Question about Tetra Garden
Change Clarifier Bulb
How do I change the UV bulb in a TetraPond PF2500 pressure filter? Specifically, how do I remove the clear plastic protecting sleeve? Do you have downloadable manuals for this device? I lost mine.
  • 21 Answers
For instructions and to get a new parts breakdown you call the Tetra Pond Division in Virginia toll-free 800-526-0650 any issues getting the right info, plan B is to ask for Product Manager Curt N.
Posted on Mar 20, 2009
How do i go about replacing the uv light
obtain proper replacement bulb
shut down entire filter for a moment before unscrewing the top locking ring off Uv filter (left turn) lift top off set asside
using a soft clean rag retract uv tube from its cylinder holder inside , remove power connector from tube end (you should have already removed all power from converter box) with extremely clean rag handle new tube ( allow no forign material to touch outside of tube ) reinsert power connector onto new tube (same way it came off old one) then reinsert tube into holder sleeve , route power cord to proper places away from lid , replace lid and install lock ring back with enough force to ensure a leak proof seal , re start pump ck for leaks if none found then restart power converter for Uv filter
Jun 05, 2015 | Sunterra 300207 Pond UV BioFilter 2000...
How do i remove the uv bulb
Place your finger in the door recess on the right-hand side of the sanitizer and pull open the door.
Remove the drip tray.
Remove the protective screen by gently lifting it up and pulling it forward.
To remove the UV light bulb, pull it out of the lamp holder.
Install the UV light bulb by snapping it into the lamp holder.
Align the pegs on the protective screen with the slots in the reflective surface of the sanitizer on either side of the UV light bulb.
Insert and gently push down the screen to secure it in the sanitizer.
Reattach the drip tray.
Dec 13, 2014 | Air Purifiers
The plastic holder for the bulb in my tetra pfx-uv 12000 pressure filter has all **** burt out and it is all a seald unit and tetra do not sell spare parts for that any help please
Try to fix it by replacing the broken part with a plastic embrace to hold the pressure of the water. Use plastic PVC with tie raps.
Jun 03, 2011 | Garden
Can you clean the clear tube that seperates the UV bulb from the water in a Tetra Green 2 UV?
A test tube brush or a small bottle brush will fit and not damage anything. Alternatively as long as it is not used for saltwater soak in a bucket of 5 gallons water and a 1/2 cup of bleach will kill and separate any algae. Just rinse thoroughly to flush out any leftovers and to clear the unit.
Apr 10, 2011 | Tetra Green Free Uv - 2 Clarifier - 18...
How do I replace the headlight bulb on a 2000 Ford Escort ZX2?
² Coupe
² Sedan/wagon
2. Open the hood and disconnect the headlamp wiring socket from the
in-line connector. This will make it easier to change the bulb.
3. Remove the protective dust shield
from the housing by turning the
dust shield counterclockwise (when
viewed from the rear).
4. Release clip and disconnect the electrical connector from the bulb.
5. Remove the bulb retaining ring by
rotating it counterclockwise.
6. Without turning, remove the old
bulb from the lamp assembly by
pulling it straight back out of the
lamp assembly and replace.
7. Install the new bulb in lamp assembly by pushing straight in with the
bulb’s plastic base facing upward. Turn the bulb slightly to align the
grooves in the plastic base with the tabs in the lamp assembly.
8. Install the bulb retaining ring over the plastic base and lock the ring
by rotating it clockwise until it snaps into place.
9. Connect the electrical connector into the plastic base until it “snaps”.
10. Install the protective dust shield and lock the shield by rotating it
clockwise until it locks into position.
11. Connect the headlamp wiring socket to the in-line connector.
12. Turn the headlamps on and make sure they work properly. If the
headlamp was correctly aligned before you changed the bulb, you should
not need to align it again.
Feb 03, 2010 | 2000 Ford Escort
How do you change the uv bulb in a hozelock vorton 2200
remove the 2 screws at the end of the unit and pull the end off.the bulb is attached and will come out with it.pull the bulb out uf the holder and replace.(on mine the screws have 2 differnent heads on for some unknown reason)
Apr 18, 2009 | RTO Vorton UVC500 Clarifier For 500gal...
Garden Logo
298 people viewed this question
Top Tetra Garden Experts
Dennis Key
Dennis Key
john h
Are you a Tetra Garden Expert? Answer questions, earn points and help others
