Question about Denon AVR-4800 Receiver
Denon ARV 2105 Power Up Problems
Worked fine last night, powered up this am for a split second and then immediately powered off. I can push the on/off button off and then on to get the red light back around the on/standby button. Then when I push the on/standby button to try to power it on a get a message that says "2 FRONT LARGE". We've unplugged it and re-tried, didn't work. Any thoughts?
  • 1 more comment
  • sassa1 Nov 03, 2008
    we unplugged the front speakers and tried again to power it off. still have the same problem.
    it will turn off, when it turns on it goes to the 2 front large message and no, we cannot make any button on the front of the receiver or the remote do anything. if you still think we should unplug all speakers, we will do that tomorrow. when you say unplug, do you mean the wire from the back of the speaker or unplug them from the back of the receiver?
  • sassa1 Nov 05, 2008
    we've finally been able to do what you suggested and we are still having the same problem. still have the same message. system seems to be locked up. no button on the front works except the on/off button does turn it off. remote does not work at all.
  • 3,037 Answers
Your front two speakers may be drawing too much current, unhook them first and see if it works without them, if it does, then the speakers are the problem,
let me know what you find and we can work from there
Posted on Nov 03, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Nov 03, 2008
    can you go into the menu and change settings at all?
    from your second comment, it seems that you are now not able to turn it off? or is it just not staying on?
    If you disconnect all speakers, will it work, and then test one speaker at a time, what happens?
  • Benjamin Patri
    unplug them from the receiver
  • Benjamin Patri
    Benjamin Patri Nov 05, 2008
    Try the following and if it doesn't work then your protection circuit might need to be replaced or at least someone will have to diagnose down to the exact problem in your unit which I expect to be a short somewhere but this will need to be physically tracked down by an electronics expert.
    1. Switch off unit and unplug AC cord from outlet.
    2. Press and hold the DIRECT and STEREO buttons, whilst simultaneously plugging in the AC cord.
    3. Check that the display is flashing with an interval of about 1
    second, and release your fingers from the two buttons and the microprocessor will be initialized.
Denon AVR 2105 5years old has worked perfectly. Now all of a suddend Zone 2 does not come on. Any ideas why after working perfect for so long?
Bad button on the remote? or
static discharge from being touched can cause all kinds of strange problems.
I would reset the micro processor back to default settings..
RESET PROCEDURE
1. PUSH MAIN POWER SWITCH OFF
2. WHILE HOLDING THE FOLLOWING KEYS DOWN, PUSH MAIN POWER SWITCH ON
AVR-2105 or AVR-885 Front Speaker A and B (2 keys)
Let the front panel blink 3 or 4 times and then release the keys (buttons)
You will have to do your set up again i.e. speaker size, assign inputs, FM presets etc.
Aug 25, 2013 | Audio Players & Recorders
Denon AVR 2105 power shuts off, tried resetting the micro processor and no luck. Please help...
The receiver has an internal problem like bad power supply or burnt channel. You need to bring it to a local repair shop or mail it here.
Feb 06, 2011 | Denon AVR-2105 Receiver
Power wont come on at all
May be the power supply check for power to the power supply and the output voltage from it as well !! May need to be replaced ! It cost $125.00 for part and $225.00 for a new one installed !!
Jul 21, 2009 | Denon AVR-1506 Receiver
Denon 1508 shuts off every 3 seconds red light is flashing
Protection- burned channel or power supply (+- 15v)
Apr 05, 2009 | Denon AVR-2105 Receiver
Powers turns on then off
faulty power amp output section occurs this problem.
canyou open the cover and are you technicaly sound to do the repair.
nuwan.
Jan 19, 2009 | Denon AVR-1604 Receiver
Power wont stay on
Hope your under warranty mate and if so hope its not in Australia as they cannot fix this problem. My denon was allegedly fixed twice but has now failed a third time (just out of warranty) and denon have turned their back on me.
SHAME ON YOU DENON.
Jul 08, 2008 | Denon AVR-2105 Receiver
Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Jan 10, 2007 | Denon AVR-1706 Receiver
See: http://www.denon.ca/hapdfs/avr2105mane.pdf, page 72. In my case, the problem was a connector between my receiver and television. I unplugged it from my receiver and it now works.
Dec 03, 2006 | Denon AVR-2106 Receiver
Denon AVR-4800 Receiver Logo
120 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
