Question about Axsion Axion ACN-5515 4 in. Portable Television
TV Picture & Sound randomly go on and off
The picture and sound on the tv randomly go on and off as if it isn't getting power...this happens every couple of minutes...it is very irritating. What is causing this?
    Welcome Back:
    Visited the website for 2 consecutive days.
Try a different RCA cable or use a HDMI cable on it. If it persists, check the power board to see if there's a bulged capacitor inside but first unplug the power cord from the source before any inspection.
Posted on Aug 22, 2018
Are you looking to buy a media-streaming device for your TV? There are a number of(Amazon Fire Stick Tech Support) great options in the market when it comes to media streaming devices, but Amazon has been doing exceptionally great. The e-commerce giant, with its latest launch Amazon Cube, alone has three different devices.
Get more info:- http://www.techserviceus.com/fire-tv-stick-prime-device-support/
    Sergeant:
  • 337 Answers
A lot of times the dc jack where you plug the power cord gets loose conections after so many times of use,if that is the case the set nneds to be open and the jack resoldered,sometimes is the ac adapter that is intermitant ,try twisting the wire to see if it makes any difference.If your tv looses power when using batteries you might be looking at a broken board.
Posted on Sep 26, 2006
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
I have a JVC HD 52g787, the sound works but no picture, The tv comes on, but the blue light just blinks, then cuts off, I have sound no picture
The problem is usually from the power or the Y sustain at the left or right side of the display when one of the large capacitor or heat sync on the capacitor even the flat power cable connection it to a main power board needs to be checked too, if the fuses on the board are blown it will need to be replaced
But after replacingthe fuses and the capacitors and still no solution,youwill need to replace the all board ..
You can also trouble shoot first before going to the board of the TV..
How to Troubleshoot an LCD With Sound But No Picture
It can be overwhelmingly frustrating when an electronic device as expensive as an LCD television set starts having problems. Luckily many of these problems are easily troubleshot. While being able to hear sound coming from your LCD television but seeing no picture may seem serious on the surface, fixing the problem involves checking a few different settings to make sure everything is set properly
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jul 17, 2011 | JVC HD-52G886 52" Rear Projection HDTV
JVC picture turns into a single line in middle of screen.
This is caused due to random falure of vertical scan circuits. It generally is caused by dried out capacitors or bad driver IC. Unfortunately it will get worse. If you fail to turn the TV off quickly you will burn a permenant horizontal line on the tube. Trip to the repair shop I am afraid.
Nov 30, 2009 | Televison & Video
LG Television 37LB4D "Rebooting"
Ours is crapping out just like yours. Picture goes out, "black and white squiggles" appear in the top left of the screen then TV input appears, then it either repeats or gives me my picture back. This happens with both the HDMI slots (tested all 3) and both Component slots. Seems like the bulb or a circuit board on the TV is faulty. What a piece of ****, never spending another dime on LG products. I did get it to come back by hitting the back of the TV with a good slap, but it gets really annoying.
Jun 14, 2009 | Televison & Video
Picture but no sound on my Vizio L37 Flat Screen
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Jan 29, 2009 | Vizio GV42L 42 in. LCD Television
No picture, no sound, stand by timer light flashing
Need a little information here...
1. The TV remains on, yet there is no picture and no sound? Or does the TV turn off altogether?
2. How many blinks does the standby light give? Are they continuous? Is it the same each time, or random?
3. Did anything else happen before this, or did it just happen one day?
Answer that and I'll try to help with what I know.
Jun 09, 2008 | Sony KV-32V40 32" TV
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Axsion Axion ACN-5515 4 in. Portable Television Logo
239 people viewed this question
Top Axsion Televison & Video Experts
Are you an Axsion Televison and Video Expert? Answer questions, earn points and help others
