Question about KitchenAid Refrigerators
Kitchenaid icemaker No water getting to icemaker. I was told it needs a new motor. Voltage to motor between black and white wires reads less than 50 volts AC. when I put 115vac to icemaker white and black motor runs. Any suggestions on what to do next. Is there a fuse in the voltage line? If so where is it located.
  • 59 Answers
Most icemakers have a thermal fuse on the black wire feeding them. If this fuse overheats then it will blow to protect your fridge. Check for continuity through the fuse.
(Note that the fuse itself can not be changed. The whole wiring harness has to be changed.)
Posted on Nov 03, 2008
My Roper washing machine will not complete a cycle. It stops before it gets to rinse. If I turn it off and wait a few hours, it will run and finish if I waited long enough. Could the motor be dying?
ATTACHEMENTS ON HOW TO TEST MOTOR
The following test must be made on one-, two-, and three-speed drive motors:
1.
Touch and hold one ohmmeter probe to the terminal on the white/black wire from the motor.
2.touch the other ohmmeter probe to the terminal on the white wire from the motor.
3.The ohmmeter should showZEROresistance (continuity). If not, the drive motor is bad and needs replacing.
Start Winding
4.
Touch and hold one ohmmeter probe to the terminal on the black wire from the motor.
5.Touch the other ohmmeter probe to the terminal on the yellow wire from the motor.
6.The ohmmeter should show a reading between 4-10 ohms.
7.If you do not get this reading, the drive motor is bad and needs replacing.
High Winding
8.
Touch and hold one ohmmeter probe to the terminal on the white wire from the motor.
9.touch the other ohmmeter probe to the terminal on the blue wire from the motor.
10.The ohmmeter should show a reading between 0-4 ohms.
11.If you do not get this reading, the drive motor is bad and needs replacing.
12.Touch and hold one ohmmeter probe to the terminal on the white/black wire from the motor.
13.Touch the other ohmmeter probe to the terminal on the blue wire from the motor.
14.The ohmmeter should show a reading between 1-5 ohms.
15.If you do not get this reading, the drive motor is bad and needs replacing.
The following test must be made on two-speed drive motors, along with steps 1-15:
Low Winding
16.
touch and hold one ohmmeter probe to the terminal on the violet wire from the motor.
17.Touch the other ohmmeter probe to the terminal on the white wire from the motor.
18.The ohmmeter should show a reading between 1-7 ohms.
19.If you do not get this reading, the drive motor is bad and needs replacing.
20.Touch and hold one ohmmeter probe to the terminal on the violet wire from the motor.
21.Touch the other ohmmeter probe to the terminal on the blue wire from the motor.
22.The ohmmeter should show a reading between 1-7 ohms.
23.If you do not get this reading, the drive motor is bad and needs replacing.
24.Touch and hold one ohmmeter probe to the terminal on the violet wire from the motor.
25.Touch the other ohmmeter probe to the terminal on the white/black wire from the motor.
26.The ohmmeter should show a reading between 1-7 ohms.
27.If you do not get this reading, the drive motor is bad and needs replacing.
The following test must be made on three-speed drive motors, along with steps 1-27:
Ex-Low Winding
28.
29. Touch the other ohmmeter probe to the terminal on the white/orange wire from the motor.
30.The ohmmeter should show a reading between 1-5 ohms.
31.If you do not get this reading, the drive motor is bad and needs replacing.
32.Touch and hold one ohmmeter probe to the terminal on the white wire from the motor.
33.Touch the other ohmmeter probe to the terminal on the white/violet wire from the motor.
34.The ohmmeter should show a reading between 1-5 ohms.
35.If you do not get this reading, the drive motor is bad and needs replacing.
36.Touch and hold one ohmmeter probe to the terminal on the blue wire from the motor.
37.Touch the other ohmmeter probe to the terminal on the white/orange wire from the motor.
38.The ohmmeter should show a reading between 1-5 ohms.
39.If you do not get this reading, the drive motor is bad and needs replacing.
40.Touch and hold one ohmmeter probe to the terminal on the blue wire from the motor.
41.Touch the other ohmmeter probe to the terminal on the white/violet wire from the motor.
42.The ohmmeter should show a reading between 1-5 ohms.
43.If you do not get this reading, the drive motor is bad and needs replacing.
44.Touch and hold one ohmmeter probe to the terminal on the white/black wire from the motor.
45.Touch the other ohmmeter probe to the terminal on the white/orange wire from the motor.
46.The ohmmeter should show a reading between 1-5 ohms.
47.If you do not get this reading, the drive motor is bad and needs replacing.
48.Touch and hold one ohmmeter probe to the terminal on the white/black wire from the motor.
49.Touch the other ohmmeter probe to the terminal on the white/violet wire from the motor.
50.The ohmmeter should show a reading between 1-5 ohms.
51.If you do not get this reading, the drive motor is bad and needs replacing.
52.Touch and hold one ohmmeter probe to the terminal on the white/orange wire from the motor.
53.Touch the other ohmmeter probe to the terminal on the white/violet wire from the motor.
54.The ohmmeter should show a reading between 2-8 ohms.
55.If you do not get this reading, the drive motor is bad and needs replacing.
The following three (3) checks must be made on all one-, two-, and three-speed drive motors to check for an internal failure (short):
56.
Touch and hold one ohmmeter probe to the drive motor housing.
57.
One at a time touch the other ohmmeter probe to each of the wires (terminals)coming from the drive motor.
58.
The ohmmeter should show an open circuit when each of the wires (terminals)are checked. If not, the drive motor is bad and needs replacing.
HOW TO live TEST a G.E - MOTOR
After removing the cabinet follow the wires from the motor halfway up the tub. Then cut and splice the ORANGE, the BLUE, the VIOLET /WHITE, & the RED wires.
Now using a long long extension cord with the end connector cut off and exposing the 2 end wires stripped back about an inch.
To check the spin cycle: Connect and splice the RED & the Blue wires to one end of the extension cord wire. And the ORANGE & WHITE /VIOLET to the other end of extension cord, be sure to use but connectors or electrical tape. Plug in the cord an the wash cycle should start? If not the motor is bad.
To check the wash cycle: Connect the BLUE and the WHITE/VIOLET wires to one end of cord. And the ORANGE & RED connected to the other end of cord, then plug in and the wash cycle should start? If not the motor is bad.
By the way my advice is free cuz God is good!
Mar 20, 2015 | Roper Washing Machines
KitchenAid 5kpms
OK you have mains voltage across the black wire and the white wire on the 2 bottom terminals on the left side of the speed control plate. You are certain that the carbon brushes are in the correct way around with the shaved off corner lining up with the blocker in the brush holder. Are the switch contacts touching when the lever is moved to position 1. They are on the inside of that black control plate. If they are touching and still no go you need to check that the fields have a circuit. You notice that the black and the white wires cone from inside the machine, there are 2 more going inside as well. Remove the brushes and check for a circuit between one of those other 2 wires to one of brush holders and the other wire to the other brush holder. If that's OK you are pretty safe to change the phase board that is above the black control plate. It has about 4 wires coming out of it. The control plate has wire colours written on it beside each terminals so there is no chance of a mistake if you can read.
Mar 15, 2014 | KitchenAid Food Mixers
1988 Nissan Pickup keeps going through alternators and batteries
Next time it's overcharging check the voltage on the two white wires and the black wire with the connector plugged in and the engine running. The two white wires should be the same voltage. There should be no voltage on the blacks wire. If there is voltage on the black wire than check for a bad ground. If the voltage on one of the white wires is different than the other than you'll need to dig into the harness and check for corrosion in the wire with less voltage. Are you familiar with how to check for voltage drops? This might be and effective test when the alternator is acting up as well. I can explain it to you if we need to do it. Btw, the readings that your are seeing are volts not amps. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 01, 2012 | Cars & Trucks
Water dispenser doesn't work
I have the same problem with a 2002 model. Icemaker working but no ice or water comes out the door dispenser. Also the light in the door is not working (i.e. no electricity getting to the door.)
Just had a service call. They told me that the whole door needs to be replaced because the wires that power the door are broken from normal opening and closing of the door. $1500 repair!!!!!!!
(KitchenAid did a POOR design with this frig. Open your freezer door and look toward the floor. On the left side, you will see a rope-like thing coming from the freezer to the door. Everytime this door gets open and closed, it crimps the wires... and thus, eventually they break.) The newer models have concealed wiring.
Two of my neighbors had the same problem with this frig a few years ago and KitchenAid replaced the door at no charge. I just spoke with KitchenAid. At first they told me that I was out of warranty. When I told them this is an obvious design flaw, they told me they would give me the new door since I have 3 other registered KitchenAid products. I have to pay for the repair service, which will be about $200 plus the $75 service call I had today. Better than buying a new frig.. but still frustrating because of the design flaw.
Aug 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Told motor was bad, replaced motor, new motor does not run
Black to Black, Purple to White and the new motor requires a run capacitor which brown goes to one side of capacitor and brown/white goes to the othe side of the capacitor. This is providing the old motor is a single speed. If the old motor is a two speed you have an incorrect replacement motor.
May 02, 2009 | Heating & Cooling
Water overflowing in ice maker.
I just replace my kitchenaid icemaker. My model is 4317943. And it comes with a sheet of menu. I scan a portion and hope it will help.
Apr 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
The out door fan motor is bad. it has three wires the new one has four, a black one a white one and two brown how do i wire up the cap.
the two brown wires go to a capacitor which you should buy new when you buy the motor. they usually cost less than $5.00 and since your motor wires are not the same the capacitor in your a/c may not be the right one for the new motor and it also may be bad.
for the white and black wires they go to the load side of your contactor. it's important that you check the voltage rating on your motor and the a/c to make sure it's the right voltage for your a/c.
usually there's a wiring diagram on your a/c showing the line or power wires coming in to the a/c, they usually go to the contactors line side the opposite side is the load side to wire the motor to.
Mar 16, 2009 | Carrier 36KCARMS Air Conditioner
Kitchenaid Icemaker does nothing. Ref. Mod.kscs25Inssoo
This also happened after I changed the water filter. The small black rubber tube that fills the tray was plugged with ice. Instead of hot wash cloths I used a hair drier for a couple of minutes.
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Icemaker problem on Sears Side-by-side #106.56546400
I have a kitchenaid referigator. The icemaker just stop working. The little red light blinks, when the door is open only. What do I do?
Thanks,
Bubba
Sep 26, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
119 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
