary to correct centre of screen. Then follows an involved process of interactive adjustments to attempt correction of errors at the screen extremities. If these are out of adjustment range this is indicitive of a convergence drive fault requiring professional intervention.
I hope this information is helpful!
Jan 01, 2010 | Hitachi Televison & Video
I have double image I am looking at array but not
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 05, 2009 | Hitachi 50DX20B 50" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
*Screen Looks 3-D
*Colors wont align
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Double image on screen
*Screen Looks 3-D
*Colors wont align
Jan 22, 2009 | Sony KP-53S75 53" Rear Projection...
SD300 LCD Display Shows Same Image
Sounds like it needs service. Call Canon tech support.
May 28, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Blurry double image on the edge of the tv...
If you have tried to adjust the convergence on your TV within the menu feature then typically you do have a convergence problem. Check out this video to be sure...
Apr 16, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Vertical stretchon pictures
This is from what you describe - more the computer dispkay than a camera proble.
How do other images look[not the camera] on the screen?
or the deck top. -Check out this first them come back to the camera images.
Nov 15, 2007 | Canon PowerShot S3 IS Digital Camera
Toshiba 50H82 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
